Old Jun 13, 2013, 01:38 AM
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Build Log
Composite ARF YAK-55SP 2.1m (continue)
http://www.rcgroups.com/forums/showt...1367033&page=5
(continue of the above link)
Anyways guys, I finished the aircraft a while back but never finished this thread.
The plane flew great and was a lot of fun, to tell you the truth I ended up selling it due to needing $$$$ for a new project and some time after I missed flying it + some $$$$ came up and I ended building another one (I like it that much).
super kupfer is online now Find More Posts by super kupfer
Old Jun 13, 2013, 01:42 AM
Joined Jan 2010
With this aircraft I decided to attach the canopy according to instructions,the reason I didnt go with the latch and locating pin system as with the first build is due to it not working as well as I expected.
Old Jun 13, 2013, 01:49 AM
Joined Jan 2010
Main landing wheel
Old Jun 13, 2013, 01:51 AM
Joined Jan 2010
Ignition install
Old Jun 13, 2013, 01:57 AM
Joined Jan 2010
Engine install
Old Jun 13, 2013, 02:05 AM
Joined Jan 2010
Fuel system install.
Old Jun 13, 2013, 02:11 AM
Joined Jan 2010
Inside the fuse (not using a smoke system on this one......trying to keep it light).
Only thing left is the ignition/RX batteries + hook up the pull pull rudder system to rudder servo.
Old Jun 13, 2013, 02:18 AM
Joined Jan 2010
Excited and happy as I am.
Old Jul 11, 2013, 08:02 PM
Joined Jan 2010
Battery placements.
Old Jul 23, 2013, 09:55 PM
Joined Jan 2010
RUD & ELE setup (used Sccraft for rud & Traxxas rods for ele & ail, worked great).
Old Sep 03, 2013, 01:14 AM
Joined Jan 2010
In order to install the pipe header I had to use a set screw and a nut on one of the mounting points (used loctite as well).
Old Sep 03, 2013, 01:16 AM
Joined Jan 2010
Mounting the pipe/canister.
Old Oct 22, 2013, 06:48 PM
Joined Jan 2010
All together, still needs paint or graphics.
Old Jul 23, 2014, 08:22 PM
Joined Jan 2010
Canopy len on.
Build Log Composite ARF YAK-55SP 2.1m super kupfer Competition Aerobatics 72 Jul 24, 2013 10:42 AM
For Sale Comp-ARF Yak-55SP 2.1m (Parts) super kupfer Aircraft - Fuel - Airplanes (FS/W) 1 Jan 17, 2013 10:02 PM
For Sale Comp-ARF Yak-55SP 2.1m (Parts) super kupfer Aircraft - General - Miscellaneous (FS/W) 1 Jan 17, 2013 10:00 PM
Sold Comp-ARF Yak-55SP 2.1m (Parts) super kupfer Aircraft - General - Miscellaneous (FS/W) 0 Dec 01, 2011 02:00 AM
Sold Comp-ARF Yak-55SP 2.1m (Parts) super kupfer Aircraft - Fuel - Airplanes (FS/W) 1 Nov 16, 2011 01:42 AM
