Old Oct 24, 2010, 07:21 PM
givemeprops09 is offline
Find More Posts by givemeprops09
Joined Aug 2009
Question
Fiberglass material
I have my hull almost finished and want to get it fiberglassed. Was curious what some of you modelers have used to fiberglass a wood hull. I have looked around and have found a lot of products for repairs and auto body fixes but because I am a cautious person I dont know what I should really use. Thanks for any information
givemeprops09 is offline Find More Posts by givemeprops09
Old Oct 24, 2010, 07:37 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
2 or 3 oz woven cloth (not mat!) is fine for waterproofing and securing wood planked hulls. One or two layers, depending on how much toughness you want to add. I'm usually happy with one on wood planked tug hulls.
Regular old polyester resin is fine, if you don't mind the stink. Epoxy can be used indoors without odor, but costs more. For epoxy, Z-Poxy from a hobby shop is fine, or West Systems from a marine supply store.
I hope you like sanding and filling!
patmat2350 is offline Find More Posts by patmat2350
Old Oct 24, 2010, 07:39 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
For a painted hull, life is easier... but get a good idea of the process from Pat T's article on glassing mahogany hulls:
http://www.rcgroups.com/forums/showthread.php?t=329811
Old Oct 24, 2010, 08:03 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
I used an Enviro-tex pour-on epoxy finish on my current project, worked fine. It's about 40 bucks at any Michaels craft store so grab one of their coupons.
ZZ56 is offline Find More Posts by ZZ56
Old Oct 25, 2010, 12:05 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
I have moved away from using polyester resin because of the smell. I use the Evercoat epoxy resin.
You can not go wrong with either one. But what I would highly recommend, start using one, and always use only one. I have had several occasions where I had a boat that was started with one form, and for some reason or another had to do a repair and used another form. They often will not stick to each other.
Tachikaze is offline Find More Posts by Tachikaze
Old Oct 26, 2010, 06:26 AM
Barthez is offline
Find More Posts by Barthez
PMBC
Barthez's Avatar
Joined Oct 2005
My standard method of hull construction is balsa plank on frame covered with two layers of glass cloth. I use polyester resin because it's cheap and due to working in the industry for many years and my father using it in the house when I was a child !!!! I can no longer smell it.
When it comes to sanding you can mix filler powder with catalised resin to make your own isopon type filler (bondo) and spread that on, it can be a cheaper alternative to using shop bought fillers.
Bart
Barthez is offline Find More Posts by Barthez
Old Oct 27, 2010, 01:44 AM
terryking is offline
Find More Posts by terryking
On The Red Sea in Saudi Arabia
terryking's Avatar
Saudi Arabia
Joined Oct 2010
Boats Is Boats...
Here's a pointer for a lot of detail about materials for building boats, epoxy etc..
http://www.boatdesign.net/wiki/MaterialsForBoatbuilding
And just in case you're into super strength there's this:
http://www.boatdesign.net/wiki/Kevlar
Almost all this stuff applies, just scaled down: thinner and tighter weave fabrics etc. West Epoxy (West Marine or Defender Industries in USA, or your local boat supply house) is great because it will keep for up to 5 years. Get one of those $10 digital scales, thin hard plastic drink glasses, and mix by weight any amount you want.. Stir for 60 seconds and you're ready to use. See the many filler materials. There are different hardeners for long or short time cure.. etc.
And if you're like me, you'll find MANY uses around the house and car also..
I get no commission :-)
Regards, Terry King ..On the Red Sea at KAUST.edu.sa
terryking is offline Find More Posts by terryking
Question Stator Coating material lixo Electric Motor Design and Construction 31 May 08, 2011 08:58 AM
For Sale Large Lot of Airplanes and Building Material, Hardware in Northern Illinios. bobschultz Non R/C Items (FS/W) 42 Nov 25, 2010 07:52 AM
Discussion electronics board material RCpilotwantabe Robotics 2 Oct 17, 2010 11:24 PM
Discussion Core material for a project reinking Composites Fabrication 1 Oct 16, 2010 12:56 AM
Link Fiberglass plate material Boneswamped Auto Gyros 0 Dec 21, 2008 05:45 PM
