Old Jul 31, 2014, 05:15 PM
Where o where has my America g
stsguy's Avatar
United States, TX, Spring
Joined Aug 2013
Help!
can I get a few ideas on motor size
http://www.nitroplanes.com/ya50nimorare.html
I have this .50 yak 54 I'm converting to electric. I'm new and the motor size throws me guys. I'm in the market to get electronics for it and 1 other plane but I'm at a wall on knowledge.
The yak I want to power for 3d flight but I'm no 3d pilot. I do want a lot of power. Can you suggest esc motor prop and battery size please.
I also need to outfit a fliton edge 540 it has a wingspan of 48 inch I think i need the same for it also thanks
stsguy is offline Find More Posts by stsguy
Old Aug 01, 2014, 10:54 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
On the 48" planes I fly the Torque 2814/820 motor with Airboss 45 ESC on 3s with a 13/6.5 or 14/7 propeller, and on 4s with a 12/6 prop. Power is outstanding and reliability is dead solid perfect.
Depending on what your definition of "a lot" of power is, you might even want to set up to the Torque 2812 motor and Airboss 60 ESC which is simply an atomic bomb of a motor. I flew those years ago on on 51" Slicks with 4s packs and a 14/7 prop, and it was simply terrifying.
In either case, since you want "a lot" of power, I would go with 4s.
However, I am sure the 2812 would probably pull the Fliton apart in mere seconds, but it might be ok on the nitro planes airfrane since it is a nitro conversion and probably built pretty stout.
Your only problem may be the lengths of the motors and how they fit inside the cowlings. Check the Extreme Flight site for dimensions.
Doc Austin is online now Find More Posts by Doc Austin
Help! Can't get the motors to unlock on Walkera QX R350PRO kukntra Multirotor Electronics 6 May 23, 2014 09:38 PM
Discussion Have any idea what soldering iron i can get? AnthonysQuad Scratchbuilt Multirotors 8 May 13, 2014 08:32 PM
Discussion Can't get my hexa to rise more than a few feet - need some power help! nadassor Multirotor Power Systems 10 Mar 21, 2014 10:42 PM
Discussion iron-on covered planes-can water get through? phil alvirez Electric Sailplanes 8 Oct 14, 2013 06:55 PM
Discussion ESC and motor getting hot after few seconds of test jamurenoki Beginner Training Area (Aircraft-Electric) 6 Oct 03, 2013 10:07 AM
