Old Mar 17, 2011, 05:33 PM
jabull is offline
Find More Posts by jabull
jabull's Avatar
United States, ID, Boise
Joined Dec 2010
11T vs. 13T Pinion gear?
Can someone share pros and cons or experience in the difference between 11T and 13T pinion gears on a 450 class heli?
thanks
jabull is offline Find More Posts by jabull
Old Mar 17, 2011, 05:54 PM
RC_Marine is offline
Find More Posts by RC_Marine
Semper Fly!
RC_Marine's Avatar
Joined Dec 2010
there is no pro's and cons when comparing pinions, its all depends on what motor you are running and how much headspeed you want. but to try and asnwer your question: typically the 13t will yeild more headspeed but draw more amps, while a 11t would be the opposite.
RC_Marine is offline Find More Posts by RC_Marine
Old Mar 17, 2011, 11:55 PM
jabull is offline
jabull's Avatar
Joined Dec 2010
ok, so based on that... learning to hover and longer battery time would have me running an 11T i think?
Old Mar 18, 2011, 12:10 AM
Semper Fly!
RC_Marine's Avatar
Joined Dec 2010
yes a smaller pinion is ideal for longer run times and the lower headspeed will make the heli more tame for learning to hover, it's still a good idea to use a headspeed calculator to determine the final headspeed with that pinion based on the motor you plan on using. to low of a headspeed can make the heli unstable.
Here is the headspeed calculator I use:
http://www.readyheli.com/headspeed-calculator.html
Old Mar 18, 2011, 08:24 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
It's a balancing act, just like anything else. I'm running a lower headspeed and a lower Kv motor on my 450 cause it's for scale flight. I've got a bit higher headspeed on my 600e since I do fast forward flight and basic aerobatics. Balance between amps, pinion gear, motor Kv, and headspeed.
Mike_Then is offline Find More Posts by Mike_Then
Old Mar 19, 2011, 11:24 AM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
It matters what KV your motor is rated at.....A 13 Tooth would run better on a 3500KV and an 11 Tooth would run better on a 3700KV....There are a lot of other factors to look at too like blade length....
skizziks is offline Find More Posts by skizziks
Old Jun 07, 2015, 09:53 PM
ronheadrick is offline
Find More Posts by ronheadrick
Joined Feb 2013
I have bought the 460mx brushless @ 1800kv I want to put it on an align 450 fbl clone what size pinion would you use 11 or 13 I have a slow to medium head speed or something different
ronheadrick is offline Find More Posts by ronheadrick
Old Jun 07, 2015, 10:54 PM
crasher47 is offline
Find More Posts by crasher47
Joined Mar 2013
When I was first learning to fly (crash) CP, I flew a HK 450GT with an NTM Rotor Drive 450 3400KV with a 12 tooth pinion. Hovered nicely at 1/2 throttle with about 6 degrees of pitch. I tached the head speed at I believe 1900 RPM tied down so I imagine around 2200 RPM unloaded (wild guess).
crasher47 is offline Find More Posts by crasher47
Old Jun 07, 2015, 11:13 PM
spykez is online now
Find More Posts by spykez
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
http://heli.dacsa.net/calcv3/Default.aspx
spykez is online now Find More Posts by spykez
Old Jun 07, 2015, 11:50 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
So I hope you are planning to run a 6s battery?
That motor is very low Kv designed to run off a 6s battery, you would be lucky to get off the ground on a 3s.
For the pinion... that would depend on what version of the 450 you had. Some use 150t main gear and some use 121t. As a typical starting point the 11t pinion would normally be used with the 121t main and the 13t with the 150t .
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jun 08, 2015, 03:29 AM
Joined Mar 2013
Thats what I was thinking. The KV is too low. A friend of mine in trying to order the same 3400KV motor I had erroneously ordered the 1800KV version...to slow. He was flying the same HK450GT that I had. 150 tooth main gear and 3S battery.
Sold E-Flite 3,900kv Motor w/ NIP 11T Pinion & 8 Amp ESC w/ Deans, $35 Combo, $20 Each lazor 22 Aircraft - Electric - Power Systems (FS/W) 2 Nov 14, 2010 01:09 PM
Discussion 10T or 13T pinion? raptor0028 Electric Heli Talk 3 Oct 04, 2010 09:57 AM
Wanted 11T pinion, 3.17mm shaft, for 450 clone heli Jeffery Aircraft - Electric - Helis (FS/W) 3 Sep 01, 2010 04:57 PM
Wanted Align 3.17mm 11T Pinion to buy or will trade for 13T ncpiperpilot Aircraft - Electric - Helis (FS/W) 0 Jun 05, 2007 01:10 PM
Discussion 11t vs 13t vs 15t ktmrider Mini Helis 6 May 21, 2007 07:18 AM
