Old Aug 08, 2014, 04:10 PM
Joined Aug 2014
Motor/Battery/Prop Combination Selection
We are developing a motor/battery/propeller combination selection tool and want to make sure it's layout and content is really what you guys need when you're building a fixed-wing aircraft.
I accidentally posted the wrong image of the mock-up here. Please scroll down a few posts to see the correct image.
blucraft is offline Find More Posts by blucraft
Last edited by blucraft; Aug 09, 2014 at 01:55 PM. Reason: Attached wrong image in discussion
Old Aug 09, 2014, 02:54 AM
Staffs, UK
Joined Nov 2003
You might do better posting in the Multirotor section e.g. http://www.rcgroups.com/multirotor-power-systems-846/
In this Aircraft section many of us mainly use 1 motor plus wings for the lift .
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 09, 2014, 01:51 PM
Joined Aug 2014
Thanks slipstick. I didn't realize I was in the wrong group.
I'll edit the original post, because we'd like to do the same thing for fixed-wing builders.
Old Aug 09, 2014, 01:58 PM
Joined Aug 2014
I've attached an image of the front-end of this tool for selecting a motor/battery/prop combination.
Would this tool be helpful to you guys?
Any feedback is appreciated!
Old Aug 09, 2014, 05:36 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
I'm not sure why you'd start with cruise L/D, when that information just isn't widely available, let alone even discussed, or its effect on power system design understood.
You'd need to be more transparent about what motors are going into the database. Calculators that spit out specific motors that people either don't know, can't get, or aren't willing to pay for are of limited use, even though it's not too hard to look for another motor of similar Kv and weight.
scirocco is online now Find More Posts by scirocco
Old Aug 09, 2014, 07:50 PM
Joined Aug 2014
Good points. Yes, the entire database would be available through the drop-down menu under motors, so you could see any of the motors in the database. And - good suggestion. It would be nice to have a list of similar motors and their price so you can quickly see what other options are out there. We will only offer motors that are widely available on the market.
As for L/D, it seems that most people cruise at an L/D of about 10 to 15. I thought that would be an easy way to figure out how much thrust the user needs. Is there a better way? Generally, the user doesn't know how much thrust they need. They have an estimate on structure+payload weight. What methods do you use to choose a power plant from that starting point?
Old Aug 09, 2014, 10:11 PM
scirocco's Avatar
Joined Feb 2001
For most RC models, cruise power and thus cruise L/D is largely irrelevant. Folks are much more concerned (even if indirectly) with excess thrust, which more directly translates into short takeoffs, 'get out of trouble' margin, strong vertical lines for aerobatics, and for some, 3D capability , ie hover and punch out performance. And that is fairly simply catered for by flying style and watts/pound rules of thumb. That tends to get distilled when it is so cheap and easy to provide huge excess thrust to a no-brainer default of 100W/lb, which on reasonable size props gives very strong thrust margins with typically close to 1:1 static thrust:weight.
Unless ultimate system efficiency is an important design goal, it doesn't need to get much more complex than that. And BTW, I'd be a little surprised if most sports models could achieve better than L/D=10.
Also, on that basis there is already an excellent tool that distils airframe characteristics prop size limits and power supply constraints and desired flying style into a generic motor and prop choosing tool - that's WebOCalc http://flbeagle.rchomepage.com/
Old Aug 19, 2014, 03:36 PM
Joined Aug 2014
Thanks for the feedback! Just curious - what keeps everyone from using the tools that are currently out there? It seems that one of the most common topics in the RC world is how to choose a motor/battery/prop combination. Why is this so difficult if the tools already exist to help you do that?
Old Aug 19, 2014, 03:53 PM
United States, MO, St. Louis
Joined Nov 2013
I like that one very much as well. I have read criticisms that it is not specific enough in that it models only generic components (although it is specific to APC props). It offers less information than others but it gives me everything I am looking for. And the systems I have bench tested have all performed pretty close to webocalc projections.
Yoda466 is offline Find More Posts by Yoda466
Old Aug 19, 2014, 04:11 PM
Joined Aug 2014
Yoda- What if that information were formatted like what I've proposed above? Would that me more/less useful? I'm looking to help people see how to change their design to get better flight times, performance, etc.
Old Aug 20, 2014, 03:02 AM
Staffs, UK
Joined Nov 2003
It's not that it's difficult it's mainly that many people would rather trust the real world experiences of other people rather than believing numbers on a computer screen, particularly as we all know that if you get the input to a computer program a bit wrong the result can be total garbage.
Of course the advice you get from anonymous strangers could be rubbish too but by the time several people have told you the same thing it gets easier to believe. That's the joy of forums .
Steve
Old Aug 20, 2014, 03:18 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Interesting project
Particularly the comparison graphs
Good courage
Louis
author of Scorpion Calc freeware
(http://www.rcgroups.com/forums/showthread.php?t=736782)
see menu "propellers"
Fourdan is online now Find More Posts by Fourdan
Old Aug 20, 2014, 10:47 AM
yomgui's Avatar
France, RA, Cormaranche-en-Bugey
Joined Feb 2011
Hi,
I hope the picture you have posted is not really what your program computes.
30 g motor with kv of 5930, spinning a 3 g APC 12x8 propeller (foam made ?) on a 30 g 3S lipo...
Yes, sure you can do better for endurance !!
This is a tool for FPV right ?
I believe there is 2 ways for such optimisation.
- real life tests,
- deep computation and then... real life tests.
The computation is only here so that you spend less time trying various setups.
But there is no possible final answer, though it is possible to get very very close.
Nice project indeed. Good luck.
One thing why I wouldn't use it : there is no access to the formula used and the data source.
But I'm a nag.
yomgui is offline Find More Posts by yomgui
Question Bixler 2 Motor-Esc-Battery-Prop Combination iliketrainz98 Power Systems 25 May 31, 2014 08:40 PM
Help! Will this battery-ESC-motor-prop combination work? cschwab145 Multirotor Power Systems 2 Mar 27, 2014 05:28 PM
Question Motor Prop Battery Combination Haroldl Power Systems 4 Jan 13, 2014 03:51 PM
Discussion What is best method for selecting motor-prop combination? mstanescu Multirotor Talk 3 Nov 18, 2010 07:21 AM
Help!! Give us a tutorial about picking the right motor, prop, battery combination StahlmanGC Beginner Training Area (Aircraft-Electric) 8 Aug 07, 2003 11:35 AM
