Old Jun 14, 2012, 07:43 PM
PMB-NZ's Avatar
Wellington, New Zealand
Joined Aug 2009
I have used the LS20031 which is in the same series. It's safest to use a level converter but the TX on the GPS can directly drive the RX on the arduino CPU. You should put a voltage divider (2 resistors) between the Arduino TX and the GPS RX to reduce the maximum voltage it sees from the arduino. The LS20031 needs 3.3V supply, which is why I haven't flown it yet. I used the Arduino serial monitor to send the commands to the GPS to set it up.
Paul
PMB-NZ is offline Find More Posts by PMB-NZ
Old Jun 14, 2012, 09:17 PM
United States, ID, Fruitland
Joined Apr 2008
I used the LS20031 as well and posted a few board designs.
Page 57 of this thread has the schematic and board layout for using an Arduino Pro Mini without the LM1881.
Page 61 of this thread has the schematic for an Arduino Pro Mini using the LM1881.
Page 65 has the third board layout I made which is smaller than the previous two.
All three boards use a logic level converter from SparkFun.com to allow your Arduino running at 5v communicate with your GPS running on 3.3v
You'll also need a 3.3v Regulator and an LM1881.
The full (hand drawn) schematics for the boards are in the posts listed above as well as board layouts that can be printed onto overhead transparencies for etching your board.
If you have any questions about any of it, let me know.
vasago17 is offline Find More Posts by vasago17
Old Jun 14, 2012, 11:16 PM
El_Nono's Avatar
Buenos Aires
Joined Jun 2008
Hello Friends
I did not like the characters make some changes so great. Since I was, I made some other changes.
Hope you like.
I'm still working.
El Nono
www.fpv-argentina.com
El_Nono is online now Find More Posts by El_Nono
Old Jun 15, 2012, 11:07 AM
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by El_Nono View Post
Hello Friends
Hope you like.
I'm still working.
El Nono
Looks very good, great work.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jun 15, 2012, 02:57 PM
ary
Argentina, CB, Córdoba
Joined May 2012
Thanks PMB-NZ and vasago17. I'll use a voltage divider.
5v Arduino 3.3v serial
GND ---------------- GND
RX ------------------ Tx
Tx ---1K8----3K3-- GND
.................Rx
ary is offline Find More Posts by ary
Old Jun 15, 2012, 02:59 PM
Just another user
Joined Feb 2011
--------- Rx
Just give it a shot with 3.3 volt and no further changes - I have used 3.3 volt logic devices with 5 volt Arduino without problems quite a few times.
Old Jun 15, 2012, 03:04 PM
ary
Joined May 2012
But... can I damage my GPS module? It works with 3.3 TTL. When Arduino writes in the TX it will write using logic at 5v. Is it a problem for my GPS?
Old Jun 15, 2012, 03:07 PM
Just another user
Joined Feb 2011
I doubt it, but I can't guarantee anything
You can use a simple voltage-divider if you like (perhaps that was what you tried to draw?)
Old Jun 15, 2012, 03:10 PM
Basel, Switzerland
Joined Mar 2008
it can be a problem. if you want to be minimalistic, you can add a resistor in series (1k or so, no important). the protection diode at the input, together with the resistor will bring the voltage down. voltage divider is fine too.
if you have several 3.3v devices, the atmega runs happily at 3.3v too, even at 16mhz.
dennis, can you uplaod your usart code?
quix-fz is offline Find More Posts by quix-fz
Old Jun 15, 2012, 03:12 PM
ary
Joined May 2012
yeap! Thanks Dennis
As I see you online, I wanna ask you how to remove the dark background in the prints. I'm using your code version 0.18
Old Jun 15, 2012, 03:15 PM
Basel, Switzerland
Joined Mar 2008
you can use a bigger resistor (the one from atmega directly to video, without diode), or remove it completely, or only remove it in software in the code.
i'm using 47ohm
Old Jun 15, 2012, 03:21 PM
ary
Joined May 2012
Arduino TX -->R1K--->Diode--->RXGPS
is it ok?
Old Jun 15, 2012, 03:22 PM
ary
Joined May 2012
is it ok?
Old Jun 15, 2012, 03:27 PM
Basel, Switzerland
Joined Mar 2008
is it ok?
hehe, i meant the protection diode inside the gps, you can leave that diode out. the resistor alone is enough
Old Jun 15, 2012, 03:35 PM
ary
Joined May 2012
Thanks quix-fz for your support!
And related to the dark background in the text... did you mean to use a bigger resistor at the output of the Arduino PIN11? Nowadays I'm using 120ohm.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
