Old May 16, 2013, 07:52 AM
Romania, IS, Iași
Joined May 2011
Tip : while falling great altitude I found that low throttle does help stabilize faster the quad rather than high rate throttle.
Can someone approx the height of the quad?
v929 (1 min 38 sec)
ccatalin is offline Find More Posts by ccatalin
Old Jun 09, 2013, 08:36 PM
Australia, SA, Adelaide
Joined Apr 2010
Help!
I fly my 929, 939 and 911 on a 9XR, and the 929 has suddenly decided to flick over backwards as soon as I start it up.
It does the same on the toy transmitter that came with it, so I gather it's not the 9XR.
The battery is in the right place, and everything appears attached correctly.
Chris
ChrisLevo is offline Find More Posts by ChrisLevo
Old Jun 09, 2013, 10:19 PM
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Originally Posted by ChrisLevo View Post
Help!
Chris
Did you change anything? That usually happens when someone replaces prop and accidentally got the wrong prop on the wrong arm. But if you haven't change a thing, then we'll have to figure out what the motors are doing. Could you share a video of how this is flicking over?
Heli Pad is online now Find More Posts by Heli Pad
Old Jun 10, 2013, 05:54 AM
Ain't crashing often anymore
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
929?
Perhaps one of the first 4 plug ones?
Then the gyro chip probably has contact problems in a pin. Was the weak spot of it.
Gently resolder/reflow solves the problem. (bring it to a computer shop/friend that has a hot air station for best results.)
here you'll find the chip location:
http://www.rcgroups.com/forums/showp...postcount=3152
DIY method:
http://www.rcgroups.com/forums/showp...postcount=2496
Or get a new PCB if you are unable to do so.
But first check prop orientation like HeliPad said if you have changed them before.
-mike-
mikefromgermany is online now Find More Posts by mikefromgermany
Old Jun 11, 2013, 03:45 AM
Joined Apr 2010
Thanks all,
It shows 23/06/2012 - problem?
I have another 929 on the way.
Cheers,
Chris
Old Jun 12, 2013, 06:26 PM
Joined Apr 2010
Here is the board.
Does that help, please?
Old Jun 13, 2013, 06:44 AM
Germany, Berlin
Joined Jun 2012
It is a first batch one.
So go ahead for the gyro chip. It is worth it!
The V1 boards are the sportiest by far of all following ones (and out of stock everywhere)
-mike-
Old Jun 19, 2013, 06:45 PM
Joined Apr 2010
I'm a complete moron!
It's my MQX that is acting up, and the 929 is fine.
Thanks for the suggestion - Chris
Old Jun 23, 2013, 06:37 PM
Joined Apr 2010
Good morning.
I use 3 cell balance charger leads for all of my batteries, but don't have a JST one for the 929.
Has anyone been able to find one, please?
I have looked on the auction sites, but no luck.
Cheers - Chris
Old Jun 24, 2013, 02:05 AM
Germany, Berlin
Joined Jun 2012
Make one yourself, and you are free to choose the cell count that suits your need best.
I made a 5 cell balance harness:
For a 3cell harness you'll need:
http://www.banggood.com/Balance-Char...m-p-77374.html
http://www.banggood.com/Wholesale-10...y-p-50810.html
together 3,70 USDshipped.
The following scheme should give you an idea for wiring.
If you need instructions/help with the wiring, PM.
If you can't do - I could make one and send it, but i don't know about the Aussie customs regulations.
-mike-
Old Jun 24, 2013, 06:51 AM
erdnuckel2's Avatar
Joined Mar 2009
Good morning.
Cheers - Chris
you could do like mike ( which is the more admirable way ) and build it yourself with the parts he mentions, ...
... or you do it like me and pay a tad more :
http://www.miracle-mart.com/store/in...oducts_id=9446
Latest blog entry: Why I L-O-V-E miracle mart ...
Old Jun 24, 2013, 05:06 PM
Joined Apr 2010
Thank you, both!
After reading both posts, I made a 6-way one with bits from damaged harnesses, and bought a 3-way one
Thanks again - Chris
Old Jun 24, 2013, 06:41 PM
Joined Apr 2010
I received a new 929 (you always should have a spare on hand) last night, and noticed some differences from my early model.
The helo and charger now have keyed shrouds over the DC connectors, so that the battery cannot be inserted reverse polarity.
Good thinking.
The transmitter looks a bit different, but I don't know whether it has changed from the original, as I use a 9XR, so can't compare.
I want to give one of the transmitters to my brother-in-law for his BNF 911, but want to keep the better one for myself for any emergencies
Anyone know whether the transmitters are different in any way?
Chris
Old Jul 21, 2013, 11:42 AM
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Good thinking.
Chris
Post a picture of them side by side so we can see the difference.
Hellysmack is offline Find More Posts by Hellysmack
Discussion WLToys WL-2019 Mini car wallaguest1 Micro Cars 51 Aug 25, 2014 10:57 AM
Discussion Rebranded NineEagles Solo Pro V2? (WLtoys V911) gettinglucky Coaxial Helicopters 1 Dec 26, 2011 01:06 AM
Discussion Keil Kraft ladybird tips anyone? tim hooper Vintage & Old-Timer Designs 101 Aug 27, 2009 03:02 PM
Discussion Ladybird Special imp.bob Vintage & Old-Timer Designs 4 Feb 03, 2008 10:08 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
