Old Sep 10, 2014, 04:22 AM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
How to arm a Naze 32?
Title says it all. Cheers
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Old Sep 10, 2014, 05:07 AM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Same as the multiwii.
You can also assign it to a switch if you wanted.
Hajile is online now Find More Posts by Hajile
Old Sep 10, 2014, 05:14 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Awesome thanks
Old Sep 10, 2014, 05:25 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Hmm still not working
Old Sep 10, 2014, 07:15 AM
Joined Jul 2012
Try calibrating the Gyro and Accelerometer and that you have it on a flat surface. If it's like the multiwii (which it's based on), it will not arm if it thinks either of those two are giving off unusual readings. Haven't needed to recalibrate on my Naze32 yet, but my multiwii needed it done before it allows itself to arm. I think that's why the calibration can be initiated from the sticks.
Old Sep 10, 2014, 08:43 AM
Don't be popular, be right.
United States, FL, Port St Lucie
Joined Aug 2004
Also make sure your radio endpoints are below and above the min and max check values. Should be 1000-2000 with 1500 as center or as close as possible. Also if you've setup an arm switch I believe the stick commands stop working.
bigddybn is offline Find More Posts by bigddybn
Old Sep 10, 2014, 08:48 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Alright I'll try it out tomorrow
Old Sep 10, 2014, 10:15 AM
FPVGuerilla
United States, VA, Chester
Joined Jan 2012
Good info, thanks
I will be setting up my first Naze32 this week
Markw177 is offline Find More Posts by Markw177
Old Sep 12, 2014, 03:50 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Still can't get it to arm? I'm using a range Link RX and PPM. I just plugged it in and typed in some initial PID settings.
Old Sep 12, 2014, 04:00 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
I calabrated it on my PC but it still won't arm? I have a solid blue light..
Old Sep 12, 2014, 04:19 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Alright I got it to work with PPM. But now my pitch is on the roll channel, Roll is on throttle and throttle is on pitch! WTH How do I change that?
Old Sep 12, 2014, 04:33 AM
Joined Jul 2012
You'll need to use the CLI tab
How to setup a Naze32 Acro / Funfly Flight Controller (49 min 41 sec)
See 42:55
Don't forget to save
Old Sep 12, 2014, 05:04 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Yes got it to work! Thankyou so very much Hajile!
Old Sep 12, 2014, 06:08 AM
United States, FL, Port Orange
Joined Jul 2014
Yes watch Mochaboys vid, helped me out a lot !!!!
ZipSnipe is offline Find More Posts by ZipSnipe
Old Sep 12, 2014, 06:28 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Well I changed the channels over but it still won't arm! I have it set on AUX1 and still nothing! If I direct both stick at the top of the pot a yellow light flashes a couple of time....
Found Naze 32 Case Air_Screw Aircraft - Electric - Multirotor (FS/W) 4 Dec 11, 2014 04:40 PM
Discussion Naze 32 - Wont arm Ground Engineer Multirotor Electronics 4 Nov 28, 2014 10:07 AM
Discussion how to connect a naze 32 to FrSky V8r4-2 abutcher Multirotor Power Systems 3 Aug 08, 2014 04:02 AM
Discussion How to connect frsky to naze 32 Help :) abutcher Multirotor Electronics 1 Jul 13, 2014 06:58 PM
Discussion Naze 32 - How to set up aux channels in Baseflight to arm from switch Ground Engineer Multirotor Talk 1 Apr 28, 2014 05:27 PM
