Closed Thread
Old Sep 04, 2014, 10:36 PM
rrothman's Avatar
Joined Nov 2011
Help!
Guardian Stabilizer not working - LED flashing
I just noticed while working on a fuel problem I had no elevator, rudder or aileron control, the servos are jittering (digital) like normal, then I notice the Guardian LED is just flashing no matter which mode I put it in or even if I turn the 2D/3D off.
I hooked up to my PC and everything looks normal - LED flashes 3 times, horizon moves. I did a factory reset and put back in plane, same problem. I know the battery is good and the radio is putting out signals (9X with monitor to see channel activity). If I bypass the Guardian putting servos directly into receiver all is well.
With Guardian powered up on a receiver all by itself, just constant flashing.
Not getting the 4 long flashes followed by the error code, just constant steady fast flash.
rrothman is offline Find More Posts by rrothman
Last edited by rrothman; Sep 04, 2014 at 10:40 PM. Reason: change from discussion to HELP
Old Sep 05, 2014, 09:27 AM
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
Can you please open a support ticket on our website? We will help you get it sorted.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Sep 05, 2014, 10:16 AM
rrothman's Avatar
Joined Nov 2011
Done, ticket #151095!
Old Sep 15, 2014, 10:19 AM
rrothman's Avatar
Joined Nov 2011
got the replacement from Eagletree this weekend, great service!
Closed Thread
Discussion Hitec Flash 5 -throttle not working cvint Hitec/Multiplex USA 3 Apr 26, 2014 05:46 AM
Discussion Guardian 2d/3d not working correctly on a Stryker F27Q MichaelT1960 Eagle Tree Systems 9 Nov 14, 2013 07:48 AM
Discussion Guardian Expander not functioning-led flashing MrMum Eagle Tree Systems 6 Jun 04, 2013 05:48 PM
Help! Support Ticket [#579924] Guardian Stabilization don't work properly‏ cesarjuliogm Eagle Tree Systems 4 Oct 23, 2012 12:21 PM
Discussion Aileron Does Not Work with Guardian texasdrifters Eagle Tree Systems 4 Jul 20, 2012 03:53 AM
