Old Dec 24, 2014, 09:31 AM
solomonx is online now
Find More Posts by solomonx
I can fix that.
United States, PA, Mountain Top
Joined May 2006
Does anyone have good BLHeli 12.2 params for the HH blh3327 motor and xp3a esc? I put this setup on the HobbyZone Sport Cub. Without the gear box, the motor starts and stops fine without issue. When meshed with the gear box, I sometimes get the screech of the motor not starting. Giving the propeller a little spin first gets it going fine. Once running it is fine. The only issue I have is with the startup. If I move the throttle up slowly from zero, it usually starts fine as well.
Thanks!
solomonx is online now Find More Posts by solomonx
Old Dec 24, 2014, 09:39 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
Oops...misread your question.
Which firmware are you using. Multirotor code or Tail?
Try the tail code if you haven't already. It's the most basic and applicable to the needs of a airplane.
It was developed for the brushless tail motor of a CP heli. So the response is instant.
Daryoon is online now Find More Posts by Daryoon
Old Dec 24, 2014, 11:52 AM
I can fix that.
Joined May 2006
I'm using the multirotor version. I use that on a lot of blue series 12a esc's and small high kv motors and it works great!
My only problem is the startup. Once it's spinning everything is fine. The throttle response and power is good and never loses sync. I'm not sure what to adjust so I don't screw anything else up.
Old Dec 24, 2014, 12:00 PM
Team WarpSquad
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
The ULTIMATE UM 1s BL Conversion
I just told you what to try.
Old Dec 24, 2014, 12:15 PM
I can fix that.
Joined May 2006
Thanks, I'll try the tail code.
Old Dec 26, 2014, 12:52 AM
I can fix that.
Joined May 2006
Tail code didn't really work. It would sometimes stall and screech upon initial startup. Also, once spinning, the motor wouldn't shut down.
I put the multirotor code back on and played with the startup power - still got several non starts. What finally worked was setting the startup method from direct to stepped. Now it starts every time. Not as smooth, but reliably.
Old Jan 19, 2015, 09:08 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Hi guys, can somebody please help me
This is what I have assembled so far.
I intend on running a nCPX BL motor off of a YEP7a, but on an airplane and using the brushed output of a built in ESC for signal.
What parameters do I need to change in the BLHeli Suite? Should I try the tail or multirotor code?
My goal is to free up a channel on my RX because I currently have to mix throttle to flaps and plug my ESC into the flap channel.
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Feb 05, 2015, 04:19 PM
marblekit is offline
Find More Posts by marblekit
United States, CA, Tustin
Joined Oct 2014
Does anyone know if I get any generic ESC with BLHeli firmware on it that it will understand the brushed throttle signal from my Spektrum UMX receiver brick? I have the SPMA3175 brick from the Hobbyzone Sport Cub S and the brick cannot be programmed to output a brushless signal.
I've read that some ESCs with BLHeli firmware can take the brushed signal as throttle input but I don't know which ESC to get.
Thanks in advance for any help!
marblekit is offline Find More Posts by marblekit
Old Feb 05, 2015, 05:14 PM
Dylwad is online now
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
They all learn the signal and adjust to it, but you might have to play with the settings depending on if the brushed esc outputs pwm to the positive or negative lead, and sometimes the brushed output can be a little dirty (which results in bad throttle linearity), so you have to either add a resistor between the motor leads to clean it up, or you need to grab the signal on the board before it gets to the fet, or it can be as simple as lowering the high throttle travel adjust in the TX to make full stick=full throttle.
Dylwad is online now Find More Posts by Dylwad
Old Feb 10, 2015, 11:07 AM
WoodyInMD is offline
Find More Posts by WoodyInMD
United States, MD, California
Joined Jan 2014
Hey Valiant, did you have any luck flashing the YEP7A with BLHeli?
It looks like we have the same flashing set up but, so far, i've yet to drag myself back to the bench to try it. I'm very interested in knowing how you got on.
Keeping my fingers crossed for you.
Woody
WoodyInMD is offline Find More Posts by WoodyInMD
Old Feb 10, 2015, 07:07 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Woody
I'm more or less in the same boat, I rigged everything up but I haven't tried flashing it yet.
BLHeli Suite seems pretty complex and daunting to use if you don't know what you're doing
Old Feb 10, 2015, 09:34 PM
Dylwad's Avatar
Joined Jun 2002
Its actually very simple, a few button presses, and select the right ESC in the drop down menu, takes all of 10 seconds. Its even easier to update settings after it has been flashed.
Old Feb 22, 2015, 09:51 AM
Joined Oct 2014
Where exactly do you add a resistor and of what size? Does "between the motor leads" mean between the positive and negative signal of the brushed motor output? What would be the best way to find the throttle signal on the board? Thanks...
Old Feb 22, 2015, 12:31 PM
Dylwad's Avatar
Joined Jun 2002
Yes, between the positive and negative motor outputs. For 1s stuff we usually used a 1000 ohm, but anything from 100 to 10k will have an effect.
brushed motor fets are usually pretty simple, they have an input "source", output "drain" and signal input, or gate. The input will be either positive or negative battery voltage, output goes to the motor, gate will trace back to the mcu, with some resistors and caps, and sometimes a signal inverter. you follow the trace back to the mcu and pick up signal there, which should be a clean pwm at battery voltage from 0 to 100% duty cycle corresponding to the throttle channel. The fet sort of amplifies this pwm signal which switches power to the motor, regulating the speed.
http://www.helifreak.com/showthread.php?t=416851
Old May 16, 2015, 11:32 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Originally Posted by bhoov128 View Post
Your post over there was pretty awesome. I'm thinking that I'm going to do exactly what you've done with the blh3327 and my new 3drankin airframe. Good job!
Curious...did you ever actually do it? Asking specifically because I've got a pair of AR6400's (sitting in a pair of Su-26XP's) that I'd consider modifying if it'll work.
BryanEW710 is offline Find More Posts by BryanEW710
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
