Old Oct 14, 2008, 01:59 PM
Kildare, Ireland
Joined Jul 2008
What are the most common causes of FPV failure?
I noticed quite a few of you have suffered major crashes/MIAs over the course of your FPV careers... What are the most common causes of failure? How likely are solder joints/ plugs to shake them selves loose over time? Are RC components robubust- or are they prone to failure? What is the typical major disaster/successful flight ratio?
pajo1981 is offline Find More Posts by pajo1981
Old Oct 14, 2008, 02:53 PM
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Pilot error:
Flyiing out of range.
Flying with batteries that are not fully charged.
Flying with new equipment (i.e. during functional check flight)
FWIW, I've been keeping a spreadsheet of everything I've been doing in this hobby. I can't remember the exact number of landings off the top of my head. But, I had nearly 900 landings, of which 19 were "hard" requiring some sort of fix.
I lost 1 Easystar into a river flying out of RC range about a month into flying FPV.
The only thing that's come loose in flight causing a crash was a push rod.
I'm on my second one (BWEZ) which has been going strong for nearly two years.
I'll do some analysis on my data tomorrow and report back.
Hope that helps...
scrtsqrl is offline Find More Posts by scrtsqrl
Old Oct 14, 2008, 05:50 PM
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Connector shaking loose for video equipment on the plane.
Batteries not fully charged.
CG not fully checked when switching out different brands of battery packs, you find out real fast.
Driving to exciting new places to view it from the air, too excited to realize that you took off without planning how you are getting down...
Yeah, I've been there.
-Chris
Blaze.45 is offline Find More Posts by Blaze.45
Old Oct 14, 2008, 07:21 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
My mistakes.....So far...
1. Not using a separate BEC to power servos, control Rx, and gyros, etc...
Result,
BEC thermal shutdown, causing complete loss of control of the aircraft, straight down from 500 ft.
Solution, use a good separate BEC or fully charged flight pack.
2. Forgetting to do a control surface check before take off...
Result,
No aileron control (plugged in backwards) managed to land ok with rudder.
Solution, Look at check list dummy! (you DO have a check list, don't you?)
galaxiex is offline Find More Posts by galaxiex
Old Oct 14, 2008, 07:45 PM
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I'm concerned this thread could lead to a list of reasons why FPV is unsafe. I just recently lost my plane and I thin you referenced my thread. However, let's remember that crashes can happen with any RC craft and most of us fly in unpopulated areas.
BTW. Mine was either due to out of range or tx battery drain.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Oct 14, 2008, 07:58 PM
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
As someone who hasent tried FPV (yet) from what Ive been reading there arent any more crashes/losses that any other aspect of modeling.
I would say with FPV style flying the first few flights would be best tried with your video equipment on and flying as you normally would, or at least have a spotter and try to stay in sight.
Once things are tested/proven then its really up to the individual.
Typical operator error things like the others have mentioned happen, doesent matter if its FPV or not.
The modern RC setup can be pretty darn reliable when its setup right.
I lost sight of a glider once in a thermal, It was a real good hands off flyer so I just stood there for a while, someone else eventually found it in a field several miles away, not a scratch on it. I had my name on it so they contacted me.
In that case I think an FPV setup would have been real handy......
Adam Neat is offline Find More Posts by Adam Neat
Idea Out of curiousity, what are the most extreme of religious denominations? Accu157 Life, The Universe, and Politics 15 Nov 09, 2006 02:40 PM
Discussion Clearview: What are the most realistic models? jweaver100 Simulators 10 Feb 03, 2006 03:05 PM
POLL: What are the most common reasons to crash a plane Patrick Plawner Electric Plane Talk 139 Oct 06, 2005 08:00 AM
Non-Poll: What are the most common reasons to crash a plane? James Frolik Electric Plane Talk 8 Jan 22, 2005 02:56 PM
What are the most efficient Battery connectors? jmiceli11 Electric Plane Talk 9 Nov 14, 2004 11:46 AM
