Old Jan 28, 2014, 09:22 PM
United States, CA, Napa
Joined Jan 2014
slipper clutch melting spur gear
I have a vaterra glamis uno. I got the 3s 5200 mah battery, and the manufacturer says to run the 20T motor pinion instead of the 24T. after replacing the stripped spur gear, I took it out. After 20 minutes the car has trouble moving. I inspected the gear and the slipper clutch melted the surface of the spur gear which it goes on top of. Was it too tight? The motor is a 3300kv dynamite
jrbirdman92 is offline Find More Posts by jrbirdman92
Old Jan 28, 2014, 09:49 PM
Cow R/C
fastmax's Avatar
United States, MI, Grand Blanc
Joined Nov 2007
Sounds to me like it was too loose and with the 3s battery it was probably slipping to the point of heating up.
fastmax is online now Find More Posts by fastmax
Old Jan 28, 2014, 10:01 PM
Joined Jan 2014
Do you think the different pinion had something to do with it?
Old Jan 28, 2014, 10:02 PM
Thumper King
Barracuz's Avatar
United States, RI
Joined Aug 2011
I second that...
Barracuz is offline Find More Posts by Barracuz
Old Jan 28, 2014, 10:27 PM
Cow R/C
fastmax's Avatar
Joined Nov 2007
It could have had a little to do with the smaller pinion, but most likely the boost in voltage was the main culprit. My guess is the slipper was a bit to loose even before you started running 3s.
Old Jan 28, 2014, 11:01 PM
Joined Jan 2014
Its weird it never happened before. It even popped wheelies on 3s. The gear just stripped
Old Jan 29, 2014, 01:42 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
You mean the gear's teeth were sheered off? That's indeed a symptom of a too tight slipper. But earlier it appeared that you were saying the sides of the spur, where it contacts the slipper pads, had started to melt.
SoloProFan is offline Find More Posts by SoloProFan
Old Jan 29, 2014, 09:16 AM
Joined Jan 2014
Yes the spur gear on it from the factory got stripped after a while on 3s. The replacement one I put on is the one that melted
Old Jan 29, 2014, 09:47 AM
Cow R/C
fastmax's Avatar
Joined Nov 2007
Stripping of the original could be the result of the slipper being too tight or the gear mesh not being set properly.
The 2nd one melting is almost certainly due to the slipper not being tight enough. How did you have the slipper adjusted? Or was it still at the factory setting?
Old Jan 29, 2014, 10:00 AM
Thumper King
Barracuz's Avatar
United States, RI
Joined Aug 2011
Ok did it melt and strip?
Old Jan 29, 2014, 10:24 AM
DocG2828's Avatar
Joined Jul 2007
I've read about this problem. With the 3s the heat from the motor can be transferred to the pinion and actually melt the spur.
DocG2828 is offline Find More Posts by DocG2828
Old Jan 29, 2014, 11:49 AM
Joined Jan 2014
Yeah I don't think I adjusted it properly when I changed the spur gear out. Oh well haha
Old Jan 29, 2014, 12:02 PM
Thumper King
Barracuz's Avatar
United States, RI
Joined Aug 2011
Just get a metal spur get the gear mesh nice and tight and your problems are solved.
But you should check if your motor is really overheating. Even if the slipper was loose, the pad is supposed wear out way before it melts the spur!
Old Jan 29, 2014, 12:32 PM
Joined Jan 2014
I don't think vaterra makes a metal one. And it has to have these little grooves for the clutch pads to go into
Old Jan 29, 2014, 12:39 PM
Cow R/C
fastmax's Avatar
Joined Nov 2007
A metal spur gear really shouldn't be necessary and only adds to the rotating mass of your drive line. I have plastic Robinson Racing and Kimbrough spur gears in my box that I bought in the late 80's early 90's that have seen hundreds of runs, and are still perfectly usable.
It's all about being patient, taking your time, and getting your gear mesh and slipper adjusted properly before running. As with any high performance machine be it a 1:1 muscle car a snowmobile, dirt bike or RC toy they require proper setup and tuning in order to hold up reliably while being run. Which for me is all part of the fun of the hobby.
Question Vintage Losi JrxT Slipper clutch CD10390 Off-road Cars 7 Jan 08, 2014 06:58 AM
Sold Losi Mini-T Transmission Assembly w/ Ball Bearings Slipper Clutch Gear Cover. REDUCED tprada1624 Cars - Accessories (FS/W) 5 Sep 24, 2012 07:53 PM
Sold Losi Mini-T Transmission Assembly w/ Ball Bearings Slipper Clutch Gear Cover. REDUCED tprada1624 Cars - Cars and Parts (FS/W) 7 Sep 24, 2012 07:52 PM
Sold Losi Mini-T Transmission Assembly w/ Ball Bearings Slipper Clutch Gear Cover. REDUCED tprada1624 Cars - Trucks and Parts (FS/W) 3 Sep 24, 2012 07:50 PM
TT Duc Nitro, clutch bell and spur gear combo...help jdracer Motorcycles 0 Sep 01, 2005 05:47 AM
