Old Jun 27, 2011, 07:44 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
MSR Help?
Guys, maybe I'm just having a senior moment here but I can't get my new MSR in the air (DX6i). After closer inspection, it appears that the cyclic is revered. forward-back is left-right, left-right is forward back. I tried a stock heli and aero model. Am I missing something here? No BNF for me?
dklassen is offline Find More Posts by dklassen
Old Jun 27, 2011, 08:35 PM
Joined May 2011
sorry, not sure what happened, last thing i knew i was on a different post.
rob
robert214 is offline Find More Posts by robert214
Old Jun 27, 2011, 08:44 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
You might want to move your post. I don't think it's relevant to my question at all.
Old Jun 27, 2011, 09:25 PM
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
you need to set it up unfortunatly . a pain in the but but do one function @ a time sometimes they are close but seems yours is reversed on every channel maby use a new model memory slot see if that makes it easier .
rcphreak is offline Find More Posts by rcphreak
Old Jun 27, 2011, 09:37 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
It's not the individual channels that are reversed. Aileron is elevator and elevator is aileron. I also tried a new model memory but that didn't help either.
Old Jun 27, 2011, 10:05 PM
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
Could you simply switch the servo plugs around, on the RX?
Frank_fjs is offline Find More Posts by Frank_fjs
Old Jun 27, 2011, 10:08 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
I think they are soldered to the board.
Old Jun 27, 2011, 10:15 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
im sure this cant be the first of this some one will chime in with a solution .
Old Jun 27, 2011, 10:18 PM
Frank_fjs's Avatar
Joined Nov 2010
The only info I can find that I gather you already know, is:
If you’re using a computer transmitter, we suggest you select a clean model memory,
set the transmitter on ACRO or AIRPLANE mode, default servo settings, neutral trim
settings, bind and fly
Old Jun 27, 2011, 10:39 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
Yep, tried that too. It's got to be the 5 in 1 board. It's acting very irritate. It just shouldn't be this hard. I'll give HH a call tomorrow. Hopefully they will help me out.
Old Jun 27, 2011, 10:59 PM
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
Sounds like somebody screwed up @ the factory, either that or you're in elevon mode or a setting is not quite right on the Tx (which would be weird so I doubt it). Have you tried it in heli mode yet? If it does the same thing in heli mode I would think the 5n1 is jacked for sure, HH should replace it no prob.
slo-fly is offline Find More Posts by slo-fly
Old Jun 27, 2011, 11:04 PM
dklassen's Avatar
United States, TN
Joined Mar 2002
Yep, tried heli mode too. I think I got the Friday at 4 unit. The gear were turned around backwards too. <sigh>
Old Jun 28, 2011, 01:21 AM
Scottsdale Arizona
Joined Dec 2009
They must have had beer on their mind! Sounds like another rookie @ the controls while the manager left early LOL! The manager explicitly told him to solder the red wire to the left pin, instead the rookie got it backwards. God only knows how many 5n1's are screwed up now!
Old Jun 28, 2011, 06:13 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Sounds like almost as much fun as the units that had the elevator-rudder mixed programmed in backwards... So instead of helping the heli to stay in place during a piro, it amplified the natural tendency to move forward on right rudder, and slide back on left rudder...
SoloProFan is offline Find More Posts by SoloProFan
Old Jun 28, 2011, 10:59 AM
dklassen's Avatar
United States, TN
Joined Mar 2002
I have another MSR coming this week.. Lucky for me I guess. HH tells me I need to wait and test with the other one first. If it flys fine they will replace the 5 in 1. If I didn't have the second one coming they won't replace the 5 in 1 without me testing with their MSR tx first. Another words they want me to find a hobby store somewhere, take it in and test it there. Really?
Discussion Blade MSR Confirmed. FAQ + PICs Below + video and video review V2.0 + MSR HELP forrest225 Micro Helis 1932 Nov 22, 2014 11:21 PM
Discussion MSR behaving very strangely indeed...help! Tom Lauten Micro Helis 6 Jun 16, 2011 10:46 PM
Discussion MSR/120SR advance swashplate help PKDURANGO Micro Helis 4 Mar 19, 2011 02:03 AM
Discussion Blade msr or t-Rex 100 help req zippyshutt Electric Heli Talk 3 Mar 19, 2011 02:01 AM
Discussion Help needed for Spektrum DX5e and my new mSR bltefft Radios 0 Mar 11, 2011 12:17 AM
