Old Jan 31, 2003, 05:12 PM
James Calivar
Guest
n/a Posts
Interface connector for using my JR transmitter with FMS?
Greetings,
I'm a newbie slow-flight flyer (I've got a GWS electric rig I'm trying
to figure out how to fly reliably), and I'd like to bolster my flying
skills by using a PC-based simulator like FMS. Ideally I'd like to
use my actual transmitter (a JR 4-ch; can't remember the actual model
# but it has a buddy attachment). Now I've seen several companies
that offer cables that interface between the transmitters and the PC,
bundled with FMS, for around $50.00 or so, but I think I can get away
with cheaper than that since I've already got FMS downloaded, and all
I need is the cable. But I'm using Windows XP and there's apparantly
some kind of problem there?
Can anyone point me in the right direction? I have a decent
famliarity with electronics assembly, and could probably build my own
if I had a schematic. Alternatively, I would just buy one outright if
it was priced under, say, $20.00.
I appreciate anyon'e help!
James
P.S. Pray for calm weather this weekend!!
Marcin Romaszewicz
Guest
n/a Posts
Re: Interface connector for using my JR transmitter with FMS?
The FlyRC simulator has a wiring diagram that works for FMS as well.
This goes over the parallel port and works on any non Windows-NT based
system (will not work on NT, 2000, or XP).
Look here:
http://hem.passagen.se/rasmus-modell...eng_index.html
James Calivar wrote:
> Greetings,
> Thanks,
> James
Old Jan 31, 2003, 06:53 PM
Brokebob
Guest
n/a Posts
The FMS home page has a downloadable manual which includes the schematic you
need. It is the one I put together and it worked first time!
brokebob@aol.com (broke=not working, retired=not working, retired=broke)
Old Jan 31, 2003, 08:02 PM
James Calivar
Guest
n/a Posts
brokebob@aol.com (Brokebob) wrote in
news:20030131184318.04893.00000301@mb-cs.aol.com:
> schematic you need. It is the one I put together and it worked first
> time! brokebob@aol.com (broke=not working, retired=not working,
> retired=broke)
Ooops! I'll have a look at the manual then. Sorry to have wasted your
time.
James
Old Feb 01, 2003, 05:12 AM
Steve Lewin
Guest
n/a Posts
>> retired=broke)
>time.
Actually the circuits in the manual won't do you any good if you're
using Win XP. You will need the PIC based circuit which you already
have as it comes with FMS 2.07. Look in FMS/Doc/Interface. To build it
yourself you will need to be able to load a program into a PIC
microcontroller.
Steve
Old Feb 02, 2003, 12:52 PM
aeropal
Guest
n/a Posts
If you decide to purchase an interface cable, several vendors are
listed in this post:
http://www.rcuniverse.com/showthread...70&forumid=142
Discussion Can i use my Futaba 4ex transmitter with FMS? zigzaggy Simulators 5 Jul 22, 2006 04:49 PM
Using JR tx with FMS question DregsFan Simulators 1 Oct 07, 2005 03:39 AM
Wanted usb sim cable for JR compatible with FMS pval3 Aircraft - Electric - Airplanes (FS/W) 6 Oct 04, 2005 11:12 AM
How to use your GWS/Smartech transmitter with FMS simulator tbitz Simulators 59 Mar 04, 2005 10:38 AM
I want a carrying case for my JR transmitter.... BeechSkipperDude Electric Plane Talk 6 Jul 02, 2001 05:50 AM
