Old Aug 24, 2014, 07:36 PM
Brynmr's Avatar
United States, SC, Liberty
Joined Dec 2013
Solartex over Ultracote?
I never covered a plane before so I have no idea if this will work. What I want to do is apply dark blue opaque stripes of Ultracote (or any such covering) onto my BOT then cover the entire wing, including the Ultracote with Antique Solartex. It will look something like this photoshopped image, though the color may be a little different. My concern is whether or not the Solartex will stick to the opaque Ultracote. Thanks!
Brynmr is online now Find More Posts by Brynmr
Old Aug 25, 2014, 08:20 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I would suggest covering your model in the Antique Solartex first, and the painting the trim color.
If you want to use Ultracote, apply the trim over the Solartex.
TomCrump is offline Find More Posts by TomCrump
Old Aug 25, 2014, 08:34 AM
Brynmr's Avatar
Joined Dec 2013
Thanks Tom. So you're saying it won't work? Also, can you get sharp painted lines by using tape over Solartex?
Hey just thought - will Solartex bond to a painted surface? I could paint the stripes then apply the Solartex. I really don't want painted Solartex. Probably couldn't get the right color anyway.
Old Aug 25, 2014, 11:42 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
It'd work, but it's backwards.
The Antique Solartex will obscure your ultra.
Solartex gets dirty if it isn't sealed or painted, so you may be disappointed in the outcome.
Painting first, and then covering, will not work well.
Old Aug 25, 2014, 02:58 PM
Brynmr's Avatar
Joined Dec 2013
Obscuring the under-color was what I wanted but Solartex is heavier by 2 oz over Ultracote to begin with and sealing it would add more weight. By how much I don't know. That might be too much on an already heavy Bird of Time. I may have to rethink this.
Old Aug 25, 2014, 03:00 PM
Brynmr's Avatar
Joined Dec 2013
Are there any other semi transparent coverings other than Solartex that don't need to be coated?
Old Sep 02, 2014, 03:35 AM
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
It will stick.
However you would be better to use a creamish coloured ultracote or other film. It will be lighter and stay clean without needing sealing.
The best way to see if your scheme will work is simply to try it on a small frame or mock up of the wing. If it works on that it will work on the real one.
mhodgson is offline Find More Posts by mhodgson
Old Sep 02, 2014, 05:24 PM
Brynmr's Avatar
Joined Dec 2013
Yeah, I decided on Ultracote. Less expensive too.
Question How to iron 1" and 2" strips of Ultrcote over Ultracote without getting bubbles hog2soar Painting and Finishing Tips 6 Aug 05, 2014 01:10 PM
Discussion Ultracote Over Ultracote RCMC Painting and Finishing Tips 0 May 05, 2014 03:52 PM
For Sale Misc. lot - Ultracote, Monocote, Solartex etc....... imdji Aircraft - General - Miscellaneous (FS/W) 5 May 02, 2014 03:47 PM
Discussion Ultracote over Ultracote Pheasant The Builders Workshop 1 Mar 17, 2006 08:45 PM
Question Solartex & Ultracote Source PGR Slope 7 Jun 16, 2005 12:02 AM
