Old Oct 28, 2003, 07:11 PM
Australia
Joined Sep 2001
david_dewit is offline Find More Posts by david_dewit
Old Oct 28, 2003, 07:26 PM
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
I made a flat package adapter the other night for programming the SM sized PIC12C509A well it seemed all the pins were touching but were not. I made the adapter similar to the way the RX boards are made. With a blank peice of copper clad board and cut tracks. The little sockets turned 90 degrees seem to work better because of the spring in them. Any ideas on getting one to work with cutting tracks in a copper clad board? I think my method of holding the pic down needs to be retought, I used rubber bands
which work ok on the sockets but not on flat copper.
Nice programmers Dave and Josh.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Oct 28, 2003, 07:46 PM
Australia
Joined Sep 2001
Billy,
I have had no problems with flat pack adapter, but like Koichi, I use nylon bolts to clamp.
Just a thought, what about a clamp like in picture or maybe a cloths peg.
I'm sure you already know pics are static sensitive.
Dave
Old Oct 28, 2003, 07:54 PM
QLD, Australia
Joined Sep 2003
Billy,
these are from Koichi's site
clipclop is offline Find More Posts by clipclop
Old Oct 28, 2003, 07:56 PM
QLD, Australia
Joined Sep 2003
one more
Old Oct 28, 2003, 08:00 PM
Australia
Joined Sep 2001
Another picture of flat package adapter back on page 20.
Dave
Old Oct 28, 2003, 08:01 PM
Joined Nov 2002
I was just looking at those pictures on Koichi's site.
I would have to use metal bolts and nuts glued underneath. would this create static? Is that why nylon screws were used?
Billy
Old Oct 28, 2003, 08:17 PM
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
Billy,
I use the plastic screw of 2mm . When screwing by the hand, to tighten, the reason because condition can be adjusted delicately.
Koichi
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Oct 28, 2003, 08:57 PM
Joined Nov 2002
Thanks Koichi.
I will try it with small metal bolts.
Billy
Old Oct 28, 2003, 11:20 PM
QLD, Australia
Joined Sep 2003
Koichi,
Hope you dont mind me posting your pictures , and thank you for shareing with us all your wonderfull work.
I am a pensioner and on a limited budget , so this ir system has alowed me to get into the light weight flyers , again thank you Koichi.
Stewart
Old Oct 29, 2003, 05:39 PM
United States, PA, Canonsburg
Joined Sep 2001
Here's my question, can a regular 12C509 be re-programed? I've been under the impression that as long as "code protection" isn't used, these chips could be programmed over and over.
Skysailor is offline Find More Posts by Skysailor
Old Oct 29, 2003, 05:44 PM
Australia
Joined Sep 2001
Skysailor,
No, one time programmable.
Dave
Old Oct 29, 2003, 05:49 PM
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Skysailor,
the chip itself would be erasable and reprogrammable, but you would have to expose it to ultraviolet light to erase it (like the old EPROM chips). Since the SOIC types don't have a window you simply can't do this. The CERDIP cases have a quartz glass window and can be used again and again, but these chips are expensive and way too heavy for our needs. I have two 12C509A in CERDIP housings for development, one of them is usually exposed to the light of an old tanning lamp that I use for erasing chips and exposing PCB material.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Oct 29, 2003, 06:00 PM
Australia
Joined Sep 2001
Regular PIC12Cxxx dips and soics are not erasable.
PIC12CxxxJW is erasable and expensive.
Dave
Old Oct 29, 2003, 06:22 PM
Joined Sep 2001
Since the 12C5XXJW are actually not that expensive but the UV erasers are. Goldmine Has UV LEDs that I wondering if they could be used to erase these chips. check them out
http://sales.goldmine-elec.com/prodinfo.asp?prodid=7291
airwars "infra-red combat system for planes" Tree_Magnet Power Systems 15 Jan 08, 2008 10:41 PM
Discussion DIY conversion to infra red Tom Harper Aerial Photography 46 Jun 25, 2006 06:43 PM
Infra-Red Thermometer for Helis rscamp Electric Heli Talk 7 Jan 08, 2002 07:11 AM
airwars "infra-red combat system for planes" Tree_Magnet Foamies (Kits) 4 Aug 02, 2001 01:15 AM
Infra red transmitter and receiver for micro size aircraft Ron MIller Power Systems 2 May 28, 2001 10:51 AM
