Old Mar 30, 2013, 01:18 PM
Willj is offline
Find More Posts by Willj
vancouver,B.C
Joined Apr 2008
transmitter on and motor runs?
Hi Guys.
I`m a little confused again. Why does the motor run when my tx is on?
I can`t get a neutral setting on the trim. I have to push the stick all the way down
to stop the motor. I`m trying to set up the esc. The last thing to do. Thanks
Willj is offline Find More Posts by Willj
Old Mar 30, 2013, 02:35 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Finish setting up the esc.
patmat2350 is offline Find More Posts by patmat2350
Old Mar 30, 2013, 09:02 PM
Willj is offline
vancouver,B.C
Joined Apr 2008
IT`s difficult to set up the esc when I cant really slow it down effectively, to a neutral point.
Has anyone else experienced this syndrome?
Old Mar 30, 2013, 09:45 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Unplug the motor, not needed for set up.
Old Mar 30, 2013, 10:08 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Did you swap the rudder servo into the throttle port on your receiver, to confirm that you did not get any radio damage, when you shorted your batteries? Also, some of the new SMART, auto set-up, ESC's, do not like working with some of the older style radios. As I noticed that yours was either on 75 or 27. Also, is it a major brand ESC, or something salvaged, or from HK? All this, makes a BIG difference. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Mar 31, 2013, 05:58 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Best thing is to read the set-up instructions for the ESC. This normally involves turning on the TX first, setting the chosen stick to the desired neutral, then switching on the RX/ESC. The ESC (if its a modern one) could give you a couple of seconds to press a button to put it into training mode. In that mode, it will expect to be presented with neutral, it will then want to be given full forward, then full reverse. Earlier generation ESCs might have a pair of trim pots to do the same job. The instructions will usually give the answers.
It is a marine type, and not a forward only flight type, isn't it?
mfr02 is offline Find More Posts by mfr02
Old Apr 01, 2013, 04:05 AM
Willj is offline
vancouver,B.C
Joined Apr 2008
It is a marine esc. Expensive at that. The tx cost 70.00. It`s probly crap
Once I charge up my batteries and find some time, I`ll give it another go.
Thanks for the tips guys. appreciated.
Old Apr 01, 2013, 08:13 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
Another set-up muck-up I've run into is having the servo reverse on that channel of the TX set to "rev" and not "nor". Trying to set up the ESC like that is, as I found, futile.
Discussion 9.6 volt motors running on 12 volts? dash8man Scale Boats 4 Mar 18, 2013 05:50 PM
Wanted WTB: cheap 21.5 motor than can run on 3s lipo arnie84 Cars - Accessories (FS/W) 0 Mar 05, 2013 08:47 AM
Question Why certain motors run on 4S-5S vs 3s mag1 Power Systems 9 Mar 01, 2013 07:02 AM
Question is it ok to run motor with no prop? philliebo Power Systems 19 Jan 24, 2013 11:00 AM
What happens when you run out of model memory on your Transmitter??? Ralph_D Parkflyers 27 Dec 20, 2003 07:50 AM
