Old Apr 17, 2016, 02:08 PM
Snetzka is offline
Find More Posts by Snetzka
Snetzka's Avatar
Auckland.
Joined Jun 2010
Idea
Laminating Products.
Well last week I got given the task of laminating some passes for an event which got me thinking...
For those of you blissfully non aware of Laminating pouches - they are basically two sheets of plastic (80 or 125 microns thick) with adhesive inside. There are two variants Hot or Cold set.
The hot set (which is the type I am using) are passed through a set of heated rollers which compress and heat at the same time, the glue melts and the two half's are bonded together. Normally a photograph or document is inserted between the two sheets which is then protected from the elements when sealed.
The cold set type is similar except heated rollers are not required and they work on pressure.
Anyway... looking at the heating device it was obvious I was not going to get anything thick into my plastic sandwich (like Carbon Fibre rods..)
So a quick experiment with a household iron and two tea-towels proved the process.
The photos continue the story...
Disclaimer -
This is an idea for discussion - I am not saying it is a perfect solution to anything... But with this product available in sizes up to A0 that's enough to produce a half / wing.... or as a stiffener bonded to existing wings... Food for thought....
Snetzka is offline Find More Posts by Snetzka
Old Apr 17, 2016, 02:52 PM
ZTEX is offline
Find More Posts by ZTEX
Joined Aug 2013
Very good idea !
Bravo!
I think that lamination sheets in different colors are available as well .
ZTEX is offline Find More Posts by ZTEX
Old Apr 17, 2016, 04:05 PM
ZTEX is offline
Joined Aug 2013
Here is an extension to the lamination idea .
This is about the technology of executing that with perfect smoot surface result.
It's a combination betwin lamination and vacuum bagging .
As is evident from the skatch there are two rectangular wooden frames and the laminating foil is pretightened on them. Just put the CF wing/ tail frame betwin foiled frames with foiled parts against each other . Pull the air out with large plastic syringe. The vacuum betwin lamination sheets and ambient air pressure will do the rest of the job.
The above instructions aren't tested yet
Old Apr 17, 2016, 10:42 PM
therealthing691 is online now
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
Great ideas Mike and a harder/stiffer medium makes sense I think it might produce better thrust if used on a wing
therealthing691 is online now Find More Posts by therealthing691
Old Apr 18, 2016, 06:40 PM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Interesting
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Apr 24, 2016, 08:41 PM
Snetzka is offline
Snetzka's Avatar
Auckland.
Joined Jun 2010
Managed an hour at the local field this morning, testing the laminated tail. Its a lot stiffer than the standard tail assembly and needed to be lowered considerably before the bird flew at a respectable angle... But once the correct angle was found it proved to be very good.
Could be a quick / easy tail assembly, and seems very strong..
Old Apr 25, 2016, 01:14 AM
australia
Joined Apr 2007
the setup you have designed I think will work well .I think I will try that on the tail to get used to the laminating material then I would love to try a wing out of it
cheers Brian
Old Apr 26, 2016, 12:02 AM
Snetzka is offline
Snetzka's Avatar
Auckland.
Joined Jun 2010
For those of you wondering about the compatibility of Rip-stop nylon and the laminating material as i was...
Experiment today was laminating both sides of the rip-stop (i.e Rip-Stop sandwich - RH side of photot) and single sided (one side of laminating material - LH side of photo) on to Rip-Stop.
Well the sandwich adhesion is very good, as is the single side. (The strange pattern on the single side is from the glue melting into the tea towel )
Wings look do-able Brian...
Old Apr 26, 2016, 04:46 AM
australia
Joined Apr 2007
oooooo aaaaaa better hide the tea towel sounds good Mike . regards Brian
Old Apr 26, 2016, 07:04 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Don't know if it's the same stuff, but you can get Doculam ,or other name brands, from Staples. This comes in 13 to 18 in. rolls. It's a stickyback film where you peel the back off and stick it on whatever you want. I use it on foam for a smooth finish and strength.
Can be painted on directly.
I can see it being used for this, with the carbon rods for shape, etc.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Apr 26, 2016, 09:02 PM
Wid is offline
Wid
Find More Posts by Wid
Wid
Live Your Dreams
Wid's Avatar
United States, CA, Redwood Valley
Joined May 2001
Laminating Film source
I have just started using laminating film for dynamic soaring EPP foam gliders. It has AMAZING potential .
My ideal orni will be able to fly beside a glider like this (6 lb, 60"), just as the Ravens were out flying me yesterday. But this 6 seconds shows how tough lam film can be and this is a link for Aloft Hobbies that sell the stuff here. Heat activated adhesive.
JW crash, bounce, bounce, bounce, recover (0 min 7 sec)
Wid is offline Find More Posts by Wid
Idea cobalt-iron lamination, new/other statordesign Ron van Sommeren Electric Motor Design and Construction 67 Jun 18, 2015 05:13 PM
Wanted 1.2 CP lamination film from laminator warehouse KenSt Aircraft - General - Miscellaneous (FS/W) 3 Jun 01, 2009 07:14 PM
Discussion Stator laminations - rewinding production motor nitrofreak Electric Motor Design and Construction 4 Mar 16, 2008 07:32 AM
stator lamination production with wire EDM Ron van Sommeren Power Systems 2 Dec 27, 2006 08:44 AM
