Old Nov 23, 2014, 05:59 AM
Slovenia, Tolmin, Municipality of Tolmin
Joined Nov 2014
FPV video goes out after few meters?
Hello... OK I admit I bought low budget FPV kit from eBay (rx RC5808/tx TS58200).
But anyway is it normal to have video noise on few meter distance???
Look video:
myfpv (0 min 8 sec)
But when I go out on open area the video is gone after 10 meters?? Black! Nothing..
I try different anntenas, changing channels,... ok channels chart is little confusing.
Remote is 2.4 GHz and FPV is 5.8 GHz.
Any idea?
Erik
erikhrast is offline Find More Posts by erikhrast
Old Nov 23, 2014, 07:25 AM
Ikaruswannab
Joined Sep 2009
Might be that Channels between VTx and VRx don't match.
Is a frequent error.
teopbako is online now Find More Posts by teopbako
Old Nov 23, 2014, 05:50 PM
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
Yup. Time for a range test with two folks on cell phones. After the one with the TX gets out at a appreciable distance cycle through the base station setting until you get the best reception. You're done.
1fullbird is offline Find More Posts by 1fullbird
Old Nov 23, 2014, 08:21 PM
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Just to clarify what the guys said above- the channel numbers labeled on the transmitter do not match the channel numbers on the receiver. TX ch 3 might be RX ch 8. It's a crap shoot. Only way to tell for sure is to cycle through until you find one that works well.
c131frdave is offline Find More Posts by c131frdave
Old Nov 23, 2014, 09:11 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Look video: https://vimeo.com/110567401
Any idea?
Erik
one of two things.
One of your antennas has a broken connection somewhere,
or your transmitter is putting out very low power
some times a transmitter comes new like that, and sometimes it can happen from something like overheating, or running without an antenna.
m_beeson is offline Find More Posts by m_beeson
Old Nov 23, 2014, 09:52 PM
sunk more than scorp
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
How about SMA / RP-SMA conflict?
The key is to have a male/female connection internally with the antenna adapters
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 24, 2014, 12:50 AM
closeflyby's Avatar
Joined May 2010
I also just got that combo. First off, follow the transmitter manual for dipswitch settings(the switch position is in black). For the receiver, don't follow the manual but the sticker on the back. This time, however, the switch position is the opposite of what it shows(you can think of it as the white space as the switch position).
I'm testing this in a car with my 9x and found that the fpv receiver being too close the radio antenna could cause some interference. Even after repositioning antennas I'm still only getting about 30m which is pretty disappointing since I hear you should get at least 200-300m.
closeflyby is offline Find More Posts by closeflyby
Latest blog entry: My first quad!
Old Nov 24, 2014, 04:22 AM
Joined Nov 2014
I'll try to scan all channels. I will set CH1 on TX, and then I'll test all CH on RX :/
The antennas are OK.. and conntectors too.
Discussion Hubsan H102F FPV looses connection after few seconds misiek_mati FPV Aircraft 0 May 21, 2014 02:42 PM
Discussion FAA Goes After Tornado Damage Video Silent-AV8R Multirotor Talk 14 Apr 30, 2014 07:33 PM
Discussion ornithopter getting crashed after a few meters of flight help me with the reasons anji.surya Ornithopters 10 Apr 25, 2013 09:39 AM
Discussion First longer distance FPV: quadcopter goes out of range and crashes [video] Mauronic FPV Talk 4 Sep 15, 2012 12:42 AM
Discussion FPV test flight video - 36mhz radio goes crazy at 600 meters away :( chancesAU FPV Talk 1 May 07, 2008 12:19 PM
