Old Jun 16, 2013, 04:51 PM
hoffy1980 is offline
Find More Posts by hoffy1980
Hoffy1980
United States, IL, Maroa
Joined Jan 2013
Question
deepvee setup
Hi,I was just wanting to make sure this will work without to big of a fire. I got a
19" wood deepvee with a 2848 motor, 2700kv and will be running 3s lipo about 1300 mah. The prop is a 3 bladed about 4.4 cm dia. I can get a smaller prop if necessary. I have a solid shaft coming out the back of the boat at the bottom of the vee. Let me know if it will work. Thanks
hoffy1980 is offline Find More Posts by hoffy1980
Old Jun 16, 2013, 06:21 PM
motorfixer1 is offline
Find More Posts by motorfixer1
United States, IL, Fox Lake
Joined Jan 2012
Pics of your setup would help. Is everything water cooled? 1300 mah will not give you a very long run time. Really too little info to make an acurate acessement of your situation.
motorfixer1 is offline Find More Posts by motorfixer1
Old Jun 16, 2013, 07:51 PM
Hoffy1980
Joined Jan 2013
I dont have motor mounted but it will be cooled with copper tubing wrapped around it and esc has built in cooling, rudder has pickup. Its not all the way done got to mount everything inside. Boat isnt as good as what most people do on here but I'm not to worried it is my first scratch built model ever. I still have to make a hatch. It doesnt have to go really fast just didnt want to burn anything up. I can try to upload a picture of it later.
Old Jun 17, 2013, 03:51 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
That prop will most likely be way too large.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jun 17, 2013, 05:42 PM
Hoffy1980
Joined Jan 2013
What would work 2 blade 27 mm? I got one of those also.What size motor would the 3blade 44 mm dia work with? Thanks for any info.
Old Jun 17, 2013, 05:50 PM
Joined Nov 2007
The 3 blade 44mm would work for a 36mm or larger motor. Plus you would get crazy torque roll at that size. I do not really know enough to be able to recommend something, but I'm pretty sure that the 27mm you have would be a good start.
Old Jun 17, 2013, 08:58 PM
Hoffy1980
Joined Jan 2013
Thanks, I see what I can get done.
Old Jun 20, 2013, 03:51 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Hoffy,
Show us some pictures of your build please.
The rather small motor can get overloaded real quick if the set-up isn't right, the angle of the propshaft, sticking out the transom and the distance between the prop and the transom is rather important...
Correct me if I'm wrong, but your motor is most likely a two pole motor, which tend to heat up when running partial throttle a lot, you'll need to run full throttle for 80% of the runtime to avoid overheating both motor and ESC.
A coil on a brushless motor is next to useless, specially on a two pole.
You'll need a cooling jacket where the water runs directly on the can.
Make sure the exit of the jacket sits at the highest point, to avoid the dreaded 'half motor cooling'...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jun 20, 2013, 10:06 PM
Hoffy1980
Joined Jan 2013
I didnt know that . I'm guessing wrapping copper tubing around the motor wont work? It will be a couple of weeks before I can try it anyway props I had were for 1/8" shaft. I still need the do a couple of things, but will take a couple pictures of it. It is ugly so be nice.
Old Jun 21, 2013, 09:39 PM
Hoffy1980
Joined Jan 2013
Here is boat and also a picture of the linberg pt109 I am going to put a brushed motor in it because I had one that came out of it, got a cheap esc for it also.
Description:
Description:
Description:
I am not sure the turn fins are in the right place, it was there or on the bottom. The shaft is not installed nor is the motor mount(homemade from a bracket).Thanks for any help.
Old Jun 25, 2013, 05:18 AM
Hoffy1980
Joined Jan 2013
to ugly to help with???
Old Jun 25, 2013, 03:58 PM
Sneek, Netherlands.
Joined May 2004
Hi Hoffy,
Ugly? You should see some of my builds...
As mentioned earlier the coil isn't going tp prevent overheating, get a fitting jacket.
A universal coupler has no business in a high revving set-up, get a solid coupler.
The prop looks a bit big for the motor, so be careful when you run it, check the motor and ESC temperature at least every two minutes.
The turnfins are in the right place, maybe you'll have to change the angle a bit to get the best result.
Make sure the angle of the propshaft is as shallow as possible and thet the end of the stuffing tube sits 2 mm above the keelline.
The distance between the hub of the prop and the transom shouls be between 10-13% of the hull length.
Let me know if you have more questions.
Regards, Jan.
Old Jun 26, 2013, 06:44 PM
Hoffy1980
Joined Jan 2013
Thanks for info, water jacker and smaller props should be here in a couple of weeks. I can not find a 3.18 motor to 4 mm solid coupler. I was going to use a 1/8" shaft but dont have any thing for it but a dog bone set up for the ptboat dont think that will last. I'm wondering if you mean prop shaft should be up from the bottom of the boat or the water line? Should I worry about center of gravity also? I remember reading about off setting the shaft to one side but cant find it anywhere. I think it was to the right just a little but wasnt sure if that was like a car, drivers side left side. I'm not sure it is a problem with this small of a boat? Thanks for your help.
Old Jun 27, 2013, 02:32 PM
Sneek, Netherlands.
Joined May 2004
Hi Hoffy,
Here's one of many eBay shops selling couplers (check the box for the correct size):
http://www.ebay.de/itm/CMT-STD-Alu-K...item4d0d23441a
Regarding the position of the propshaft, look here:
The angle as shallow as possible and the bearing just 2/16" (2 mm) free from the table the keel is resting on.
Rule of thumb is to have the CoG between 28 and 30% of the hullength, measured from the transom forward.
When your prop rotates counterclockwise, seen from the rear, offset the drivetrain (motor and propshaft) 3-4 mm to the right, to counteract propwalk.
Propwalk is a 'problem' with every single prop speedboat, the propwalk makes the boat veer off to the right, hence the offset drivetrain.
Another counter measure is to have the rudderblade next to the prop.
Regards, Jan.
Old Jun 27, 2013, 02:35 PM
Sneek, Netherlands.
Joined May 2004
Hi Hoffy,
The picture is of my 80 cm Arowana, so ignore the 13,5 mm height:
Regards, Jan.
Sold 32'' Offshore DeepV HYDROJERRY Boats (FS/W) 1 Apr 25, 2013 06:25 AM
For Sale new traxxs nitro 15 deepv ROKJR56 Boats (FS/W) 7 Jun 14, 2008 11:14 PM
Discussion Good Setup, Bad Setup, What setup is good? Discusman Mini Helis 11 Oct 03, 2006 09:29 AM
Prather 46" DeepV For Sale anywaste Boats (FS/W) 6 May 19, 2004 03:04 PM
Shulze Future 45Ho setup VS. Kontronik, The first time setup of Schulze? Inverted-3D Electric Heli Talk 1 Feb 01, 2002 05:04 PM
