Old Apr 28, 2013, 07:39 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
If you want telemetry, I really recommend switching over to FrSky. They are also releasing a $200 transmitter that has 60 model memory and other amazing specs.
Koo is offline Find More Posts by Koo
Old Jan 13, 2014, 02:52 PM
syzygyQ is online now
Find More Posts by syzygyQ
Joined Oct 2011
What range can you get reliably using this TX module using the stock antenna, installed in a stock 9XR, and running a stock "full range" OrangeRX DSM2 RX?
Will this set up match the performance of a stock DX6i for range?
syzygyQ is online now Find More Posts by syzygyQ
Old Jan 15, 2014, 12:28 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
It should. The ORx DSM module is a full range Tx, but the actual "performance" will be determined more by how your equipment is set up.
A preflight range check should give some indication of the range "performance" of your set up.
KC is offline Find More Posts by KC
Old Jan 21, 2014, 11:25 AM
Joined Oct 2011
I got 200 meters downrange in a field test before gltiching into failsafe and getting signal back.
The glitch out could have been due to antenna angle (I had it mounted @ 90 degrees parallel to the TX case back -- bad angle for my main RX antenna although just a bit better for the satellite).
Extending the antenna down, or pulling the u fl lead out and running the antenna out the top of the TX in "standard" spektrum position might help.
We'll see.
Old May 13, 2014, 03:20 AM
piotrkundu is offline
Find More Posts by piotrkundu
piotrkundu's Avatar
Joined Feb 2014
From what I have seen so far most issues with OrangeRX is on the receiver side and that Spectrum receivers will perform better in a range check. I think the TX is "good" in a sense that I suspect it puts out more than 100mW, considering the RX noise I get in my Taranis.
Then again there are plenty of sad pilots using original DSM2 Spectrum TX & RX.
PS. I still can't believe people are calling Hitec "branded" radio - that stuff was a guaranteed to down your models in the past.
piotrkundu is offline Find More Posts by piotrkundu
For Sale Jr/Spectrum Rx's and Modules for sale (2.4 Module, AR6110e, AR6115e, AR7000, R900s) Twyl Aircraft - General - Radio Equipment (FS/W) 9 Apr 03, 2012 12:23 PM
Found Wanted: Spektrum DM9 DSM2 TX Module for JR John Boy Aircraft - General - Radio Equipment (FS/W) 2 Mar 24, 2012 12:16 AM
Sold spectrum dm8-dsm2 module for futaba 9c vic gensberg Aircraft - General - Radio Equipment (FS/W) 1 Mar 16, 2012 10:28 PM
Sold [SOLD] OrangeRx DSM2 6ch Receiver Compatable with Spectrum Tx studizzle Aircraft - General - Radio Equipment (FS/W) 22 Jan 29, 2012 12:20 PM
For Sale JR XP9303 Spectrum 2.4 DSM2 Module + PCM- HELI dotdigital Aircraft - General - Radio Equipment (FS/W) 0 Sep 03, 2008 05:53 PM
