Old Apr 09, 2014, 01:24 PM
Calgary Alberta, Canada
Joined Feb 2008
DIY cat or tri
I am thinking about building a 1m or 1.5 m cat or tri just for fun, possibly using my IOM 1 (A) rig. One though was to use built in vacuum pipe for the hulls. It is thin walled and fairly light. My thought was to use heat gun to close off the bow then use the pipe glue to join it together. Then use heat again to give a bit of rocker.
I have built 7 RC boats out of fibre glass, balsa and so I know I can build. The question is more around if anyone else has tried using PVC pipe to build a RC boat and if so any tip?
Andrew
A.B. is offline Find More Posts by A.B.
Old Apr 09, 2014, 02:59 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Some of the UK guys transformed their 1 meter monohulls into trimarans and used the closed cellular foam but performance results were pretty poor. If you do a search, you can find free plans on the net. My design ("IMPULSE") was to allow building a tri - or a cat. Use two of the main hulls for a cat configuration, or use the main hull and two floats for a tri. Since the original prototype build, some have suggested a bit more buoyancy in the floats if building as a tri.
Dick
Dick L. is offline Find More Posts by Dick L.
Question DIY quad w/ 5A BL motors -- "propsaver" prop mount OK or NG? Gabe_BigApple Scratchbuilt Multirotors 3 Nov 09, 2013 10:26 AM
Sold Dead Cat Quad or Spider Quad RTF $200 pohlmeyr Aircraft - Electric - Multirotor (FS/W) 4 Oct 04, 2013 05:59 AM
Discussion Who has tried both the NAZA and a DIY Arducopter or Multiwii? compuatic Multirotor Electronics 23 Oct 18, 2012 02:19 PM
Discussion Looking to either buy a kit or diy a tri/quad anthvxne Multirotor Talk 23 Oct 18, 2012 05:54 AM
Build Log The diy 29 inch sterlite cat...! DIYPRO Racing Boats - Electric 10 Aug 08, 2012 11:18 AM
