Old Nov 03, 2013, 07:00 PM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
Some progress on the wing. Retract mount and both servo hatches.
tsymonds is offline Find More Posts by tsymonds
Old Nov 06, 2013, 10:26 AM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Got the bottom of one panel fully sheeted. Next will be the wheel cutout and mounting the servos to the covers. I intend to make some paper tubes that'll go inside the wing for servo and motor leads similar to the ones I made for the tail but a bit smaller. Those will run through the existing lightening holes in the ribs.
Old Nov 06, 2013, 03:05 PM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Looking good Tim keep on plugging away
CapMike is offline Find More Posts by CapMike
Old Nov 06, 2013, 05:20 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Thanks Mike. Been real busy at work lately but I've been trying to at least get something glued, shaped or sanded each evening. I think I'll start getting the othe wing panel to the same point as this one since it's still just a frame and then go from there.
Old Nov 09, 2013, 06:21 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Got the nacelle stringers and formers dry fit together. Also got the left main gear cutouts done and the gear working. Flap and aileron servos have been mounted to the covers, paper tube conduits installed and the leads run.
Old Nov 09, 2013, 06:28 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Here's the wing shots.
Old Nov 16, 2013, 08:48 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
One down. Three to go. Still needs some finish sanding and some lightweight balsa filler for some small imperfections.
Old Nov 17, 2013, 06:39 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Looking really good on that Nacelle Tim. You had the pre-cut planks for the nacelles is that correct? Remember your going to still need a little filler once the nacelle is on the wing to fair it in. I am liking the looks it is taking. I need to get busy with mine and get it built.
Old Nov 17, 2013, 08:11 AM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Mike,
There were no precut planks in my kit. I wasn't aware that there was supposed to be any either. I made my own planks with a balsa stripper and they were all hand sanded and fitted. Might explain why it took me three evenings to plank one nacelle.
Old Nov 17, 2013, 09:17 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Tim I think that may be an option
Old Jan 06, 2014, 09:41 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
And now back to our regularly scheduled program. After a bunch of work related delays, visits from relatives, the holidays, sick kids, the missus and myself getting both the flu and an eye infection etc. I'm happy to be back to the usual grind. Not a lot to report as of now but I did manage to get a good portion of the fuselage planked over the last few evenings as well as the steering servo mounted with its linkage to the nose wheel.
Old Jan 06, 2014, 09:58 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Looking good Tim. I am looking forward to cutting some new parts and getting mine built
Old Jan 11, 2014, 12:45 AM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Some more progress on the fuse.
Old Jan 11, 2014, 08:37 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
AH the joys of planking. Once in the zone they planks seem to lay themselves into place and the outside world no longer invades ones senses
Old Jan 11, 2014, 10:02 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Fuse planking mostly done. Decided to mock it up for motivation.
Discussion My new AP platform is taking shape... Phil R Aerial Photography 2 Jul 22, 2007 10:17 PM
New AP ship taking shape..... randall1959 Aerial Photography 37 Jul 09, 2005 11:40 PM
New ME262 takes shape Larry Dudeck Electric Ducted Fan Jet Talk 0 Jan 28, 2005 07:01 AM
New EDF takes shape winmodels Electric Ducted Fan Jet Talk 70 Dec 09, 2004 01:10 AM
