Old Mar 19, 2010, 06:27 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Stryker motors: High performance, low cost Turnigy 28xx comparison
Did some static testing on popular low-cost Styker-motors today, and here is what I found:
Turnigy 2835 / 3900KV Inrunner
Prop Amp Watts Thrust(kg)
TGS 6*4 56,5 609 1,38
MA 6,5*4 73,1 750 1,16
TGS 5*5 53,2 558 0,93
APC 4,75^2 44,7 477 0,72
Turnigy 2836 / 2350 Outrunner
TGS 6*4 32 358 1,14
MA 6,5*4 49,3 526 1,13
TGS 5*5 29,6 331 0,82
TGS 7*4(UoB)60,8 666(Beast?)1,5
Other observations:
Tried the configs with 2 different ESCs an 2 different batterys:
In these setups the TowerPro H40A ($9,98) performs as well as Turnigy Plush 80A........
In the case of LiPos(3S1P), the rather expensive Hyperion VX 2200 (35c) is out-performed by 5-10% by Turnigy 2200 30C......
Please comment, anyone who has an opinion or some thought to share......
*EDIT*
After doing some testing I've found this to be a bulletproof lowcost setup:
Turnigy 2836/3200kv http://hobbyking.com/hobbycity/store...idProduct=8138
TowerPro H40A esc. http://hobbyking.com/hobbycity/store...ed_Controller_
Turnigy 3S1P 2200mAh 30C http://hobbyking.com/hobbycity/store...idProduct=9394
APC 6*4e prop
The Stryker will go some 110mph in level flight and I have measured it to some 118mph coming out of a dive.
See this video and specially the passes at 2:15 and 3:22 which gave the figures above:
RC F 27 Stryker: LoudMouth Turnigy 2836 (4 min 26 sec)
*EDIT II*
After several months of trying different Turnigy 28mm setups, my recommendation will be:
PS: Although I have been running this setup with good results others have reported that this setup will BURN YOUR MOTOR. The kv of the Turnigys can vary quite a bit and the conclusion must be that this setup is not recommended. For a long life with the 2836/2350 you must not exceed 6" prop diameter when run on 4S!
Turnigy 2836/2350 http://hobbycity.com/hobbyking/store...idProduct=7993
Turnigy Plush 80 ESC: http://hobbycity.com/hobbyking/store...idProduct=3727
Turnigy 4S3000 40C LiPo: http://hobbycity.com/hobbyking/store..._40C_Lipo_Pack
APC 6.3*4 Pylon/Combat prop: http://www.canyonhobbies.com/APC-Pro...apclp06340.htm
This setup gives very good thrust and speed and a static of 68Amps/1061Watts.
Here's a video:
Stryker Turnigy (1 min 9 sec)
Hope you'll enjoy this thread, but do not waste too much flying time on your computer. Go out and fly your Stryker - that's what it's for...
-Arcteryxxx
Arcteryxxx is offline Find More Posts by Arcteryxxx
Last edited by Arcteryxxx; Oct 07, 2010 at 01:00 AM. Reason: Posting some tried setups for new readers to enjoy
Old Mar 19, 2010, 08:40 PM
denver colorado
Joined Jan 2004
I have a turnigy 28/35 3900kv in my funjet. With a 4.75x4.75 it pulls 38 amps, 420 watts. Motor is rated at 40 amps 3s. Mine comes down cool after 5 minutes of almost all WOT but I suspect it would fry and die pretty quickly on 4s .
topher is offline Find More Posts by topher
Old Mar 20, 2010, 12:00 AM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
The in-runner holds to much heat and will blow up.
I have one that had about 50 flights.
The out-runner has over 100 flights and is not even warm when landing after 9 mins of 130 mph runs!
DoctorAudio is online now Find More Posts by DoctorAudio
Old Mar 20, 2010, 12:27 AM
What's that button do?
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
Anything over a 4.75x4.75 is way too much for the 2835-3900. I've read Doc's results from the outrunner, and it really seems to be the better choice. So much so that I'm thinking about going that route.
Shpook is offline Find More Posts by Shpook
Old Mar 20, 2010, 04:14 AM
Milwaukie , Oregon
Joined Feb 2003
On the 2835-3900KV in-runner a 4.3X 4.1.
grauper prop
On a 4S setup!
Old Mar 20, 2010, 11:15 AM
Joined Jan 2010
am I doing this correct? I used the prop calculator chart and if using a 5x5 prop you need a higher KV motor eg a 5x5 on a 3900kv motor on 4s is showing a pitch speed of 164mph or something stupid fast with decent thrust.
But say using a 3200kv motor and a 6x5.5 prop your top speed is reduced to 135mph on 4s but has about 30 more oz of thrust.
in the end what are you better off doing to have a fast stryker? the 5x5,3900,4s? or the 6x5.5,300kv,4s or something among those lines?
shakaka is offline Find More Posts by shakaka
Old Mar 20, 2010, 12:28 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I have used the Turnigy 2835 3900kv motor more than any other hobby city motor. On a Stryker, that motor shines on an APC 5x3 prop.
I would never try this motor on 4S, it will smoke before it even gets in the air.
As for the 2836 2350kv, I just bought one and haven't tried it yet. I hear 4S is possible with a 5.5x4.5 prop. I will be testing this motors capabilities soon.
This is my favorite HC motor thus far. I use it on my combat stryker
http://www.hobbycity.com/hobbyking/s...idProduct=4943
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 20, 2010, 01:34 PM
Milwaukie , Oregon
Joined Feb 2003
Jhonny, use a 4.1 X 4.1 on 4S it will work for many flights!
You would be much happier with a 2836 3200 KV out-runner anyway!
More punch for the money!
I have gotten 900 watts out of one. If you put it with the rotating end at the back of the plane you won't have problem with magnets ungluing from the heat!
Old Mar 20, 2010, 02:12 PM
Joined Jan 2010
rotating end at the back? so set it as a pull setup instead of push ?
Old Mar 20, 2010, 02:30 PM
Milwaukie , Oregon
Joined Feb 2003
You will have the the bolts facing the nose cone.
push the shaft out toward the rotating end! The prop will be farther away from the fuselage.
Old Mar 20, 2010, 03:06 PM
Milwaukie , Oregon
Joined Feb 2003
These motors I have tested and ran the crap out of them.
I have used the a 6 X 5.5 - 4.1 X 4.1 APC and gruapner props on them!
I have ran 3S, 4S and 5S setup with them!
I can tell you this the lower KV ones are fun when people at the field, say stuff like mine is faster than that!
I just laugh and change batteries.
I prop these for 3S and they draw lost of amps and stay cool.
I don't like beating the holy hell out of my batteries.
I try to find the setup that gives me plenty of power yet allows me to run my sTuff for every
650 watts on a 4S.
http://www.hobbycity.com/hobbyking/s...trunner_2350kv
800 watts 4S
http://www.hobbycity.com/hobbyking/s...F_Motor_3200kv
1100 watts 5S
http://www.hobbycity.com/hobbyking/s...i_Motor_3700kv
Old Mar 20, 2010, 07:08 PM
KenS999's Avatar
United States, IL, Huntley
Joined Oct 2008
Stryker motor....
Hi,
It appears I will need to replace my Stryker C motor soon. Can you recommend a Turnigy or comparable motor to replace the stock 1880 kv one. I Plan on using these components: Stock prop and stock prop adapter , 2200 3S lipo and 30amp esc. Something that will easily mount to the stock motor mount with no/minimal modification would be great
Ken
KenS999 is offline Find More Posts by KenS999
Old Mar 20, 2010, 07:23 PM
Milwaukie , Oregon
Joined Feb 2003
http://www.hobbycity.com/hobbyking/s...hless_Inrunner
Old Mar 20, 2010, 07:25 PM
Joined Jan 2010
doc how are you getting 1100 watts on that motor? On 4s with a 6x5.5 I am getting like 650 on the calc.
what prop and motor do you recomend for 4s 2200mah packs with a 50 amp esc
Old Mar 20, 2010, 08:06 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by KenS999 View Post
Hi,
Ken
This motor has excellent thrust on a 6x4 apc sport. I think it outperforms the 2835 2700kv.
Discussion Low cost receiver comparison n0qbh Radios 1 May 01, 2008 05:20 PM
Discussion Proven low cost motors to replace eflite motors? TommyB Electric Plane Talk 55 Aug 24, 2007 10:28 PM
Discussion What would be a decent low cost motor for a Stryker? randall1959 Flying Wings 33 Nov 17, 2006 02:00 PM
Discussion Li-Po high cost balancer/charger vs low-cost Rusty-Gunn Batteries and Chargers 24 Oct 09, 2006 10:05 PM
Discussion comparison between low cost lipos (Apex, Max amps, DN power...) oded mazor Batteries and Chargers 21 Aug 23, 2006 09:29 AM
