Old Apr 12, 2011, 11:31 AM
elvill is online now
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
MCX Tank Buster - A10 Tuffoam Conversion
Picked up a batch of mcxs from ebayhobbemart, good news 4 out of 5 bricks function perfect and saw this auction full of Tank Busters so I had to have em!
Good News: A10 is a super easy conversion, save maybe 8 grams from stock, keep cg and plane flies very nice with mcx brick.
Bad News: Diff thrust turning is on throttle stick, which kinda messes with throttle when turning, how do I switch diff thrust to right stick on my dx7?
Here are some picks, flies better then stock with weight savings, I use 180 Hyperions, still wont loop or roll but nice climb and decent control 2ch way up high
elvill is online now Find More Posts by elvill
Old Apr 12, 2011, 09:32 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That P-38 should be 2S, so it may need more than just a brick to fly it.
For the A-10, you should run an Elevator Pushrod back from the brick. It would only add about 3g to have a working elevator.
To Move the Differential thrust to the right stick, You need to mix Rudder > Rudder -100%/-100%. This will kill the left stick input.
Mix Aileron>Rudder 100%/100% to get the right stick to control differential thrust.
UNGN is offline Find More Posts by UNGN
Old Apr 12, 2011, 11:02 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very nice
How does the VRC fly on champ brick?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Apr 13, 2011, 12:09 AM
Eugene, Oregon
Joined Apr 2009
Thanks for mix UNGN knew youd have it, with all your tx help I finally feel its worth having dx7
Old Apr 13, 2011, 12:16 AM
Eugene, Oregon
Joined Apr 2009
Originally Posted by Razors edge 29 View Post
Very nice
doesn't fly as well as the original unmodded itc starscream (shout out to Lee) wont turn as sharp or glide as well. think its couple grams nose heavy - champ brick seems underpowered thinking on switching out with 6400. BL vrc might be fun but smallish airframe
Old Apr 13, 2011, 06:01 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Yeah BL would be neat - I think they might be a bit heavy for size though.
Old Apr 13, 2011, 06:05 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
also remember that with the rudder mixed to ailerons, the servo will move along with the diff thrust.
derk is offline Find More Posts by derk
Old Apr 13, 2011, 06:42 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What Servo?
Old Apr 13, 2011, 07:32 AM
derk is offline
derk's Avatar
Joined Dec 2003
What Servo?
well, i guess i should have looked a little closer at the pictures haha
though you can still make it run actuators
Old Apr 13, 2011, 09:09 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
So this isn't the airhoggs a-10 ?
Edit
Also when you guys do these little direct drive conversions/scratch builds; if you use GWS prop which length/pitch do you use?
3020 or smaller?
Old Apr 13, 2011, 12:01 PM
Eugene, Oregon
Joined Apr 2009
this is not the airhogs A10, it is the rarely seen Guillows Tuffoam A10, little smaller very lite airframe. for sale random online hobby shops and HorizonHobby (though way to expensive @ 59$ for crappy 2ch) you want excellent 2ch go ITC on convert to dsm2
I use the Tri-Turboprop ala Plantraco, commonsencerc not sure which gws is comparable to the TT prop but it works very well if not a little fragile
Old Apr 13, 2011, 12:07 PM
Eugene, Oregon
Joined Apr 2009
so if I add elevator mod and use UNGN mix (remove the aileron servo for weight savings) everything should work yes? for diffthrust and elevator
elevator is exactly what this plane needs - it noses up porpoises way too much - need either bigger 1s lipo for weight or throttle+down ele mix
Old Apr 13, 2011, 01:43 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Cool thanks
The
Discussion WW2 Tank Buster - some thoughts (and maybe actions) Pat Lynch Scale Kit/Scratch Built 206 Dec 10, 2007 12:09 PM
Build Log Tank Buster - a WWII warrior chara Foamies (Scratchbuilt) 58 Jul 25, 2007 04:11 PM
Discussion Depron A-10 Tank Buster gooseman Foamy EDFs 9 Nov 13, 2006 11:00 AM
