Old Dec 17, 2012, 05:32 PM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
How to swap the gear for nine eagles motor
Hi, I have difficulty putting parkzone gear on nine eagles 8.4mm motor. With my needle nose pliers I can push the gear in about haft of it length. Any suggestion on how to push the gear would be much appreciated!
buratino is offline Find More Posts by buratino
Old Dec 17, 2012, 08:01 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Set the gear on end on a piece of scrap lumber. Heat the gear with a soldering iron until it starts burning the wood. Remove the soldering iron and push the motor shaft into the gear applying pressure to the end bell of the motor. It will slip right on and should stay put after it cools.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Dec 17, 2012, 08:51 PM
buratino is offline
Singapore
Joined Nov 2007
Thanks Tim, will try it tonight
Sold Cox / Nine Eagles Micro Motors (for Cox Xtra or Sky Cruiser) ShokWaveRider Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2012 01:14 PM
Discussion nine eagle 180, how to revert tail gyro correction? eders Micro Helis 3 Mar 08, 2012 12:38 AM
Discussion Nine Eagles Solo Pro landing gear - How are you fixing it? Recoplon Micro Helis 6 Feb 18, 2010 10:44 AM
