Old Aug 08, 2012, 09:59 AM
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Changing radio pots for two position switches
Hello
I was wondering if I could take an old radio, remove the pots on steering and throttle and solder in two way toggle switches, and then have the functionality of a two way switch on that channel, as if the switch had been there all along, like the gear switch? Would this also work vise versa, putting pots on what used to be toggle switches?
Thanks, Zane
zanek is offline Find More Posts by zanek
Old Aug 08, 2012, 12:48 PM
Romania, Dolj, Craiova
Joined Sep 2007
Switch instead pot works, requires two resistors, viceversa not, you can't replace a switch with a pot without making this thing known to radio firmware.
renatoa is online now Find More Posts by renatoa
Old Aug 08, 2012, 02:05 PM
Agressive driver
Joined Jun 2011
Okay. What size resistors do I need and where do i put them?
Old Aug 08, 2012, 02:20 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Do you want it to work like gear switch with servo going full travel?
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 08, 2012, 02:24 PM
Agressive driver
Joined Jun 2011
Yes. So if I understand correctly, pots are essentially variable resistors? So to go full travel I would use a resistor that is equal to the max. ohm value of my pot? and less for less travel?
And I just put the resistor between the switch and each of the wires going to the TX?
Thanks, Zane
Old Aug 08, 2012, 02:36 PM
Joined Sep 2007
if you want full travel, then you must replace the pot with a single resistor of same value, usually 5-10k, and the switch will be connected as follows: the two fixed contacts at the resistor ends, and the bouncing contact instead pot cursor.
If you want adjustable range, it's a more complicate play of values.
Old Aug 08, 2012, 02:45 PM
Agressive driver
Joined Jun 2011
Okay. Thanks for your help.
Old Aug 08, 2012, 03:02 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The pot acts as a voltage divider. The setup varies from one transmitter to another, but lets assume the pot is 5K ohms and has 6 volts across it (one end is grounded, the other connected to +6v regulated). With the wiper in the middle it will see 3v. At one end of travel it might see 2v and at the other end 4v (since the pot is often 270 degree travel but the stick assembly limits it to perhaps 30 degrees each way).
In this case, one could replace the variable resistor with three fixed 1.6K resistors in series (adding up to roughly 5K). With 6v across the resistors, you will get 2v at one junction and 4v at the other. That would give full servo travel in each direction, depending on which you picked. You set up the switch accordingly.
That's the general principle. If you give specifics about the transmitter, someone can probably give you some guidance on actual values and the best way to do it. The numbers above are just for illustration.
EDIT: Those numbers will obviously give too much servo travel if the pots are 270 degrees.
Old Aug 08, 2012, 03:24 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Could you explain a bit further and reconcile with (or correct) the explanation I gave, please.
Old Aug 08, 2012, 03:28 PM
Agressive driver
Joined Jun 2011
I totally understand now. Thanks for the explanation
Old Aug 08, 2012, 04:09 PM
United Kingdom, Slough
Joined Aug 2003
With JR sets, a 2 position switch will go from 0V to 5V as they use 5V for most of the electronics. You can use a 3 position switch to replace a pot to give minimum, centre and maximum.
theaton56 is offline Find More Posts by theaton56
Old Aug 09, 2012, 12:22 AM
Joined Sep 2007
There is nothing wrong in your post, nothing to correct.
What I proposed is in the first schematic below, and is based on fact that usually, RC (stick) pots are not 270 degrees, they are special build with even less than 90 degrees movement.
What you proposed is in the second schematic and is correct as well, depends on pot type, if it rotates the full resistor range or only partial.
LE: and in the 3rd, the three position switch version, described by theaton
Old Aug 09, 2012, 05:48 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thanks. In the end, of course, there's going to be some trial and error if one cares about the precise output values (as opposed to having just high and low output to trigger a switch in the model, say). So one would probably use a couple of variable resistors to fine tune the setup.
Discussion Changing radio pots for two position switches zanek DIY Electronics 3 Sep 04, 2012 03:27 AM
Mini-HowTo Turnigy 9x v2 standard firmware, mode switch 3 position switch for dji naza gps :) stein3247 Multirotor Electronics 3 Jul 20, 2012 04:23 AM
Discussion Changing Two Position Switch to Turnable Dial Grips Radios 5 Mar 28, 2012 10:11 AM
Question Changing a rotary pot for a switch Frank Hurd Radios 2 Mar 13, 2012 08:16 AM
Discussion Changing toggle switches to Pots on radio? ziomatrixacs DIY Electronics 5 May 16, 2010 10:12 AM
