Closed Thread
Old Oct 30, 2012, 07:53 PM
tsecrist's Avatar
Salt Lake City
Joined Apr 2005
Esc getting hot !
I am building an alfa fw190 and mounted an mpjet motor and attached the cowl of the plane. I attached the 25 amp great planes esc and put in the 6100e reciever. I attached the battery to the speed control and the esc got hot very quickly. I quickly unplugged the battery and checked for bad wiring to the motor! Everything checked out so I plugged the battery against with same the result. The esc was then fried because it would start the motor. I checked everything again and to my bewilderment I discovered that disconnecting a servo solved the problem. Meanwhile I fried two esc at $30 each all because of an $11 servo. Anyone else have a similar problem? Tim
tsecrist is offline Find More Posts by tsecrist
Closed Thread
Discussion Problem - ESCs and motors get real HOT Zeifod Multirotor Electronics 19 Aug 30, 2012 10:40 PM
Help! 30amp ESC gets hot with only 9amp!!?? Von Cave Power Systems 4 Apr 16, 2012 03:31 AM
Discussion Computer getting hot with RF 6 Ernie Misner Simulators 17 Mar 27, 2012 10:13 AM
Help! ESC programming card and ESC supposed to get hot when transfering data? RollingR6 Beginner Training Area (Aircraft-Electric) 9 Jun 06, 2009 01:45 PM
