Old Dec 07, 2012, 02:59 AM
Joined May 2005
Rds8000 id-up!
My RDS8000 is also now dead in the water. While trying to go to a new model setting, I inadvertently got into HELI mode and now when I turn the Tx on all I get is ID-UP! and beeping and none of the buttons or switches are responsive. I've tried everything and every combination I can think of. Nothing works.
I found a few old threads on this topic (so it's not just me) but I've found no solution.
THIS REALLY SUCKS AND ALTHOUGH I HAVE BEEN AN AIRTRONICS USER FROM THE BEGINNING, I WILL NEVER AGAIN BUY ANOTHER AIRTRONICS RADIO.
abufletcher is offline Find More Posts by abufletcher
Old Dec 07, 2012, 05:09 AM
Fountain Valley, CA USA
Joined Oct 2000
You could contact the service dept for free
For technical assistance with Airtronics radio setup and operation, you can contact our technical support department at 800-262-1178 from noon-4PM M-F Pacific time
or email
service@airtronics.net
Mike Greenshields is offline Find More Posts by Mike Greenshields
Old Dec 07, 2012, 06:14 AM
Joined May 2005
Thanks, Mike. I did eventually find the solution. It has to do with the position of the toggle switches for HELI flight modes. If, when the Tx is switched on, the switches are set for either 1, 2, or 3, the TX locks up and displays ID-UP! It's a shame this isn't explicitly explained in the manual. There's just a mention (in the HELI section) about "knowing which flight mode you're in before starting the engine."
The problem on my Tx is that last year the right toggle broke off. That was never a problem for me since I only fly WWI aero. But I was able to insert the end of a ballpoint pen and jiggle the broken-off toggle base around until the FM switched over to N. When that happened the ID-UP! and beeping disappeared and I was able to use all the buttons. Now that I've switched that model over to AERO the broken toggle is no longer a problem. But I'll have to keep this in mind each time I set up a new model.
Sorry for the rant.
Old Dec 07, 2012, 07:01 AM
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Go on, go crazy - buy yourself a new 50c switch!
MattyB is online now Find More Posts by MattyB
Latest blog entry: My OpenTX Taranis templates...
Old Dec 07, 2012, 08:02 AM
Joined May 2005
Can a suitable replacement switch that would fit the Tx body be purchased separately? If so, where?
Old Dec 07, 2012, 05:26 PM
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Of course - a quick Google popped this site straight up, but you can probably get the same switch much cheaper from a generic component supplier.
http://globalservices.globalhobby.com/part/751700.asp
Old Dec 08, 2012, 05:14 AM
Joined May 2005
Thanks. I've bookmarked this for future needs.
Discussion ID plane and hc power set up please frank99 Parkflyers 1 Apr 29, 2010 12:20 AM
Discussion I thought Id offer this up here ..... jstoll Flying Wings 13 Apr 20, 2009 09:57 AM
Discussion Help with ID-UP! on Sanwa rd 8000 Padishah Radios 3 Apr 19, 2009 06:21 AM
I figured Id offer up a few things jstoll Non R/C Items (FS/W) 7 Mar 27, 2009 08:37 PM
Discussion Thumbs Up / Thumbs Down-AirTronics RDS8000 8CH Gsquared08 Radios 3 Apr 18, 2008 06:46 PM
