Old Nov 03, 2013, 07:44 PM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
AMD Hawk
At the edf jet jam Kevin Cox was flying one of these models on a 10S Jet Fan with simply an inlet ring and I was impressed with how nice the model flew. I picked up a well used example of this model that was being flown on a Dynamax on 12S.
I plan to power it with a 12S Jet Fan with an inlet ring for starts if I like the way it flies I will make inlet ducting.
I decided to refurbish the model and started by removing the old fan mounts and alot of old built up epoxy that held the original fan mounts in place. The fuselage moulding is actually quite light and well done. The wing is built like a tank and feels as heavy as one too! It's a foam core with obecche wood sheeting so I am not sure why it is so heavy. I need to find a way to get some weight out of it.
The nose will need a little repair work and this might a good reason to make a long nose Hawk 100. I will redo the nose gear mount too.
I'll post some photos tomorrow of work I've done so far.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Nov 03, 2013, 08:34 PM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Cool, looking forward to seeing what you can do with this.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Nov 04, 2013, 09:58 AM
kevin's Avatar
ohio
Joined Aug 1999
hey, that plane was always meant to be a beater. don't go making it all nice.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Nov 04, 2013, 10:52 AM
Joined Dec 2000
NO Beaters in my fleet!
The fuselage is very light and strong for its size. There are a few areas that have cracks that will have to be repaired with a piece of glass cloth but nothing major.
I will most likely move the rudder servo into the fin with a removable panel.
I will not do any paint work until I have flown the model to decide just how well I like it.
Old Nov 04, 2013, 11:58 AM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
If any one is looking I have one NIB for sale with a spare fuse.PM me if you want a spare
turbonut is online now Find More Posts by turbonut
Old Nov 05, 2013, 10:28 AM
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Pm sent
SkylineFlyer is online now Find More Posts by SkylineFlyer
Old Nov 05, 2013, 10:46 AM
Hawk Fanatic
Joined Jul 2008
Sweet Bob , I look forward to seeing this fly in person.
Old Nov 05, 2013, 12:20 PM
Joined Dec 2000
I have now stripped out all formers except the nose gear, the weight is 2.2 lbs.
Old Nov 05, 2013, 01:58 PM
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Hi Robert
how did you get rid of the old epoxy?
cheers
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Nov 05, 2013, 10:14 PM
Joined Dec 2000
Steve used a cutoff wheel and the a sanding drum the finally 60 grit sand paper and a lot of elbow grease! ;( Im actually having fun with the refurbish efforts.
Old Nov 05, 2013, 10:50 PM
Hawk Fanatic
Joined Jul 2008
And hopefully a mask. That dust is nasty stuff.
Old Nov 06, 2013, 08:19 AM
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Hi Robert
thanks for that. I thought you had found some magic potion other than Elbow grease.
Cheers
Old Nov 06, 2013, 01:19 PM
Joined Dec 2000
Don't I wish!
I weighed the wing this morning with the retracts removed, what a tank, 2.4 lbs with film covering. Looking at cutting new wing cores to save 1lb minimum.
Old Nov 06, 2013, 04:45 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
I checked last night and mine has built up wings..pics coming to you later today
Old Nov 07, 2013, 11:11 AM
United States, NC, Rockingham
Joined Feb 2011
Amd Hawk For Sales
I also Have an AMD Hawk for sale if anyone is interested. It has been flown twice years ago with a nitro engine. It is equipped with spring air retracts and JR servos. It has a little hanger rash but would make a great candidate for electric power. I will take $300.00 for it. I will box and ship at your expense.[ATTACH][ATTACH]6240Name: hawk.jpg
Description:
Description:
Description:
Description:
Description:
Description: 688[/ATTACH][/ATTACH]
jp447 is offline Find More Posts by jp447
Sold 120MM AMD Hawk $375 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 6 Jul 17, 2013 10:13 PM
Wanted will's hobby or amd hawk sherlockshah Aircraft - Fuel - Jets (FS/W) 1 Jul 08, 2013 06:21 PM
Wanted Amd bae hawk CARL SCHIMNOWSKI Aircraft - Electric - Jets (FS/W) 1 Jun 02, 2013 08:30 PM
Sold AMD Hawk 120mm with fan and motor 1moparman1 Aircraft - Electric - Jets (FS/W) 0 Jun 02, 2013 08:25 PM
Sold AMD BAe Hawk (120mm): $200 eaticus Aircraft - Electric - Jets (FS/W) 2 May 24, 2013 10:23 PM
