Old Nov 20, 2011, 12:46 AM
Tranworld is offline
Find More Posts by Tranworld
Singapore, Singapore
Joined Apr 2005
Turnigy 9X - beware of the hook
Today I happen to open the central hook, where you would normally hang the TX to a lanyard, and found that it is far from secure. The thread is badly made and is very loose inside the nut that retains it, in fact there is very littl hold. During use it could easily detach from the TX body and the whole thing may drop down.
Check your TX. if anybody has a good spare one they don't need, please let me have it, I will be glad to pay for it
Tranworld is offline Find More Posts by Tranworld
Old Nov 20, 2011, 01:38 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
what is "central hook"?
What is "lanyard"?
What "thread"?
What "nut"?
Were you trying to dry your TX by hanging it from clothe line under the sun?
What were you trying to do? Why do you need a replacement?
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Nov 20, 2011, 01:47 PM
pchewn is offline
Find More Posts by pchewn
Pat Chewning
USA, OR, Beaverton
Joined Sep 2009
What is "lanyard"?
What "thread"?
What "nut"?
I'll translate
Central Hook = Neck-strap ring (where the neck-strap attaches)
Lanyard = Neck-strap (Goes around your neck and supports TX)
Thread = Helical groove on cylinder face to convert rotational motion to translational motion.
Nut = internally-threaded piece to engage with externally-threaded screw
What is so hard to understand about his terminology?
I'll translate again:
The neck-strap attachment piece has a threaded portion that does not engage properly with the threaded nut. It is dangerous because if you are using this neck-strap to support the transmitter, it has a high risk of failing and the transmitter dropping to the ground and breaking. He'd like to fix it with a replacement part.
pchewn is offline Find More Posts by pchewn
Old Nov 20, 2011, 06:38 PM
Joined Apr 2005
Many thanks Pat for the exact translation, indeed that was what I was trying to warn people about. It may be a singluar manufacturing default in this case but you never know, so I am trying to warn people to double check theirs, theerby avoiding an unnecessary accident
Old Nov 21, 2011, 12:59 AM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Old Nov 21, 2011, 01:00 AM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Singapore people use English. Your English needs translation.
Learn RC terminology.
I don't use neck strap anyway. Need not worry about.
Old Nov 21, 2011, 01:30 AM
Joined Apr 2005
I must admit that central hook was an invention of mine for lack of memory of what it is called, however lanyard, nuts and thread are common words and need no translation. The only problem is that I have too many hobbies, not just RC and the convention in each are different, tbe lanyard is usually used in torches and mountain equipments, as to nuts and thread, well everywhere really
By the way I live in Singapore but am not Singaporean, if I had used Singlish you WILL need translation
Old Nov 21, 2011, 09:59 AM
caseih is offline
Find More Posts by caseih
Joined May 2005
Yeah I think it is Mr Kim whose knowledge of common English terminology (RC or otherwise) is lacking. After his first post I was pretty sure he was joshing you but after the last post of his, I wonder.
Thanks for the heads up anyway. I have not had the problem with the eye hook ring thing so far.
caseih is offline Find More Posts by caseih
Old Nov 21, 2011, 04:12 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Thanks for the heads up - I will inspect mine before I use the neck strap (hopefully that is the politically correct term from an engineer that despises the English language because it is completely illogical)
Scott
ScottSails is offline Find More Posts by ScottSails
Old Nov 21, 2011, 04:33 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
i thought you were referring to the addictive nature of the 9x radio.
dave1993 is offline Find More Posts by dave1993
Old Nov 21, 2011, 05:50 PM
Joined Apr 2005
haven't thought of that, brilliant. Yes beware of the 9x hook, I haven't stopped improving my beloved 9x....I am hooked
Discussion Mysterious Flaperons on Turnigy 9x richardmrazek Radios 2 Jul 19, 2009 05:08 PM
Help! Turnigy 9x settings IGnition Radios 3 Jul 16, 2009 05:55 PM
Sold Turnigy 9X 9Ch Transmitter (Mode 2) and 2 recievers FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 2 May 19, 2009 12:31 AM
FAQ Binding/Synching the Turnigy 9x, with their module to the 4ch rx. Ravenseye Radios 0 May 10, 2009 09:41 PM
