Old Jun 25, 2016, 12:40 PM
jajefan is offline
Find More Posts by jajefan
Novice Pilot
jajefan's Avatar
Joined May 2016
Question
Getting a second plane: The Bix3? Or something else?
In my last thread, I got some advice, and now, I'm formulating my plan to get a second plane:
https://docs.google.com/document/d/1...it?usp=sharing
Heres the list in case you didn't want to click on the link:
http://www.hobbyking.com/hobbyking/s...dproduct=58883
Turnigy 2200mAh 3S 25C Lipo Battery - American Shipping
http://www.hobbyking.com/hobbyking/s...dProduct=65278
HXT900 9 Gram servo (x2) for flaps - American Shipping
http://www.hobbyking.com/hobbyking/s...dproduct=74579
Bix3 Plane (PnF) - American Shipping
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Adaptor for UBEC-American Shipping
http://www.hobbyking.com/hobbyking/s...dproduct=64374
UBEC - American Shipping
http://store.flitetest.com/battery-voltage-alarm-1-8s/
Voltage checker/alarm -American Shipping
https://www.amazon.com/gp/offer-list...&condition=new look for $3.25; ships from texas
http://www.ebay.com/itm/Original-iMA...QAAOSwYudXGLvd
iMAX B6 Charger
http://www.ebay.com/itm/12V-5A-AC-Po...8AAOSwstxVZpFR
Charger Power Supply
http://www.ebay.com/itm/Spektrum-DX6...oAAOSwe7BWyNGZ DX6 With Receiver
https://www.amazon.com/Prop-Spinner-...SDPYYBD3YCQWA9
Sport Cub S Extra Propeller
Later On
FliteTest Beginner Swappables -All American Shipping
http://store.flitetest.com/lumenier-...-battery-xt60/
Battery for Planes (XT-60)
http://store.flitetest.com/power-pac...ed-wing-small/
Electronics for Swappable Fuselage
http://store.flitetest.com/3-pack-sw...eed-build-kit/
3 Beginner Air Frames
is this a good setup or not? I pretty much have mind set on using the external ubec now.
Update #2: Now I'm trying to decide between the two batteries listed... Accucell S60 or the iMAX B6 charger?
I've seen some videos of what Brownout looks like and I fear that based on the information I was given in the previous link, the 2A linear BEC in the Bix3 won't be enough for 6 servos.
Another option would be to buy another ESC with an adequate BEC rating (5+Amps), but I'd have to look around for one.
Update: Found one! http://www.hobbyking.com/hobbyking/s...dproduct=65291
SBEC with 3A/5V and 20A esc, looks like it might be good. (But how would I rip out the esc already on Bix3?)
The plane is only my second plane, so I have no previous experience regarding electronics. I think my sport cub s might've had a few brownouts (or were they radio link losses? not sure) at times, and generally it took about 3-4 seconds to recover, but I'm not so sure with a Bix3.
Any help would be greatly appreciated as to whether or not I should worry about Brownouts in the plane, or whether to just scrap this plan entirely and go with scratch-building with flitetest supplies.
jajefan is offline Find More Posts by jajefan
Old Jun 25, 2016, 01:56 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
You can use an external BEC or a receiver pack to power your receiver/servos . If you do , be sure to disable the red wire going from the ESC to the receiver .
http://www.hobbyking.com/hobbyking/s...dProduct=33274
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jun 25, 2016, 02:21 PM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
Would this be too much of a hassle to always worry about two batteries for both components of the plane so that I be better off just getting the ESC with the better BEC that was mentioned in my post?
Or is this trade-off worth the hassle of always charging 2 batteries?
Old Jun 25, 2016, 03:51 PM
Joined Aug 2010
An external BEC runs off the same battery . For expensive airframes I use external BEC's , for home-made Dollar Store Foam planes I don't .
Old Jun 25, 2016, 08:38 PM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
How would I make this happen with the Bix3? Bix3 runs off 3 cell but the 1300 is a 2 cell, and the included ESC is a XT60 connector
sorry, I'm just particularly new to this and don't know how i would set this up. All I know is to plug a battery into an ESC and make the plane fly
Old Jun 25, 2016, 09:46 PM
kaptainkruton is offline
Find More Posts by kaptainkruton
Joined Dec 2013
If you were to use a connector similar to the one shown in BalsaOrCarbon's picture, you could eliminate the 1300mah 2s pack. You would draw power from your 2200 3s. All of the plane's electronics are powered by one battery. It is hard to see in that picture, but that connector consists of a male and female battery connector. One side plugs into the battery and the ESC plugs into the other side of it. So the current that powers the plane just passes straight through it. That connect also has two wires that branch off and go to your BEC. This lets the BEC draw power from the battery as well.
Here is one at hobbyking with XT60 connectors: http://www.hobbyking.com/hobbyking/s...arehouse_.html
If you do decide to use an external BEC, instead of the one built into the ESC, you will probably need to disconnect the red wire from the ESC that plugs into the receiver to avoid giving the receiver power from two separate sources. Also, If you do get the external bec you mentioned, it doesn't appear to come with any type of plug/connector to attach it to the power source.
kaptainkruton is offline Find More Posts by kaptainkruton
Old Jun 25, 2016, 09:53 PM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
Ah, that cleared it up a lot.
Thanks!!
What about the ESC with the SBEC inside of it? Would that be another viable option?
Also, is there any comment regarding the rest of the items on the list? Or is the list already a good setup for getting started?
Old Jun 25, 2016, 09:58 PM
Joined Aug 2010
Use this adapter between the ESC and battery , then connect the external BEC to the JST ( small red plug ) .
http://www.hobbyking.com/hobbyking/s...r_Adapter.html
Old Jun 26, 2016, 11:11 AM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
Thanks for the help you guys! I have finally finalized my list with the two recommended items.
One last question:
Can someone look over it to see if it's a good setup or not?
Old Jun 26, 2016, 04:06 PM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
Sorry for the double post/bump, but I am sort of in a time scrunch and want some feedback on my finalized list.
Old Jun 27, 2016, 05:38 PM
Mac50L is online now
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
It appears the question is, should you be using a separate BEC for the servos.
My Bixler V1.1 has gone from a 30 Amp ESC running one motor to two 20 Amp ESCs running twins. Only one of those ESCs runs the servos. OK, only 4 servos but a servo is only drawing current when moving so a couple of extras on the flaps shouldn't make any difference.
My setup, 2 - 19 g motors, 2 - 20 Amp ESCs, 4 - 9 g servos, 1 - 2200mAh 3S battery. I have sometimes used a couple of extra servos for dropping things which would be the same as a couple for flaps.
Mac50L is online now Find More Posts by Mac50L
Old Jun 27, 2016, 08:37 PM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
Question is,
Have u ever browned out?
Just had a horrific crash this evening with my sport cub s due to stupid decisions.. (I put a Bluetooth Tile-finder thing on top of my plane ---- and Bluetooth uses 2.4 GHz---so you know what happened) . I don't want to make any more
Also, if you can, can you make any comments about my list of items that I'm buying? That's my real concern now before buying anything.
Old Jun 29, 2016, 12:19 AM
Joined Oct 2011
Question is,
No.
Your "brownout" if due to Bluetooth wasn't a "brownout" but interference and a EBEC won't make any difference to that problem.
Two chargers, I use an Accucell but not that model and it works well.
Y XT-60 cable - Why? Unless you are going to fly a twin?
There is a cheap HK tool (sort of plastic pliers) which makes unfastening XT-60 connectors very easy.
Swappables - you can make them much cheaper than that ($30), Nutball, Dart-XS (FT Flyer) and Delta. An airframe is so cheap I leave one (Dart-XS which I flat-packed over there) in Australia and fly it when over there, probably about $6. Also the nose is too short on the FT Flyer, make it an inch longer at least so the battery can go further back. Make sure the fuselage is wide enough for the battery you are going to use, plus about 5 - 10 mm because the leads come out of a battery sideways a bit.
My Darts use a 19 gram motor, will fly gently on half throttle or go berserk with an open throttle - wild aerobatics. Battery, 800mAh 2S. I use a 3S on the biplane with the same motor.
Old Jun 29, 2016, 11:39 AM
jajefan is offline
Novice Pilot
jajefan's Avatar
Joined May 2016
No.
Thanks for the suggestions
Sorry I didn't clarify this, I was just asking if you've ever browned out while using your built in BEC
The Bluetooth tile interference had nothing to do with it :P ^_^
The Y-harness is for the UBEC im buying. I'm just gonna use the same battery to power both BEC and ESC but the BEC doesn't have a pre-soldered connector, so I have to buy a Y-harness and some XT-60 connectors to solder on to the BEC (ESC already has XT-60).
Also, for buying the FT- Swappables is mainly due to convenience. I want to start scratchbuilding, but my ideology is that I don't want to start off by trying to get different frame parts when they all come in a nice package like the 3-pack bundle (btw, that's probably one of the only airframes I'll ever buy from FT, as I do like the premise of using $2 airframes), and plus, I like like 20 minutes from their HQ; shipping will cost nothing.
Old Jun 29, 2016, 03:10 PM
Joined Aug 2010
All those Y harness thick wires and XT-60 plugs will be heavy and take up a lot of room in the BIX , I recommend using these to connect the external BEC :
Discussion FinWing Penguin.. as a secondary fpv plane?? Or an AXN? Or bix3... nilshv Electric Plane Talk 8 Jun 02, 2016 05:25 AM
Discussion Question on going one level to the next Quadrophenia Multirotor Beginner 28 Apr 21, 2016 12:14 AM
Question Question about the "NEXT STEP" to take in RC flying. Desync Multirotor Beginner 12 Jan 16, 2016 02:48 PM
Help! Bix3 arf build for first plane rohnramirez Beginner Training Area (Aircraft-Electric) 6 Dec 09, 2015 07:58 AM
my next plane... big question... hogfarmer Sport Planes 28 Nov 02, 2004 08:15 PM
