Old Nov 18, 2012, 03:58 PM
Joined Nov 2012
Help!
Please Help Mini Super Cub
Hello.
I am a beginner rc flyer and received my rc airplane as a gift 2 years ago. It has been sitting in my garage for a while and I wanted to run it. Here is the problem: even with a full battery, the motor does not run for long. When I have the throttle on the remote on full, the motor lets out a blast for 1 second, then turns off even with my hand still full on the throttle. When I disassembled the propeller assembly with just the motor, the motor would work perfectly. I cleaned out a lot of dirt from inside, but to no avail. It does not work with the propeller on.
If anyone has been having the same problems and knows how to fix it please respond!
pencil588 is offline Find More Posts by pencil588
Old Nov 18, 2012, 04:30 PM
Livermore, CA
Joined Sep 2004
Sometimes when the battery sets too long, it can be charged, but will not hold the charge when you put a load on it.
Butch777 is offline Find More Posts by Butch777
Old Nov 18, 2012, 05:34 PM
Joined Nov 2012
I do not think it is a problem with the battery because when I remove the propeller, the motor works perfectly fine. Thank you for the reply
Old Nov 18, 2012, 05:47 PM
United States, SD
Joined Aug 2010
The motor won't have to work without the prop on it, so the battey will last longer.
Kyler1 is offline Find More Posts by Kyler1
Old Nov 18, 2012, 05:49 PM
United States, CA, Santa Rosa
Joined Mar 2011
Try a new battery. It doesn't matter what the motor does with no prop because
there is no load on the battery.
asosestrom is offline Find More Posts by asosestrom
Old Nov 18, 2012, 06:13 PM
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
Try running at half to a quarter throttle with prop on and see if it runs a little longer? It's going to be your battery?
tupeloflyer is online now Find More Posts by tupeloflyer
Latest blog entry: Sig New ARF 4 Star 64
Old Nov 19, 2012, 12:10 PM
United States, CA, Oceanside
Joined Apr 2011
If I remember correctly the battery is the 5 or 6 cell nicad or nimh right? Sometimes nimh battery packs can be resurrected by charging, discharging and then repeating the cycle about 4-5 times. I have done that with car battery nicads/nimh batteries before.
chucksolo69 is offline Find More Posts by chucksolo69
Old Nov 23, 2012, 03:55 PM
Joined Nov 2008
The prop is a loading of your motor, if you remove it, the motor will run becasue it drain less current. change the battery.
Edmond
Edmond Y is online now Find More Posts by Edmond Y
Old Nov 25, 2012, 11:25 AM
builderdude's Avatar
United States, TX
Joined Jun 2011
In fact, consider an upgrade to a Lipo battery.
builderdude is offline Find More Posts by builderdude
Old Nov 25, 2012, 02:03 PM
I live on LiPos
RcAirplaneNoob's Avatar
United States, DE
Joined Jul 2012
The battery has gone bad save your self the trouble and buy a 5$ battery
RcAirplaneNoob is offline Find More Posts by RcAirplaneNoob
Old Nov 29, 2012, 09:56 PM
tonytiger20's Avatar
USA, MS, Picayune
Joined Jan 2011
Also make sure you turn off the anti crash stuff. That will cause the motor to cut out too. Your owners manual will explain how.
tonytiger20 is offline Find More Posts by tonytiger20
Old Nov 30, 2012, 12:35 PM
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
My champ did that when the battery was not charged fully. Also, there is a cutoff mode when the power is lost, but the best way to fix it is just make sure the battery is fully charged. If it is, then buy another battery.
Wrice4 is offline Find More Posts by Wrice4
Help! Hobbyzone Super cub or Mini Super cub? fuzzynorman Beginner Training Area (Aircraft-Electric) 10 Sep 09, 2013 06:49 PM
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 09:01 AM
Help! HZ super mini cub or TG super cub? HELP!! awesome_smiley Beginner Training Area (Aircraft-Electric) 10 Dec 27, 2009 11:36 AM
Wanted Mini-Super Cub, Super Cub, Bird Dog, etc. oldenway Aircraft - Electric - Airplanes (FS/W) 2 Dec 07, 2009 08:23 PM
Discussion Super Cub or Mini Super Cub 98PaceCar Beginner Training Area (Aircraft-Electric) 10 Jan 06, 2009 02:04 PM
