Old Oct 11, 2013, 03:20 PM
GH crash - I practice a lot
Joined Oct 2011
Help!
Question on 8.5mm motors
I was browsing through the Horizon Hobby website and noticed that they had three 8.5mm motors listed; the Parkzone Sukhoi motor, the Parkzone P-51/T-28 motor and then one from E-flight. I'm wondering if anyone could tell me the differences in the motors and which one is the "hot" motor of the three.
http://www.horizonhobby.com/webapp/w...pe=productgrid
ghcrash is offline Find More Posts by ghcrash
Old Oct 12, 2013, 10:41 AM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The 26m motor is the same motor in the Champ. Short length wires, translucent white end bell. Mid power. About 1 Amp with a 5"X30 prop.
The P-51/T-28 motor has mid length wires, black end bell and is know as a "Mustang Motor". Pretty much the std wind in all of the PKZ 1S planes. About 1.3A with a 5"X30 Prop
EFL9052 is the 4site/Extra 300 motor. Same as Mustang Motor but with Longer Lead plug
The New ASXtra300 Motor (not listed) has a 23mm long can and would be the highest Power 1S plane motor from HH. It probably draws around 1.5 A with a 5"X30 prop.
UNGN is offline Find More Posts by UNGN
Old Oct 13, 2013, 10:33 AM
Joined Oct 2011
THANKS for the info. It sounds like that all the HH's present 8.5mm motors are about the same.
Are there any other 8.5mm motors out there that may be better than the HH stuff?
Old Oct 13, 2013, 10:56 AM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
The new ASXtra300 motor is probably just as good as anything you'll find. With the added benefit that you won't have to change the pinion gears out. One thing to remember is you must use the best batteries to take advantage of these motors.
I R Irv is online now Find More Posts by I R Irv
Old Oct 15, 2013, 06:35 PM
Gulf Breeze, FL
Joined Jul 2006
I think you missed UNGN's thrust - there are three very distinct power levels, in order from low to high: Champ; P-51/4-Site/T-28/Extra, etc; and the new AS3Xtra (a helicopter motor). The more powerful motors need better batteries than the lesser.
Alternatives include the Bravo SP and SX motors discussed here. Hopefully the AS3Xtra motor will be the breakthrough IR points out.
Gene K
speedy01 is online now Find More Posts by speedy01
Old Oct 17, 2013, 05:10 AM
Joined Oct 2011
Thanks everyone. good information all the way around.
I've made a 15" span 3D plane that uses the P-51 motor and gear box. It does all the typical 3D maneuvers but it would be more fun if it has just a little bit more power. I was hoping to find a slightly more powerful motor I could just slip into the P-51 gearbox.
Old Nov 07, 2013, 08:07 PM
Joined Apr 2012
Does anyone know if the AS3Xtra motor is more powerful than the Bravo SX motor? I`ve got two scae helis using the Bravo SX mechanicals that are a few grams heavier than the standard Bravo SX and would like to drop in a more powerful motor that`s the size of the Bravo SX motor.
MiG29Fulcrum is offline Find More Posts by MiG29Fulcrum
Discussion Help - Question on hacker motor and prop assembly WHOOOOOOOSH!! Electric Plane Talk 2 Mar 30, 2013 08:50 PM
Question Sourcing Question: 1.5mm Nylock Nuts poiyt Electric Plane Talk 10 Mar 20, 2013 03:57 PM
Question UM 8.5mm brushed motor kV? NitroCharged Micro Ready-to-Fly 8 Jan 28, 2013 06:01 AM
Wanted couple of PZ UMX P51/Corsair 8.5mm motors with gearbox karfrik Aircraft - General - Miscellaneous (FS/W) 0 Jan 08, 2013 08:12 PM
Discussion Chimera: 10" All balsa Delta, brushed 8.5mm motor, 30mm fan speedemo Micro EDF Jets and Power Systems 7 Apr 29, 2011 03:29 AM
