Old Oct 19, 2009, 04:36 PM
Dublin Ireland
Joined Aug 2005
Question
wemo or het 70mm fan
Hi there
Having read a few threads I decided on a wemo 480 fan and ordered one.
It arrived today but the supplier sent a HET 6904 instead ?????
When I phoned I was told We don't sell wemo. Is there Such a big difference, or should I just try it rather than sending it back.It is a four blade.I was going to fit it to a Hoffman Beast Or LS 1400 I have both.
Cheers
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Oct 19, 2009, 04:42 PM
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
If he charged you the price of a wemo and shipped you HET, I'd definitely raise hell. There is a pretty significant price difference between the two.
Performance wise you will get different opinions from the two camps. I can tell from past experience that HET 6904 and Wemo pro are both excellent fans.
Steph280 is online now Find More Posts by Steph280
Old Oct 19, 2009, 05:02 PM
steve morris
wekiva springs,florida
Joined Jul 2006
who did you order the fan from.
steve morris is offline Find More Posts by steve morris
Old Oct 19, 2009, 05:47 PM
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I personally don't like the HET all that much, the 3 I have owned all took considerable work to be balanced properly, one of them had an out of round collet and motors like the Neu 11 series and Lehner 15 series won't fit it. I much prefer the Wemo that runs silky smooth out of the box. It just feels like the quality is better.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Oct 19, 2009, 05:57 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i like my HET better than the wemo ,the HET is faster but pulle a few more amps ...i guess it depends on what you use it for.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 19, 2009, 06:16 PM
United States, VA, Suffolk
Joined Jun 2009
Pete at Hoffman recommends the Wemo fan. I have one with a Hoffman Wild Beast on my Sapac L-39 on 4s 3600. Pete claims the HET will pull more amps and that's not what you want. I am using a CC125 and getting 1900 watts. On a 4 lbs plane it is insane fast. Timer is set for 4.5 min and getting it, no problems. Make sure the fan does not break itself in by rubbing on the shroud. This will destroy the motor. Ask Pete!
Jay H
jayjet is offline Find More Posts by jayjet
Old Oct 19, 2009, 07:25 PM
Mark Huffman's Avatar
Gilbert, AZ
Joined May 2008
I've gone through a couple of HET fans and have not been that happy with them. If the Wemo was available, I would take that one instead.
Mark Huffman is offline Find More Posts by Mark Huffman
Old Oct 19, 2009, 07:53 PM
Matrix 90 & 100mm sport jet
Getmore Rc's Avatar
Merritt Island Fl
Joined Aug 2008
I will take a wemo over het. they just seem to go together
better with less work and great sound to boot.
Getmore Rc is offline Find More Posts by Getmore Rc
Old Oct 19, 2009, 08:06 PM
United States, OK, Oklahoma City
Joined Apr 2009
I would go for the Wemo, if you could find them. Who carries them in the US besides EJF anyway?
reg
flyregfly is offline Find More Posts by flyregfly
Old Oct 19, 2009, 08:16 PM
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Jay H
Hi Jay,
In general I prefer the WeMo. It is a lot easier to seat and run in. Guys like Roger have probably done many, many of fans. Hell he could probably make my ceiling fan run smooth. The reason I say Wemo is it is a lot easier to run in and make work properly where the HET is a lot more work in my opinion.
Yes it is a more agressive fan and does pull more amps but I have had two go off in my hand. (I know)
Pete
hole digger is online now Find More Posts by hole digger
Old Oct 19, 2009, 08:20 PM
Faster!
Joshua Wesley's Avatar
United States, NV, Sparks
reg
http://shop.chuckshobbies.com/produc...&categoryId=59
Joshua Wesley is offline Find More Posts by Joshua Wesley
Old Oct 19, 2009, 08:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Jet Hanger Hobbies has them too ,thats where i got mine .
Old Oct 19, 2009, 08:34 PM
Long Island
Joined Apr 2007
wemo or het
I have both I perfer the het I have the het in my 33" ray on 5000ma 4 cell battery runs smooth and sounds great
dcala is offline Find More Posts by dcala
Old Oct 19, 2009, 10:19 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
plus one to the above.so far the set up i have now is the smoothest fan i've had .....i like the collet adaptors better than set screw one's ...just my .02
Old Oct 20, 2009, 12:00 AM
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I just put a HET in my sapac L-39
havn't flown it yet ... but it's silky smooth and sounds cool for a 70mm
I also like the collet over the set screw
I put a Neu 1112 1y in mine with a CC ICE 100 and a 4s 35c 4200 hyperion
95 amps burst to 1350 watts
steady 85 amps and 1250 watts
Ron101 is offline Find More Posts by Ron101
Wanted HET or Wemotec 70mm fan - NIB snoshoe62 Aircraft - Electric - Jets (FS/W) 1 Jul 19, 2008 12:51 AM
Found 70mm fans - Wemo or HET - robert53 Aircraft - Electric - Jets (FS/W) 0 May 16, 2008 10:44 AM
Wanted Kontronik 480-33 & HET 70mm fan flanker Aircraft - Electric - Power Systems (FS/W) 0 Mar 20, 2008 03:01 PM
Question Wemo or HET fan? mdlifcrisis Electric Ducted Fan Jet Talk 36 Dec 26, 2007 12:52 PM
Found Need wemotec mini or HET 6909 fan and UBEC Ebolavoodoo Aircraft - Electric - Power Systems (FS/W) 0 May 10, 2007 04:23 AM
