Old May 07, 2012, 03:07 PM
allgie is offline
Find More Posts by allgie
Joined May 2012
Double horse 9053 TX
Hi there, can anyone tell me if the 27.145 frequency is am or fm on this chopper?
I have a 4 chanel e sky transmitter which I would rather use, is it simple to just put the 27 MHz crystal in and fly the 9053?
allgie is offline Find More Posts by allgie
Old May 07, 2012, 04:38 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Likely same as my DH9104. ON/OFF carrier modulation, guess you could call it AM. Proper name I suppose is continuous wave.
The receiver is super-regenerative (super-regen) and does not have a crystal. It has a tuned front end feeding what looks like a common base transistor pre-amplifier. Actually works very well considering the simplicity.
The ESky transmitter would have to be on the 27MHz band and if it is ON/OFF keyed carrier, then just a matter of re-tuning the receiver coil at the antenna wire on the helicopter.
However, the DH9053 likely also transmits control information by 4 channels, in 6 bit binary with a parity bit.. ESky transmitter not likely to work. I wouldn't even try.
Ribble is offline Find More Posts by Ribble
Question Double Horse 9053 Battery help... ckanroh Coaxial Helicopters 5 Jan 02, 2013 10:44 AM
Found Main Gears For 9053-03 Double Horse 9053 Helicopter irun4fundotca Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 22, 2012 01:29 PM
Gallery Double Horse 9053 Volitation ckanroh Coaxial Helicopters 0 Mar 01, 2012 10:39 PM
Discussion Double Horse 9053 Volitation ckanroh Beginner Training Area (Heli-Electric) 0 Feb 29, 2012 09:54 PM
Help! 9053 double-horse patties Coaxial Helicopters 0 Feb 29, 2012 06:11 PM
