Old May 07, 2013, 03:56 PM
Joined Mar 2013
Since I have to use the backlight (or you can see the output) couldn't I run it off the BEC? seeing how I already have one?
sagz is offline Find More Posts by sagz
Old May 07, 2013, 04:19 PM
Aberdeen, Scotland, UK
Joined Dec 2007
Yes.......so run the LCD off the BEC and the Arduino direct from the Lipo.
Ian.
IanJ is offline Find More Posts by IanJ
Old Dec 29, 2013, 06:59 PM
Joined Dec 2007
Hi all,
Been a long time since I visited this thread............is anyone using this system?
Ian.
Old Dec 29, 2013, 09:00 PM
Joined Jun 2012
Hi Ian.
I've been wanting to build this for a while and have all but the USB Host board ready to go. I've finally figured out I should get this up and running, and learn some decent Arduino programming before trying to implement any other ideas I've been having.
Thanks for sharing your design, it seems the best way for a novice to get up and running.
Justin in NZ.
RevDWC is online now Find More Posts by RevDWC
Old Dec 30, 2013, 11:25 AM
Holon, Israel
Joined Apr 2009
$50 for 16MHz 8bit MegaADK or MEGA+USB Shield vs $25 168MHz 32bit STM32F4 only. Why to pay more?
Tahorg is offline Find More Posts by Tahorg
Old Jan 31, 2014, 01:01 AM
Joined Jan 2014
TX System
I am very new to RC flying.
Could someone suggest me a inexpensive TX System that will work with this setup.
rggovani is offline Find More Posts by rggovani
Old Jan 31, 2014, 06:34 AM
Fix it till its broke!
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
Originally Posted by IanJ View Post
Hi all,
Ian.
I'm using your v1 joystick software in my turnigy 9x transmitter to give me more channels via the trainer port so I can utilise all 16ch on my openlrs radio.
http://www.rcgroups.com/forums/showthread.php?t=2054642
It manages the 2 extra pots at the top, ps2 stick and my sliding flap switch.
Scotland!
geofrancis is online now Find More Posts by geofrancis
Old Jan 31, 2014, 04:47 PM
United States, ID
Joined Sep 2011
Originally Posted by tahorg View Post
$50 for 16mhz 8bit megaadk or mega+usb shield vs $25 168mhz 32bit stm32f4 only. Why to pay more?
++1
jakestew is offline Find More Posts by jakestew
Old Jan 31, 2014, 06:24 PM
Joined Jan 2014
FrSky FF-1 2.4Ghz
Google is your friend - http://www.webx.dk/rc/uhf-link3/how2purchase.htm
You can use any Tx system just as long as it conforms to standard Futaba type PPM stream, albeit I have only tested with Thomas's kit.
Ian.
Would This Work with this system?
FrSky FF-1 2.4Ghz Combo Pack for Futaba w/ Module & RX
http://www.hobbyking.com/hobbyking/s...Module_RX.html
Old May 21, 2014, 01:55 PM
starefly's Avatar
Toulouse (Fr)
Joined Sep 2008
Hello,
I'm very interested by what you have done, this is really a nice work, I think that I will give try.
Do you think that there is a huge work to modify the code to use a Xbox usb controller instead of the joystick that you have used ? I'm a newbie hobbyist programmer....
Tkx
starefly is offline Find More Posts by starefly
Old May 21, 2014, 02:09 PM
Joined Dec 2007
Originally Posted by starefly View Post
Hello,
Tkx
The library I use centres around the Joystick, so you'd have to fine a suitable replacement library for the Xbox controller then re-write the I/O to suit. A fair old job for a newbie.
Ian.
Old May 21, 2014, 03:06 PM
Joined Feb 2010
i also used your code for a hkt6a hobbyking radio you can use the stock rf module and receiver with the arduino board.
Old May 25, 2014, 05:49 AM
Norway, Hedmark, Brumunddal
Joined Aug 2012
Would some be willing to make a Box like this and sell it to me?
I'm looking for a better way to fly my camareship (a 1000mm hexa) and control the camera solo.
I would like to build a ground station with joystick control, and as I'm thinking right now it should be possible to control ele/rud/ail/thr with just the stick + throttle (up/Down/left/right/twist left/twist right and the a own throttle handle).
If the joystick that have a thumb stick on the top (like "misslecontroll" then all I need is that joystick and left hand can be used for other Things (or a second joystick for camera)
now I'm using a turnigy 9x Stock, and a er9x with upgraded hw board and all that
tormodnt is offline Find More Posts by tormodnt
Old May 25, 2014, 06:22 AM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Is it this project you want built or is a custom hardware er9x?
Im about to start byikding a diy er9x into a the casing of a 5 inch video screen fot my fpv use.
djdavies83 is offline Find More Posts by djdavies83
Old May 25, 2014, 12:03 PM
Joined Aug 2012
I've already designed the ground station and I have a fully modded er9x but what I want is a type of pc joysticks to control my multirotor instead of using my 9x.
As I see it, if I use one of the joysticks I've had fun with in the past I should along with a linear throttle stick have all the functions I use to control my hexa + gimbal with just the use og 1 hand + throttle
Discussion RC Radio Tx - Re-inventing the wheel! IanJ DIY Electronics 345 Mar 18, 2013 02:44 PM
Sold Immersion RC 600mW 5.8 TX Version 1 $50 shipped. nybeechpilot FPV Equipment (FS/W) 2 Jun 02, 2012 06:36 PM
Discussion Re inventing the internal combustion engine UlteriorModem Life, The Universe, and Politics 10 Apr 11, 2012 05:24 AM
Discussion Re-inventing the wheel philgib Blimps 5 May 25, 2006 06:42 PM
Wanted WTB AeroFly Professional Deluxe USB Interface Version RC Flight Simulator for futaba heliguy Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2005 02:21 PM
