Old Mar 25, 2012, 01:55 PM
ballores is offline
Find More Posts by ballores
UK, West Sussex, Chichester
Joined Aug 2008
Brushless silverlit v tilt
Hi just picked up one cheap and wondered about putting in a couple of um 180 Stryker motors with the props turned round, I can do the wiring etc just wanted your thoughts before the scalpel came out, am I pi$$ing in the wind, would appreciate your input.
Cheers Nick.
ballores is offline Find More Posts by ballores
Old Mar 26, 2012, 04:56 AM
Machy2k is offline
Find More Posts by Machy2k
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
Well since there has been no answer's...I'll put my two cents in...
This plane is toy grade, but approaches hobby grade, it would benefit more from elevator control maybe also rudder and changeable batteries.
It is amazingly good at S.T.O.L..
Mine is ok to fly in airplane mode but looses altitude in turns very quickly, these need addressing IMHO before better motors, go for it mate....
Machy2k is offline Find More Posts by Machy2k
Old Mar 27, 2012, 11:58 AM
ballores is offline
Joined Aug 2008
Just Trying to find how to set up two brushless motors on an ar6400nbl 100 views but no takers!.
Old Mar 28, 2012, 09:51 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
You can't, there's only one on-board ESC and even if it could start two motors wired in parallel it wouldn't be able to handle the amps (nor could you program it for differential thrust if that's what you have in mind). You'd have to go with separate ESCs and RX rather than try to use the 6400 brick.
Tres Wright is offline Find More Posts by Tres Wright
Old Mar 28, 2012, 11:35 AM
ballores is offline
Joined Aug 2008
Many thanks Tres I have done differential thrust before but used an orange rx, thought I could plug in a separate esc and wire that to the flap channel, and power it off the main battery after removing the BEC wire.
Didn't want to be the first to try and cook my brick, will go with two sec's and a spektrum rx.
Old Apr 02, 2012, 11:18 AM
ballores is offline
Joined Aug 2008
NearLy there took a lot of getting apart, and putting back together, will video if all is well.
Old Apr 02, 2012, 02:48 PM
Forney, TX
Joined Mar 2002
Good luck, if you can get it to work it would be awesome It the tilt via a servo? I've never seen one up close.
Old Apr 02, 2012, 03:12 PM
ballores is offline
Joined Aug 2008
Tres,there is a servo type affair with offset arms so the wings come up slightly off centre,and the motors are spun up independantly to control the rotation.
i am installing two servo's one for each wing and a couple of speed controllers,might work or might be something of nothing.
Old Apr 02, 2012, 07:01 PM
Machy2k is offline
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
Dude we need Pics man large and detailed babee!!!
Old Apr 02, 2012, 07:04 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
There's a plane in here somewhere with an external ESC wired into the NBL, so I don't see why you couldn't wire 2 of them in. He isn't using the internal one only the external. I'll try searching and remembering were I saw it.
TODD
Found it : http://www.rcgroups.com/forums/showp...&postcount=433 hope you have a programable TX.
I R Irv is offline Find More Posts by I R Irv
Old Apr 03, 2012, 12:04 AM
ballores is offline
Joined Aug 2008
Cheers Todd, I have a dx6i which you can mix to get differential, it's a double mix and the flap/gear channel mirrors the throttle with the rudder for mix.
Worked on a 10 xpv shadowhawk but the sec's were too heavy.
Thanks for the link BTW, but I think the ar6400 might have issues with 3.7g servo's.
Nick.
Old Apr 03, 2012, 03:02 PM
ballores is offline
Joined Aug 2008
used the spare ar6400nbl and wired it with another esc and fed the bec wires to the servo's and took the signals from the board all works fine.
The gear channel is mirrored with the throttle and they both work as they should got to work out the servo arrangement next.
Old Apr 05, 2012, 02:48 PM
ballores is offline
Joined Aug 2008
Installed the motors and the props they are both rotating in the same direction but one is spoiling up differently than the other, though they both mirror each other on the monitor screen.
I used this arrangement on a pair of brushed esc's on a different plane, so have just ordered a pair of brushless esc's will keep you posted.
Any suggestions of contrrotating props that will fit the Stryker motors would be appreciated.
Old Apr 05, 2012, 09:44 PM
Forney, TX
Joined Mar 2002
Nice job on the progress! Are you setting it up with differential thrust? If so then you don't have to worry about the motors not spooling up together because you can adjust it with your trim (I went through something similar just recently, worked fine). I didn't bother with counter-rotating props on mine because with props this small it's not a big deal.
Old Apr 06, 2012, 12:08 AM
ballores is offline
Joined Aug 2008
Tres, yes I am using differential, on mine, On the monitor screen the other motor was mirroring the throttle, but not in reality.
I have ordered two esc's but will still have a play with trim and mix.
Matched esc's is probably the way to go, Nick.
Sold Piranha 600 Brushless V-Hull jdr43 Boats (FS/W) 0 Oct 29, 2011 12:47 PM
Sold VEN-1373 Venom V-Series 36AMP Brushless ESC w/ LiPo Safe Technology NEW! tprada1624 Aircraft - Electric - Power Systems (FS/W) 0 Oct 22, 2011 04:23 PM
Discussion V-tail mixer for camera tilt? lovegroove Multirotor Talk 3 Oct 13, 2011 09:54 AM
Discussion I am running a mini v on lipo and brushless, does the prop torque tilt the boat ? mortonj69 Dock Talk 9 Apr 27, 2009 08:31 AM
update on V-22 tilt rotor v22chap Coaxial Helicopters 24 Aug 26, 2004 12:06 PM
