Old Apr 29, 2014, 12:56 PM
CW4
Joined Aug 2012
Hey jdm2ner --
A couple questions for you:
It sounds like you are running the tail boom straight out of the mechanics without using the front gear set from the RCA tail drive kit. Is that correct? If so, did you have any issues with the angle of the tail boom, since the tail on the Apache tends to slant downwards a few degrees?
Did you configure your main rotor to spin in the scale direction (CCW), or did you leave it stock and have it spin CW? I couldn't really tell from your video. It looks like it's spinning CCW, but the camera does some strange things.
Thanks!
CW4 is offline Find More Posts by CW4
Old Apr 30, 2014, 07:12 PM
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
Cm4 you are right I am not using the front short section because of that I cant make the head turn ccw do to the tail now will turn in the wrong direction. If you do use the front section than you can turn the head ccw and the tail will also spin in the correct direction. I am having a bit of clearing issue but that bad.
jdm2ner is offline Find More Posts by jdm2ner
Old Apr 30, 2014, 08:57 PM
CW4
Joined Aug 2012
Thanks for the info jdm.
What headspeed are you running?
Old May 01, 2014, 02:49 AM
jdm2ner's Avatar
Joined Oct 2010
1390
Old Jul 10, 2014, 06:19 AM
jdm2ner's Avatar
Joined Oct 2010
does anybody need any parts for this bird. my tail gave out the other day and i dont feel like reparing it any more. getting rid of everything but the electronics and the 4 blade head.
Old Jul 12, 2014, 05:23 AM
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Sorry to hear that you lost your bird.
Jan,
Horseman is offline Find More Posts by Horseman
Old Jul 12, 2014, 11:29 AM
jdm2ner's Avatar
Joined Oct 2010
thanks horseman she really turned heads at the field.
Old Jul 14, 2014, 11:12 AM
CW4
Joined Aug 2012
Sorry to hear that jdm. Do you know what caused the tail to fail? I've got my tail drive set up pretty much like yours with the metal gears.
Old Jul 14, 2014, 05:19 PM
jdm2ner's Avatar
Joined Oct 2010
Not sure. She was flying great for about 15 flights. I did notice once I landed the the servo was not moving too smoothly but not sure if that is from the crash or the cause of the crash. Also a saw that the set screw on the tail baled grips had moved out from the notch on the tail shaft. I have no idea. I am using the scale plastic smart model tail blades. I don't know if they had anything to do with it. Or it could have also been my ar7200bx that gave out.
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
