Old Dec 21, 2014, 02:07 PM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Wing and fuselage joined, also Aileron stiffened.
vincent123 is offline Find More Posts by vincent123
Old Dec 22, 2014, 02:11 PM
iron eagle is offline
Find More Posts by iron eagle
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Lot of room in the fuselage for the battery. The control surfaces should suffice as long as you keep the speed down.
iron eagle is offline Find More Posts by iron eagle
Old Dec 30, 2014, 04:50 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Finished product, ready for maiden!
Winglets screwed on to the wing tip, to change them if test requires...
Old Dec 30, 2014, 10:43 AM
iron eagle's Avatar
Joined Jul 2007
Good luck with the maiden.
Old Dec 30, 2014, 03:22 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Thx
Old Jan 01, 2015, 02:32 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Victory !
Maiden of the prototype went well, no problem whatsoever, settings were spot on.
Ready for the real thing, but this will take much longer to build ... :-)
Vincent
FZ5 PART1: all wood ducted fan flying wing (3 min 3 sec)
Old Jan 01, 2015, 02:42 PM
Subsonic Mike is offline
Find More Posts by Subsonic Mike
Doing things differently
Subsonic Mike's Avatar
UK, England
Joined Sep 2009
Woop!
Great to see a successful maiden!
Also good to see you still have all your fingers....
I always feel a bit scared launching a pusher with an overarm launch.
Anyway, rest not you have the full size to make!
Michael
Subsonic Mike is offline Find More Posts by Subsonic Mike
Old Jan 01, 2015, 04:43 PM
iron eagle's Avatar
Joined Jul 2007
It looks like a winning design.
Old Jan 02, 2015, 03:10 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Looks ok.
Gonna fly around some more, to see if it has overall good tendancies ..
Old Mar 10, 2015, 02:15 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Considering laser cutting !
To reduce building time, considering for a first time to sent it out to a laser cutting service ..
Vincent
Old Mar 11, 2015, 04:59 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Congratulations on the test model. Fast and clearly stable. A little twitchy on the controls but that's due to how you set up the controls. Slightly smaller control surfaces and a little less throw on the final version would make it smoother and faster if that is the goal. Snappy handling can be fun but it generates a lot of drag on the airframe. If speed is the goal then smaller surfaces make for smoother handling. And smaller surfaces, if they are still stiff enough, reduces the chance of control surface flutter.
It did seem to get into a sort of stall and drop suddenly at the end of the flight. Perhaps play around with the slow speed flying more to get a better feel for the handling. Especially if that's the same wing and airfoil you're going to use for the ducted fan version.
BMatthews is offline Find More Posts by BMatthews
Old Mar 12, 2015, 12:05 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Hi there, good analysis, y r on top of It!
Discussion How well would this canardish jet perform? (just design phase right now) GreenAce92 Foamies (Scratchbuilt) 5 Jan 16, 2009 07:14 AM
More shots with the Depron Dragon and Panasonic DMC-FZ5 CactusJackSlade Aerial Photography 7 Jun 12, 2005 12:46 PM
Yippee! Depron Dragon w/Panasonic DMC-FZ5 - maiden photos CactusJackSlade Aerial Photography 11 Jun 11, 2005 09:37 PM
Depron Dragon's new Panasonic DMC-FZ5 camera set-up - maiden this evening?! CactusJackSlade Aerial Photography 1 Jun 11, 2005 12:30 AM
New A/P Plane - Initial Design Phase Buzz_Man Aerial Photography 4 Apr 21, 2005 12:33 AM
