Old May 02, 2009, 05:59 PM
n111kx is offline
Find More Posts by n111kx
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Golden Eagle Model F-16CJ Build Thread
I got my "16" and it's time to get started
What's in the box...
n111kx is offline Find More Posts by n111kx
Old May 02, 2009, 06:06 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Getting started.
The first thing the plans call for is to get the decals on. It takes a bit of technique to look good as they are fragile when wet but it's a quick learn. As I am impatient a few are not pretty or scale but I'll still sleep at night.
The foam parts come out of the mold in pairs so it's a simple task to cut them off and file smooth.
Next, the builder must cut off the control surfaces and hinge them a lot like a balsa model that I am used to. No problems here.
Old May 03, 2009, 05:49 PM
head-wind is offline
Find More Posts by head-wind
Joined Mar 2009
could we have some photos of
1/ fan location (with fan in place)
2/ battery location (with pack in place)
3/ and the ducting.
thanks.
BTW,
1/ how big is the housing of the fan? can it
handle 36mm motor? or only 28mm motor?
2/ how big is the fan's adaptor ? 1/8'? or larger?
head-wind is offline Find More Posts by head-wind
Old May 03, 2009, 06:54 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
I'll get back with you on that with pics soon. I can tell you that the fan mount has a fore/aft provision to allow for CG change. Also, the battery compartment seems fairly large and will accomodate many sizes.
The only thing I don't like with the ducting at this point is that it seems that is glued on so fan access would involve cutting a glued joint...
Pehaps the manufacturer will step in here as I am reluctant to disassemble a factory balanced fan unit to check specs. The outside diameter is about 86mm...
3/ and the ducting.
thanks.
BTW,
Old May 04, 2009, 11:42 AM
pathelihk is offline
Find More Posts by pathelihk
pathelihk's Avatar
Joined Jun 2008
Motor Specs.
The motor is 28mm(Diameter)39mm(Length) 2600kV , (Specifications are subject to change without notification). The Fan is patent pending, I was told, and since the fan is not available separately, it is better to leave the fan system alone, as it's glued to the shaft of the motor after it's factory balanced. Revs up to 30,000 on 4S, around 40A pulling about 1.0 Kg, almost 1:1 power to AUWeight ratio.
pathelihk is offline Find More Posts by pathelihk
Old May 04, 2009, 01:30 PM
Joined Mar 2009
".... since the fan is not available separately...."
that is no fun at all.
Old May 04, 2009, 05:25 PM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
Cant wait to see this one.
ozzi supercub is offline Find More Posts by ozzi supercub
Old May 05, 2009, 08:07 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
I'm not a fan of the F-16 but I have to say that's one darn fine looking model. That fan is interesting too. I like the way the wires are routed and secured to the housing.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old May 05, 2009, 08:16 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Well after much talking to curt at easy tiger, the fan WILL NOT be made available to the public unless you buy the 16 or the new sabre. I think its a bad idea cause what happens if you ruin a fan??? I wanted to buy two to test on high watts. They look well built and the pitch doesnt look bad at all. Being 8 blades it will probably be more like the sickle fans. They sound wicked and really put out the power at a respectable amp draw similar to a HET fan.
What a shame though. He could be making more money off of these.
lavochkin is offline Find More Posts by lavochkin
Old May 05, 2009, 08:20 PM
lavochkin's Avatar
Joined Oct 2006
This is the most scale f-16 I have seen so far. Too bad it didnt retract those gear though. The shape is perfect though.
Old May 06, 2009, 07:03 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
lavochkin-
Is this GE Model the one Curtis has on his site?
EDIT - nevermind - I see that info in Post #1.... I need to read closer.
Nice Jet..... time to order.
kydawg1 is offline Find More Posts by kydawg1
Old May 06, 2009, 07:05 AM
kydawg1 is offline
kydawg1's Avatar
Joined Mar 2007
What is your overall impression thus far? Quality? Build? etc
Old May 06, 2009, 07:19 AM
WiggleWiggleWiggle
South Australia
I am no scale expert but does this mean it will be a handful to fly because it is so scale?
Old May 06, 2009, 07:30 AM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
I'm not a big foamy fan but and this model looks too good to ignore as an F-16 lover. I have built and flown 40+ models since 1984 and completed two Famous F-16's in recent months. The Golden Eagle is way above that model in fit and finish. So far, I'm not sure what I would change given the chance (except perhaps gluing the duct but we'll see as I'm not there yet). All parts have fit perfectly and I have noticed great attention to detail. After building two full -scale hombuilt aircraft also, I find myself noting how difficult it would be to engineer some of the details on this thing. I'll be back building tonight. I'll take lots of detail pics when it's done...
Kip
Build Log F-16 Build Thread Thomas Nelson Foamy EDFs 598 Oct 14, 2015 10:22 AM
GAD Northrop F-5a build thread roccobro Pusher Prop Jet Models 172 Dec 27, 2008 09:59 PM
Discussion micro F-16C *build thread* customminatures Scratchbuilt Indoor and Micro Models 2 Dec 18, 2006 09:33 PM
P/F-80 Build Thread....the beginning... Kirkgh Slope 53 Nov 19, 2004 12:37 PM
Jet Hanger Hobbies F-14 build thread? speleopower Electric Ducted Fan Jet Talk 14 Jul 23, 2004 03:48 AM
