Old Oct 16, 2012, 02:31 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by gunradd View Post
Would be cheaper to get one turbine! Then you would be lighter , have more power and be able to leave the left thumb up!
Great build Brent. Only a few people could scratch build something like that and I can say I am not one of them. Great work from both of you.
Dude, just because you went Turbine dosent mean you need to keep dragging it over here.... We know you love your turbine
bri6672 is offline Find More Posts by bri6672
Old Oct 16, 2012, 03:18 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
thanks for the encouragement guys. im thinking a couple 120 fans using the inner gear door openings as cheaters will be the best performing edf setups for this. now i just need the money to buy 2 120mm setups haha.
There you go bud...now your talking. I know you have hook up for JHH stuff so maybe a couple turbax's? The TF-4000's are a pretty good deal also.
It may be even cheaper to find used dynamax's and convert them with outrunners.... you know how cool they sound.
But I think your on the right track now to get this baby moving out... looking forward to seeing it go. I have a brand new glow vio fan you could convert....I'd work you a good deal if your interested in it. Then you just need to find one more...
Ron101 is offline Find More Posts by Ron101
Old Oct 16, 2012, 03:20 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
while i would really like to go turbine, theres a number of issues going that route too, especially with a foam model. id have to heat/fuel proof most of the inside of the model, adding more weight, also, the complexity of learning a completely new type of power system, that i have 0 experience with (other than flying a CARF flash a couple times)
corsair nut is online now Find More Posts by corsair nut
Old Oct 16, 2012, 03:22 PM
tehachapi, CA
Joined Jan 2006
vio fan....NEVER! haha.
id go turbax's for sure. chris wolfe recently did some testing on 8000 mah neu packs that was very interesting. were talking 17-18 lbs of thrust with no inlet ring, on a trusty ol' 1527
Old Oct 16, 2012, 03:24 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
dude, just because you went turbine dosent mean you need to keep dragging it over here.... We know you love your turbine
+1 :d
Old Oct 16, 2012, 03:33 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
HA! turbax should work out nice for what you are doing
Old Oct 16, 2012, 04:02 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Ask Chris about the 100mm.....
Old Oct 16, 2012, 05:05 PM
tehachapi, CA
Joined Jan 2006
thats my 100mm, i built it, he tested it. i flew a 105mm in my kfir that i built.
100 would work with full ducting, but it needs a solid 6kw to match the 120 at 5kw. something to consider. andys flies well on 100's.110's might work with ducting. 105's like i had in the kifr would be killer at 5500w. the kfir only had about 4400.
Old Oct 16, 2012, 05:22 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i think 110 at a min,120s are going to be hurting for FSA. you need something that well allow you to back off the power and cruise at say 75% but you know that already ,you need some sponsers for this beast....and a trailer
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 16, 2012, 11:37 PM
rush1 is offline
Find More Posts by rush1
rush1's Avatar
United States, CA, Palmdale
Joined Mar 2011
Originally Posted by P. Richards View Post
Both jets were damaged, and they can be repaired.
See you in California...
http://youtu.be/pdHCGUxS9mA
P. Richards aka SwatTeam
Oh man thats brutal to watch two great flying birds Hope to see them in the air again
rush1 is offline Find More Posts by rush1
Old Oct 17, 2012, 02:45 AM
argyris is offline
Find More Posts by argyris
SHINDENBOY
argyris's Avatar
ATHENS
Joined Feb 2007
Congratulations both of you!Gunradd is right, only a few people could scratch build something like that.I'm sure you will solve all the problems!One question i have is if you have measure the instaled static thrust?With so big inlets and outlets how much is the losses?
argyris is offline Find More Posts by argyris
Discussion Las Vegas Ace in the Hole 2012 falcon5 Electric Flight Events 238 Jun 27, 2013 05:52 PM
Discussion What's the hole in jetdrive shaft for? jetboatman Dock Talk 7 Jul 06, 2012 02:12 PM
Fly-In Vegas ace in the hole xi, oct 12,13,14, 2012 Sugarbear36 Electric Flight Events 0 Oct 23, 2011 12:20 PM
Discussion "Ace in the hole" event...Oct 1. 2. 3. 2010 who's coming and whatcha bringin'? One Six Right Electric Ducted Fan Jet Talk 15 Sep 26, 2010 03:54 PM
