Old Aug 13, 2012, 12:39 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Question
Servos: Long Leads cause interference?
I am building a 98" Dragon express. I really don't like using long linkages and bellcranks for the ailerons as shown on the plans. I would like to mount a servo near the aileron with a simple short link. I did this on a large DC-6 and I have not had any problems so far.
In the instructions it says not to do this because the long servo leads may pick up interference from the power systems. These instructions were written in the days of brushed motors when brush-less were fairly new. I will be running some brush-less 480 size motors with 20 amp ESC's for each motor.
Is interference really a concern on this setup?
Dave
payne9999 is offline Find More Posts by payne9999
Old Aug 13, 2012, 05:31 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
From experience my suggestion is to do what is called the Poor Mans Choke. The article was written in the AMA mag like 20 yrs ago. Simply tie a square knot close to the Rx, yup a one loop knot. I used the tried and not so trustworthy Electron 6 on a 9C FM in a mini Helli, until I read the mag I had probs out the ying yang. Tied a knot on each servo lead and viola man. Of course I use Spectrum X now and don't worry about a thing. Some of the large scale guys use a match box that supplies the power off another supply etc. Longer wires and or heavier use think about HV servos and such.
ApexAero is offline Find More Posts by ApexAero
Old Aug 14, 2012, 03:31 AM
Magne is offline
Find More Posts by Magne
Moss, Norway
Joined Jul 2003
Dave,
Are you using a 2.4 GHz radio system?
If so, don't worry, case closed.
If you are using a 72 MHz system, (35 MHz for us Europeans) then concerns/warnings etc. written 20 years ago still apply.
Regards,
Magne
Magne is offline Find More Posts by Magne
Old Aug 14, 2012, 03:44 AM
Boomerang1 is offline
Find More Posts by Boomerang1
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
I have a 110 inch B-36 with long leads out to the aileron servos .
It uses brushed 400 size motors & flys on a 36 Mhz system.
It's about 15 years old & I haven't had any problems yet! - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Aug 14, 2012, 04:11 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
For long extension leads, I prefer to buy (or make), the ones with twisted wires, not the flat three wire strip. The 'twisted pair' principle, ( only a triple).
eflightray is offline Find More Posts by eflightray
Old Aug 14, 2012, 12:08 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Thanks everyone.
I am using 2.4 gig Spektrum equipment and I didn't think it would be a problem but I saw the warning in the instructions. It probably was pre-2.4 gig information.
Dave
Old Aug 15, 2012, 08:48 PM
barracudahockey is offline
Find More Posts by barracudahockey
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
The twisted pair prinicpal only applies when there's pairs.
Twisting servo wire has no benefit, and just makes the actual wire run longer.
barracudahockey is offline Find More Posts by barracudahockey
Old Aug 16, 2012, 05:14 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
But pairs of what ?.
There is a +ive, -ive, and a signal wire in the twist, are you saying only two signal wires benefit from the 'twisted pair' ?.
Old Aug 16, 2012, 06:37 AM
Joined Sep 2004
Thats what I'm saying. More precisely, multiple pairs. Twisting the pairs prevents cross talk from adjacent pairs.
If you were to cut the sheath off a Cat 5 network cable and carefully examined it you would notice that each of the 4 pairs is twisted at a different rate of twists per inch so that the fields around each pair are not in phase. (simplified explanation)
Sold 2 Parkzone SV80 Long Lead Servo wolfcbr2003 Aircraft - General - Radio Equipment (FS/W) 0 Jul 28, 2012 12:23 AM
Sold (x2) SV80 Long Lead 3-wire servos - [PKZ1081] davidjrojas Aircraft - General - Radio Equipment (FS/W) 0 Jul 24, 2012 02:37 PM
Found PZ SV80 Long Lead Servos kellymacdaddio Aircraft - General - Radio Equipment (FS/W) 0 May 03, 2012 09:32 PM
Sold Two Parkzone DSV130M servos, Two Electrifly long lead ES50 Nano servos kobkobico Aircraft - General - Radio Equipment (FS/W) 0 Jun 15, 2011 03:54 PM
