Old Jan 13, 2013, 05:21 PM
AirplaneFreak100 is offline
Find More Posts by AirplaneFreak100
as the name says!
AirplaneFreak100's Avatar
Barbados
Joined Sep 2012
oh and is the spark constant or only at startup thanks for the help dar
AirplaneFreak100 is offline Find More Posts by AirplaneFreak100
Old Jan 14, 2013, 01:46 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Originally Posted by AirplaneFreak100 View Post
Oh and by the way, in question #2 I meant the ignition system...
Oh and is the spark constant or only at startup thanks for the help Dar.
AF,
A spark-ignition engine need the compressed air-fuel mixture in the cylinder (combustion chamber) ignited by a spark, in each and every complete cycle of the engine.
...So, obviously, if you disconnect the battery (or the whole ignition system) from the spark-plug, the engine will cease to run...
In a glow engine, you only heat the glow-plug's coil with a battery for starting.
After it is running, the platinum coil remains glowing hot, due to catalytic reaction of the platinum on the methanol in glow fuel.
See this video to understand how hot platinum becomes, just from spraying methanol on it and without any power being provided...
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 14, 2013, 02:52 PM
as the name says!
Barbados
Joined Sep 2012
Thanks alot
Old Jan 14, 2013, 03:05 PM
as the name says!
Barbados
Joined Sep 2012
If i have any more questions i will ask here. Is that ok?
Old Feb 01, 2013, 07:28 PM
as the name says!
Barbados
Joined Sep 2012
ANOTHER QUES
for a gas engine lets say 15cc would 2 cycle oil like the one i use for the wacker be good?
Old Feb 01, 2013, 07:35 PM
Machzx is offline
Find More Posts by Machzx
Joined Nov 2012
Yes it will be fine
There are alot of opinions on oil !
But that will work just fine
Be ready for the deluge of info to come on oil though
Machzx is offline Find More Posts by Machzx
Old Feb 01, 2013, 07:39 PM
as the name says!
Barbados
Joined Sep 2012
Ok:d thanks then that question is answered well that means that when i get to gas engines i don't have to order from online i can just go to the local hardware store for some 2 cycle oil. OK. Thanks
Also when they say oil ratio is the bigger number the oil?
Old Feb 01, 2013, 11:52 PM
DarZeelon's Avatar
Joined Nov 2003
AF,
Just take note; some smaller gas engines do not have a needle bearing con-rod, or a ringed piston...
Engines that don't cannot survive if run on 50:1 gas-oil mix; they need a 20:1 to 25:1 mix.
In this respect, do what the manufacturer says.
Old Feb 02, 2013, 10:13 PM
as the name says!
Barbados
Joined Sep 2012
Ok thanks....will be edited
Discussion New Similar gasoline engine with DA60/ DLE55--EME55-II joyanan Engines 0 Mar 14, 2012 10:22 PM
Sold SPE 40cc Gasoline Engine w/Pitts Muffler NIB b-gosh-prophead Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 12, 2012 10:10 PM
For Sale Gasoline Engine LCD Hour Meter spookyeng Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 28, 2012 01:03 PM
