Old Aug 22, 2005, 07:33 PM
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Question for SammyB
I just bought the Het Warhawk and every thing is fine except for the piece that goes under the wing, It doesn't look right, What do you think?
Glenn WI
wellington53 is offline Find More Posts by wellington53
Old Aug 23, 2005, 01:49 PM
schoonerj's Avatar
Berne, NY
Joined Sep 2004
I am in the process of building the P-40 as well. I had the same question. It gets glued to the bottom of the wing. The narrow part should have a hole for the screw that will attach the wing.
I glued the wings together, and fit them to fuse, and then lined up the hole with the blind nut. Then glued it in place with epoxy. I had to add a little balsa to the front to get it to fit correctly. I ended up stripping off the covering, and then fiberglassing the plane anyway.
I am also going to add a peice over the belly pan to replicate the radiator flaps (Or vents??). I can take a couple of pictures when I get home. Thtat should explain it far better than I could.
schoonerj is offline Find More Posts by schoonerj
Old Aug 23, 2005, 02:58 PM
Glenn
Joined Jan 2004
Thanks schooneri, Thats just what I wanted to see, I've got loads of gws gearboxes and brushless e-flite stuff so I'm going to try and mount a geabox on a stick kind of thing.
Old Aug 24, 2005, 06:40 AM
schoonerj's Avatar
Berne, NY
Joined Sep 2004
Picture of P-40 Bottom
Here is a picture of the bottom of the wing.
Het-RC P-40 Wing Bottom
And a photo of the plane in progress. I am in the process of painting. I am going with US Army colors from pre WWII
Het-RC P-40
I still have not decided on a power setup yet.
I hope this helps!!
Old Aug 24, 2005, 08:31 AM
Glenn
Joined Jan 2004
Thanks for the pictures, This is exactly the same stage as mine schooneri. I made a firewall to take a colbri motor mount for the GWS gearbox, this meant removing the tray, I still have to do some dremmeling but it's the easy way out for me being that I've got loads of GWS and E-flite gear, When the motor is mounted I'll post some pictures,
Glenn.
This is my last Tiger Moth question for the day! FlySilent Parkflyers 4 Sep 11, 2001 07:18 PM
A question for dave-lilley & others as well VaVol Electric Plane Talk 9 Aug 02, 2001 01:49 PM
Question for LS's prop motor gb 8x270mah experts jas_Qfix Parkflyers 13 Jul 24, 2001 12:17 AM
A question for Open Discussion Forum readers Greg Covey Electric Plane Talk 26 Jul 12, 2001 08:25 AM
Voyager people with brushless setup: question for you: jhudak7 Electric Heli Talk 1 Apr 23, 2001 09:03 AM
