Old Nov 09, 2013, 02:21 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
I cut the elevator off, took off the top covering and opened the top of the outer stab bays.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Nov 09, 2013, 04:52 PM
Dark Yet??
Joined Dec 2009
I marked a line down the center of the elevator and cut notches for the LED strip to ride in. The strip is held down with a dot of thick CA and a small piece of Blenderm tape. The electrical attachment is thru the LE of the elevator and will later be routed thru the stab.
Old Nov 09, 2013, 06:44 PM
Dark Yet??
Joined Dec 2009
Used pin hinges to put the elevator back. Put some LED strip in the stabs. The elevator power wires will route thru the stab and out the LE of the stab into the fuse. The stab power will also come out the LE of the stab. I hope to cover these wires with monocote.
Old Nov 10, 2013, 03:43 PM
Dark Yet??
Joined Dec 2009
I removed the covering from the top of the fuse and small piece on the side. I tried the strip several ways. On the sides, in the bottom of the fuse shining up and in the top shining down. I settled on one in the bottom and 1 on the top. They both shine into the fuse. Tied a piece of string to the backing and fed it thru with a CF rod. Then you can pull the string and remove the backing when it is in place. Added some thick CA to the strip to help hold it down.
Old Nov 10, 2013, 06:20 PM
Dark Yet??
Joined Dec 2009
Testing the fuse lights.
Old Nov 10, 2013, 11:41 PM
jstiltner is offline
Find More Posts by jstiltner
United States, VA, Blacksburg
Joined Aug 2010
Looking Great Barn!
jstiltner is offline Find More Posts by jstiltner
Old Nov 11, 2013, 11:20 AM
Dark Yet??
Joined Dec 2009
Now to get all the empennage wiring up to the front of the fuse. I had to run the wires on the LE of the stabs for a short distance. They are exposed for now but I am going to try and cover over them later.
Old Nov 11, 2013, 05:54 PM
Dark Yet??
Joined Dec 2009
The wires have to be routed and the the stabs can be covered back. I covered the exposed wiring on the LE.
Old Nov 12, 2013, 07:32 AM
Dark Yet??
Joined Dec 2009
Re-covered the elevator top in white to match the ailerons. Hinged it back with pin hinges.
Old Nov 13, 2013, 12:22 PM
Dark Yet??
Joined Dec 2009
I put some waterproof blue LED strip on the vertical stab to make things easy and wired it all up temporary for a test.
Old Nov 13, 2013, 12:25 PM
Dark Yet??
Joined Dec 2009
Used a piece of perf board to mount the Turnigy Multi RX switch on and a Deans connector.
Old Nov 13, 2013, 05:24 PM
Dark Yet??
Joined Dec 2009
At this point I made a 8 pin connector for the wiring harness from the board to the wing. It has separate connections for the ailerons, mid wing, LE and 3W circuits. The plan is to switch the ailerons, mid wing and 3W circuits, leaving the LE as "Always On". There is a two row header on the board to plug circuits into for Always On or to test a strip.
Old Nov 13, 2013, 07:54 PM
Dark Yet??
Joined Dec 2009
Looks like the Turnigy Multi Switch is not going to work out. The LEDs are dimmer running thru it. Probably pulling too much current for it.
Old Nov 14, 2013, 03:50 PM
Dark Yet??
Joined Dec 2009
I ditched the Turnigy switch and installed a small RGB controller. It is not remotely operated but If we get a Xen later it will be easy to change. Much brighter now.
I have the ailerons, elevator, mid wing, stabs and 3W on the RGB controller and the vertical stab, fuse body , cockpit and cowl are Always On.
Old Nov 15, 2013, 12:55 PM
Dark Yet??
Joined Dec 2009
Kadet ARF Night Flyer (0 min 48 sec)
Build Log Kadet Senior ---- Super Night Flyer Build Barn-E-Stormer Night Flying 203 Jun 17, 2014 09:46 PM
Discussion E-Senior Night Kadet N2RYD Night Flying 4 Mar 12, 2013 05:40 PM
Discussion Sig Kadet Senior EG ARF on current issue of Model Aviation ripacheco Electric Plane Talk 5 Jan 21, 2013 12:02 AM
Sold Sig Kadet Senior T-tail Night Flyer~ flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 16 Dec 07, 2012 07:40 PM
