Old Dec 19, 2010, 04:36 PM
AAA100 is offline
Find More Posts by AAA100
AAA100's Avatar
United States, OK, Norman
Joined Aug 2008
900mhz Yagi mounting
I just received my new 10dbi yagi/900mhz from DPCAV.com . I have extended the backside of the square tubing of the yagi with a piece of aluminum angle, about 12" long, for mounting the receiver and battery. My question: Will the extra piece of aluminum angle interfere with the reception? If so, can I use a piece of wood or something instead of the aluminum angle?
Thanks, Brian
AAA100 is offline Find More Posts by AAA100
Old Dec 20, 2010, 01:21 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
I think you look good except for your video rx looks like a not good one and will be a bad situation
the whole set up is positioned well
make sure your video voltage for the video rx stays up and does not fall
a good steady voltage is imporatant for all components and many people underestimate the video rx voltage requirements
everything has to have the volts and not everyone talks or thinks of the video rx volts and miss this very important requirment, a very underestimated requirement
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 20, 2010, 01:57 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The extra beam, probably not a problem. The metal case of the Rx itself, could certainly
interfere with the radiation pattern.
ian
Daemon is offline Find More Posts by Daemon
Old Dec 20, 2010, 06:47 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Why do you say that David?
Blue Chip is offline Find More Posts by Blue Chip
Old Dec 20, 2010, 06:53 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
If that is the 4 channel from DPCAV IBCrazy says it is pretty good....? At least to him?
Derek_S is offline Find More Posts by Derek_S
Old Dec 20, 2010, 08:08 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The RX location is probably fine. It's behind the reflector. It should be ok there. There is no way to get it completely out of the radiation pattern.
The 4 channel RX from dpcav is a decent unit. It's sensitivity is fair. It could be a bit narrower, however. But I can't complain. You can replace the SAW filter, I guess, but I'm 2 for 4 on that mod. I got one working great, one working ok, and two dead ones. This coming from a guy who has a professional soldering station and many years experience...
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Dec 20, 2010, 09:48 AM
David22 is offline
Joined Apr 2008
only reason being that i have tried some not so good video rx's and found others to be much better
maybe that is a good one but others claim to have had problems with 900 due to poor quality products.
and wish for higher quality 900 systems
personally i never tried that rx but maybe something to concider
For Sale New DPCAV 900Mhz +10dbi Yagi $32 Shipped cbcalhoun FPV Equipment (FS/W) 1 Dec 01, 2010 12:35 AM
Discussion 900mhz Yagi Blue Chip FPV Talk 18 Nov 30, 2010 09:00 PM
Discussion 900mhz inverted y yagi diys tconners FPV Talk 2 Oct 16, 2010 12:10 AM
Link For Trade - My 900mhz Yagi for your 900mhz Patch EyeFlyPlanes FPV Talk 2 Mar 23, 2010 07:18 PM
Discussion How to build a 900mhz yagi antenna? JustinONE FPV Talk 14 Sep 12, 2008 11:32 PM
