Old Sep 18, 2007, 11:51 AM
Joined Aug 2007
Carbon fiber finish
I'm new to composites. I've made a few carbon fiber plates by laying up fabric and epoxy resin between two pieces of MDF wood and wax paper, basically making a sandwich and then clamping the heck out of it to substitute for a vacuum.
The plates come out pretty good but don't have the "glossy" cosmetic appearance that I've seen on other CF parts. I care more about utility than cosmetics, but it couldn't hurt to have it look good. What are my options? I've heard you can use clear coat in a can as a final finish, but that it may peel off over time. I've also heard you can layup with polyester resin instead of epoxy, but it won't be as strong.
Cosmetics aside, does my epoxy finish need UV protection? The parts will see MAXIMUM one hour of sunlight per week, probably.
Thanks!
The111 is offline Find More Posts by The111
Old Sep 18, 2007, 12:31 PM
newbee to rc
flxzcat's Avatar
lake forest, CA
Joined Feb 2007
Use Mylar or a similar glossy surfaced material instead of wax paper. Also, wax and buff the surface of the material facing the epoxy.
Paul
flxzcat is offline Find More Posts by flxzcat
Old Sep 18, 2007, 12:33 PM
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Remember that the finish on the part mirrors the mold, which in your case is wax paper. Try using waxed mylar or acetate about .013 thick, and watch your finish improve. Car wax is fine.
David Forbes is online now Find More Posts by David Forbes
Old Sep 18, 2007, 04:08 PM
Joined Aug 2007
Thanks for the replies guys. Sounds like waxed maylar is the way to go. Where can I obtain this? The wax paper I was using was available at grocery stores... I've never bought a mylar sheet before so I'm not sure where to look.
Thanks again.
Old Sep 18, 2007, 04:35 PM
United States, CA, Davis
Joined Sep 2004
Thanks again.
Online sources are Aerospace Composite Products and Composite Structures Technology (CST). My local hobby shop in Sacramento carries rolls of the .014" thick stuff from ACP which saved on shipping.
Chachi639 is offline Find More Posts by Chachi639
Latest blog entry: Graham1234 Planes
Old Sep 18, 2007, 04:45 PM
John O'Sullivan's Avatar
Nova Scotia Canada
Joined Jan 2004
Acetate has a higher gloss than mylar and will not adhere to the part. It separates easily and gives a mirror finish.
john
John O'Sullivan is offline Find More Posts by John O'Sullivan
Old Sep 18, 2007, 06:00 PM
DLD
David Layne
Tracy, Ca
Joined Jun 2004
If you are just making flat plates, use glass, waxed and polished. That should give you the finish you are looking for.
DLD
DLD is offline Find More Posts by DLD
Old Sep 18, 2007, 06:57 PM
PNF
infopimp's Avatar
Los Gatos, CA
Joined May 2005
Also: roll the heck out of your fabric - each layer - to make sure bubbles are popped or soaked up. I drop a paper towel over the wet CF and use a 3" paint roller lookin' thingy from ACP (link above)... really helps to beat the bubbles.
infopimp is offline Find More Posts by infopimp
Old Sep 18, 2007, 07:47 PM
Portland Intl, Oregon, United States
Joined Jul 2003
Another idea that works well is anti static bags used in the electronics industry.
I have used them as vacuum bags on small flat parts and also pressed them as you have done. They leave a really glossy finnish as well.
TIM
A6INTRUDER is offline Find More Posts by A6INTRUDER
Old Sep 19, 2007, 01:25 AM
Christchurch, New Zealand
Joined Dec 2004
Glass is best, You can wax it really hard though you don't need to and if any resin does stick you can scrape it off.
tomahawkflier is offline Find More Posts by tomahawkflier
Old Sep 19, 2007, 02:12 AM
nuevo's Avatar
United States, AL, Madison
Joined May 2002
You can buy .005" or maybe .010" thick acetate at your local crafts store. i.e. Micheal's or Hobby Lobby (craft store, not RC store).
http://www.michaels.com
http://www.hobbylobby.com
For example at hobby lobby.
http://www.craftsetc.com/store/item....cat=4&Search=Y
I've seen acetate at hobby lobby store. I can't find much on their website. A better source is if you have a local (non national chain) art/drafting supply store. They likely will have acetate by the foot.
nuevo is offline Find More Posts by nuevo
Old Sep 19, 2007, 07:49 AM
Joined Sep 2003
I but mylar from the local drafting supply house. It works great and I can buy as much as I want and the cost is $1/sq. ft. You should be able to find one close by. You might ask a surveyor or architact if they have any old drawings on mylar they want to part with. Be sure to use the non-inked side or you'll have some graphics on your lay-up.
kevin6Q is offline Find More Posts by kevin6Q
Old Sep 19, 2007, 09:00 AM
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
You definitely want to use a glass plate if your panels need to be flat and you are making cosmetic panels.
Like DLD said, wax and polish the glass first. Then pour epoxy onto the glass and spread it around to the size of panel your making, say, 6" by 6". Then use a blow torch or butane torch and lightly move it over the epoxy to pop all the bubbles. Lay your first layer of carbon down into this epoxy making sure that the weave is nice and straight. Come in with subsequent layers of carbon for your strength. Let cure, use a wood wedge or razor blade to pry the panel from the glass.
Sean
sporter is offline Find More Posts by sporter
Old Sep 19, 2007, 04:44 PM
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I've done many aesthetic carbon panels and have found the best way to get nice looking parts.
-As others have suggested, a piece of glass or a mirror is a must. Wax it well and tape off the area you want with masking tape.
-Spray a couple coats of clear paint on the glass surface First before any lay up is done. If this will see sunlight, the epoxy will turn yellow in a short amount of time from UV (without clear paint). The best is a two part urethane paint like PPG car paint but you can even use a Krylon clear if you want... Anything with a decent UV protection in it.
-When the paint is dry, lay up the panel in normal fashion and vacuum bag it down. When the part is cured, you will pop it off and see a very high depth gloss and shine like nothing else. Any minor porosity that didn't evacuate with the vacuum will have a sealed layer of clear paint covering it. Any small bubbles will be masked much better than if it is just a layer of epoxy on the surface causing pin holes.
Troy is offline Find More Posts by Troy
Old Oct 01, 2007, 11:36 PM
Carlsbad, CA
Joined Sep 2004
How wet should the layup be before the mylar goes on? Should the epoxy be damp or just enough to wet the weave or?
Ray
rockbus is offline Find More Posts by rockbus
Discussion Carbon fiber surface finish BMatthews Composites Fabrication 10 Jan 07, 2006 06:35 PM
Glueing Carbon Fiber Reuben01 Electric Plane Talk 8 Aug 02, 2001 10:19 AM
How do I make Carbon Fiber Parts? gns30 Electric Plane Talk 1 Jun 16, 2001 12:02 PM
Were to buy - Carbon fiber laminated sheets?? robertcarl Electric Plane Talk 1 Jun 14, 2001 11:22 AM
home made carbon fiber ? mjse Electric Plane Talk 2 May 26, 2001 07:55 AM
