This thread is privately moderated by cmala, who may elect to delete unwanted replies.
Old Apr 27, 2013, 07:25 PM
cmala is offline
Find More Posts by cmala
Trader Rating: 19
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Trader Rating: 19
For Sale
OS 33GT Prop Bushings
If you have an OS 33GT and you want to use a prop that has a 10mm diameter hole in the center then you need some bushings.
These bushings are designed to slide over the shaft of the OS 33 GT engine and also fit inside a prop with a 10mm ID hole.
They are 2 for $10 shipped in the continental US. Outside of the US pays $10 plus actual shipping charges for two bushings.
Craig
cmala is offline Find More Posts by cmala
Old Apr 27, 2013, 09:22 PM
PropsnWings is offline
Find More Posts by PropsnWings
Trader Rating: 45
To Infinity and beyond!
PropsnWings's Avatar
Joined Jun 2011
Trader Rating: 45
This guy is stellar. Products are very well made.
PropsnWings is offline Find More Posts by PropsnWings
Old Apr 29, 2013, 06:08 AM
cmala is offline
Trader Rating: 19
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Trader Rating: 19
I also make custom standoffs. Aluminum engine/motor standoffs made to your specifications.
Just let me know what you need. I've been doing this for about a year now.
Craig
Old May 25, 2013, 01:21 AM
rino is offline
Find More Posts by rino
Trader Rating: 165
Big Extra
USA, CA, Lincoln
Joined Apr 2003
Trader Rating: 165
I need a couple of these. Do you take paypal? They are for my Dad's OS 33 GT so we'll pay with his pay pal or however you want to take payment. Just let me know.
Steve
rino is offline Find More Posts by rino
Old May 25, 2013, 07:47 AM
cmala is offline
Trader Rating: 19
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Trader Rating: 19
Yes I do take Paypal.
PM sent
Old May 25, 2013, 02:00 PM
stevehookem is offline
Find More Posts by stevehookem
Trader Rating: 0
Hook 'Em Horns!
stevehookem's Avatar
Joined Jul 2011
Trader Rating: 0
How will this work if I also need to add the TruTurn spinner adapter to the outside of the prop nut? Currently, I have a bushing inside only the spinner backplate. The prop I have been using has an 8mm hole.
Do your adapters only extend to the front of the prop? Your photo makes them look as long as the entire shaft.
stevehookem is offline Find More Posts by stevehookem
Old May 25, 2013, 02:12 PM
Trader Rating: 0
Hook 'Em Horns!
Joined Jul 2011
Trader Rating: 0
I just ordered 2 sets of 2. If they're too long, I'll just cut them down. I need them to be only long enough to go through my TruTurn spinner and through the prop or just prop only. Do you cut them to length or send longer that we cut?
Old May 25, 2013, 06:09 PM
cmala is offline
Trader Rating: 19
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Trader Rating: 19
They actually slide into the motor a little and fill the prop without sticking out.
I think you will be fine with the spinner as long as the back plate has a 10mm hole.
If not, let me know and I will make you some new ones to the length you specify.
These will not be too long. If anything they would be too short depending on how thick the spinner back plate is.
You should have these on Tuesday as long as the post office doesn't get backed up from the holiday.
If you don't mind, post a couple pictures
Craig
Old Sep 20, 2013, 12:32 PM
Jeff Worsham is offline
Find More Posts by Jeff Worsham
Trader Rating: 86
AMA 13456 NSRCA 4513
Jeff Worsham's Avatar
Rio Rancho, NM
Joined Nov 2007
Trader Rating: 86
Hi- still selling these? If so, do they require pressing into the 10mm prop hole or do they slide in by hand? I've made my own out of brass and have to press-fit into prop and would like to get away from that.
Jeff Worsham is offline Find More Posts by Jeff Worsham
Old Sep 20, 2013, 07:51 PM
cmala is offline
Trader Rating: 19
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Trader Rating: 19
Yes. Www.customstandoffs.com
No tools necessary. Slide in fit.
Craig
Question Hat bushing for prop saver, source? Joshua Wesley Power Systems 7 Feb 15, 2013 12:59 PM
Question Prop bushing question Electrofish Electric Plane Talk 12 Feb 08, 2013 10:37 AM
Question Brass Prop Shaft Inside An Oil Impregnated Bushing? scoobyvoodoo Scale Boats 17 Feb 06, 2013 02:00 AM
Discussion Prop bushing for FSK (Flying Styro) props? RAFster Electric Warbirds 1 Oct 10, 2007 02:31 AM
Discussion why put bushes in os LAs and not bearings? spitfire123 Engines 24 Sep 04, 2006 05:42 AM
