Old Nov 12, 2013, 02:41 PM
flo
flo's Avatar
Near Munich Germany
Joined May 2003
LSD a lightweight DS and slope design
Hi,
as my other project got stuck a couple of times this year i happend to have some time at hand to try an idea i had for quite some time.
Every summer on those lazy days we talked about a light weight sloper for some fun DS when all other ships stay groundet.
Hence the name - Lazy Summer Days
Eventhough lightweight i wanted a reasonably fast flying design of modern outline.
I defined my goals:
all parts Milled on my little cnc
aprox 165 cm wingspan
aprox 600g
modern outline and section
geodetic wing construction
DP custom section as usual
twisty wing to make things a little more intresting
So early Okt i hit the keyboard and about 12 days later maidened my mark one LSD.
What shall i say?
It flies really well as long as kept on speed, roll need to be improved for acro, even thermals well.
Withstands even a bungee launch on a f3b siced rubber.
Just keep on the speed.
Quite addictive really
Mark II is beeing build by my Buddy Toni fuse greatly improved, wings need only slight changes.
DS ability needs to be determined, i am beeing a little buisy at the moment.
Pics do not show actual version, i will ask Toni to post some.
These will only give you an impression.
enjoy
flo
flo is offline Find More Posts by flo
Old Nov 12, 2013, 03:45 PM
Dave Pope Manawatu NZ
pope's Avatar
Palmerston North NZ
Joined Dec 2006
Love the concept. Great building
pope is offline Find More Posts by pope
Old Nov 13, 2013, 08:43 AM
Confirmed Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
That looks really cool. Around here there aren't too many slopes I'd think about landing a plane with a built up wing, though.
screamin' eagle is offline Find More Posts by screamin' eagle
Old Nov 13, 2013, 09:12 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Those wings are beautiful - engineering AND art
Shedofdread is offline Find More Posts by Shedofdread
Old Nov 13, 2013, 11:21 AM
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Handcatch ?
Thanks all for your kind words.
greets
flo
Old Nov 13, 2013, 01:17 PM
SlingWinger
San Bernardino, California, United States
The name definitely fits the look of that wing, it's kinda psychedelic looking.
The ribs appear to be of sandwich construction.
My only criticism is the fat aft fuselage, but I realize that will provide robustness while remaining lightweight. I could get used to it, but I'd rather see a tapered composite tube used there.
Because my slope sites aren't balsa friendly, a CNC'd foam wing structure would be nice. Take a look at Gordon Johnsons' first venture from indoor to slope, he has a lot of experience with "skeletonized" foam airframes.
dayhead is offline Find More Posts by dayhead
Old Nov 13, 2013, 02:44 PM
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi,
ribs are of 2mm ply, fuse is from poplar.
aft of fuse happened because i wantet to get the proto into the air.
Has been changed since to have a little more pleasing lines.
should be robust enough for its intendet purpose - lightwind conditions.
i wanted to build a design that works without specialised composite parts.
wood and stuff from the DIY stores.
time will tell
greets
flo
Old Nov 13, 2013, 03:59 PM
Tarzanstyle English Sorry
AgoMago's Avatar
Cittadella(PD)(Italy)(Europe)(World)
Joined Nov 2004
Plans
Are plans avilable for free or not?
Very nice looking wing Flo.
Compliments
Ago
AgoMago is offline Find More Posts by AgoMago
Old Nov 13, 2013, 11:17 PM
Is it DS'able?
wr_mizzard's Avatar
United States, CA, Oakland
Joined Feb 2007
Nice!
Ever since the "Gentle Lady DS discussion" I've had it in the back of my mind that there was a place for the pursuit of built-up DS...
I like the design a lot flo... I wonder if there's a way to do a honeycomb structure and whether that would be any stronger than your structure or the traditional perpendicular structure?
-James
wr_mizzard is offline Find More Posts by wr_mizzard
Old Nov 14, 2013, 12:16 AM
In speed lies safety
Aerogance's Avatar
USA
Joined Sep 2008
Built-Up RE ds has been done successfully and is eye opening. I was recently thinking of building a DS-specific "woody" but now I don't have to because of the awesome LSD! Thank you for building it, I hope to see some DS video of it soon!
Aerogance is offline Find More Posts by Aerogance
Old Nov 14, 2013, 02:46 PM
the occasional flyer
rothlisburger's Avatar
Rexburg, ID
Joined Jul 2008
I want to see a failure by shredded covering.
-David
rothlisburger is offline Find More Posts by rothlisburger
Old Dec 14, 2013, 12:08 PM
AgoMago's Avatar
Joined Nov 2004
Compliments
Ago
Ok no plans....!
A question to Flo:
How do you design geodetic structure.
Is there a method or a program or simply you use a cad program and do all the work involved?
Anyway Very nice looking wing Flo
Thanks to share it.
Ago
Old Dec 14, 2013, 12:45 PM
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi AGO,
sorry no files availible..
as for designing.
First design the "Hull" and then create ribbs by "slicing". Adding spars and tubes.. done
greets
flo
Old Dec 17, 2013, 12:11 PM
AgoMago's Avatar
Joined Nov 2004
Originally Posted by flo View Post
Hi AGO,
as for designing.
greets
flo
OK Flo
I understand the method used for the design now..
Thanks for the answer
Ago
Mini-HowTo U/C designs.. Removable and simple Under carriage systems, lightweight etc davereap Beginner Training Area (Aircraft-Electric) 39 Nov 04, 2013 03:35 AM
Discussion NiMh LSD batteries treated as Lipo Mr_westie HobbyKing 2 Oct 12, 2013 08:41 PM
Discussion HobbyKing LSD AA cells after 500 cycles. jj604 Batteries and Chargers 4 May 12, 2013 09:35 PM
Discussion Lightweight twin - need a design ChickenStick Foamies (Scratchbuilt) 1 Dec 26, 2007 07:47 PM
Help! new project, must be lightweight. i need help in designing an edf Zippiot Electric Ducted Fan Jet Talk 23 Feb 25, 2006 08:20 PM
